Question about Maytag Neptune MDE5500AY Electric Dryer
Loose baffle in my Maytag Neptune MDE5500AY electric dryer
One of the baffles in the drum of my Maytag Neptune MDE5500AY is loose. How do we open the cabinet to get to where we can tighten it?
  • Maytag Master
  • 3,053 Answers
Hello, sheila I was trying to help you out here. I wasgoing back to some customers that asked questions in the past and it appearedthat no one answered them, so I thought I would take some of my personal timeto see if I can help. Here is a link to about everything you want to know aboutyour dryer, from repair to trouble shooting it. If you go to this link andclick around, I am sure you will find out so much about your dryer, you willknow more that the company that made it. Here Is the link for you to click onhttp://home.howstuffworks.com/how-to-repair-a-dryer.htmPlease if this helped you at all, if youcan find the time to rate my help and some kind words written would beappreciated for my free help , I would appreciate it. Here is also my direct link to my own pagesof other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike http://beta.fixya.com/users/mc1bean
Posted on Oct 26, 2011
The beater bar in my Neptune dryer modeL # MED5500AYW has come off and needs to be replaced.
It sounds like you are referring to the drum baffles when you say "beater bar". If that is so, you need to remove the front panel then raise the top cover to access the baffles mounting screws outside the drum. Below is the link to the procedure I posted previously.
Maytag Neptune Dryer Front Panel and Top Cover Removal
Sep 09, 2010 | Maytag Neptune MDE5500AY Electric Dryer
We have a neptune front dryer and a baffle came loose inside the drum. How do we repair it
an easy way of reinstalling the baffle is remove the top cover or rather flip the cover upward this will show you the dryer drum in which u can spin the drum to the proper spot where u can retighten the screws that hold the baffle on hope this helps
Jun 25, 2010 | Maytag Neptune MDE5500AY Electric Dryer
One of the plastic pieces inside the dryer drum is loose. How do I remove the dryer top so I can tighten the screws>
OPEN THE DOOR. INSIDE THE OPENING ARE FOUR SCREWS 2 ON EACH SIDE. REMOVE THESE. EACH SIDE OF THE FRONT PANEL KIND ROLL OF FROM INSIDE TO OUT AT THE TOP. OR JUST PULL. BRING THE FRONT PANEL OUT TO A 45 DEGREE ANGLE. CLOSE THE DOOR AND LIFT UP ON THE FRONT PANEL. AT THE FRONT OF EACH TOP CORNER THERE ARE HOOKS HOLDING DOWN THE TOP. THEY ARE SCREWED IN PLCE WITH A 5/16 TH HEX HEAD SCREW. REMOVE THOSE AND THE TOP CAN LIFT UP.
Apr 25, 2010 | Maytag Neptune MDE5500AY Electric Dryer
How do I install a baffle for a neptune dryer?
unplug the dryer,open the door,take out the 2 screws that hold the door in and remove the 2 screws opposite the door screws,remove the door and pull the front panel off,spin the drum until you line up the baffle that you need to work on is down in the right hand bottom side,you can get to it there
Apr 02, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My Maytag dryer has a loose dryer drum baffle. How to i get to it inorder to tighten the screws? Do I remove the top
unplug Dryer, open door, Remove two door hinge screws going into front panel, remove two screws on opposite side. Grab front panel on upper sides and twist and pull front panel out. Panel sits on two clips at bottom so you have to tip panel out to unhook from the bottom. You will see a metal hook with two screws in it that holds down the top of the dryer on each side. Remove the screws and hook bracket. Make sure you note how it reinstalls. Top will now lift up and lean back against a wall. It is hinged in back. You can now easily get to the drum baffle screws. Good Luck, Appliance Specialists
Dec 17, 2009 | Maytag Neptune MDE5500AY Electric Dryer
BAFFLE INSIDE THE DRUM IS LOOSE. HOW DO I TAKE FRONT OF CABINET OFF SO THAT I CAN GET TO OUTSIDE OF DRUM TO TIGHTEN SCREWS HOLDING BAFFLE?
Open the front door where you load the machine.
Look towards the top where the door normaly closes, there ususualy two screws that you can unscrew there.
Once loose the top pannel should come off, which allowes you to remove the front panel with 2 screws as well.
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_341f3f9dee622e54
Nov 14, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Baffle loose (Can see hole when moving baffle)
Hi there :)
The baffles are held in by 2 quarter inch screws per baffle. The only way to get to them is by taking off the top lid of the dryer.
Good luck.
Aug 05, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune MPG5500AWW loose baffles but can't figure out how to lift top or front
Press a putty knife in at the top front corners. That will release the spring catches.
May 04, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer Baffle Coming Loose
See if there are 2 screws located at the bottom front of dryer,unscrew anft panel up untilthe clips that are at the top disengage, disconnect door switch and any other connections , taking note of the connections.
W
Jan 05, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Baffles are loose on my dyer maytag neptune mde5500
Hi Nick, welcome to FixYa!
1. Open the door and remove the two screws that secure each of the door hinges to the dryer frame. With the door open so you can take a hold of it, simply pull the whole door out of the notches that the hinges fit into.
Next, remove the two screws on the opposite side of the frame where the door closes to. (along with the two white plastic trim pieces the screws go thru) Once the door is off and the screws are out, pull the entire front panel forward and then it will lift off the tabs at the bottom and you can set it aside.
next, look up near the top of the cabinet, on each side, for the metal hooks that secure the top to the cabinet. Remove the screw (5/16" nut driver) that secures each hook to the cabinet. Take the hook off, repeat for the other side.
Now you can lift up the top of the machine, and rotate the drum so that the loose baffle is at the top so you can work on the baffle easily. Rotate the drum to the next baffle, etc.
I hope you find this answer helpful.
Dec 28, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
286 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
