Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
Sharp turns mower didgs in ground or on unlevel ground
It is a16.5 42 inch deck i have tryed every thing to adjust the mover to corect this would a set of mower deck wheels soulve this
    President:
  • Poulan Master
  • 1,545 Answers
If you have the owners/operators manual that came with the mower, it will have instructions on how to LEVEL the mower deck. That sounds like your problem. Deck wheels would greatly help also by stabilizing the deck so it doesn't bounce and "float" so much while mowing.
Posted on Jul 13, 2010
How do I remove mower deck on Toro riding mower 1986
First put the front on a jack stand on high. then lower the deck all the way down. Look at the three places on each side to remove the pins that hold the deck on Then there should be two in the front of the deck, remove them. Remove the belt from the motor pully. Lower the mower to the ground and release the peices the pins were in. Remove the clip from the tension cable and remove the cable from the deck. Raise the mover to pull out the deck. Reverse to instal
I hope I helped you
Oct 04, 2014 | Toro Garden
Craftmans mover blade keeps hitting ground
Is the deck too low or one side lower than the other? Level the deck side to side, front should be a little lower than back (about 1/4 inch). check tires for correct air pressure. Make sure blades are balanced.
May 10, 2014 | Craftsman 42 in. Precision Cut Plus 24hp...
I need to adjust my scag mower deck
The mower deck can be adjusted from a height of 1.0 inch to 6.0 inches at 1/4-inch intervals. To adjust the cutting height:
1. Disengage the power to the cutter blades.
2. Push the cutting height adjustment foot pedal all the way forward using your right foot until it locks in place
3. Insert the lanyard pin into the cutting height index at the desired cutting height. Push forward on the deck lift foot lever, hold in place and pull back on the deck release lever. Slowly release the foot pedal. A deck height decal is located on the cutting height index as an aid in adjusting the deck to the desired height.
Aug 18, 2013 | Scag STT61V-27CH Hydrostatic, Gas Turf...
I have Poulan Por 54 inch deck,25 hp Kohler hydrostatic. After I mow on unlevel ground for about 30 min. Transmission makes noise jerks and won't go till it cools off. Will changing the fluid help
couldn't hurt to try but some cheaper mowers don't have a drain plug look on a parts break down on sears parts online but check the belt tension first
Apr 13, 2012 | Garden
Riding mover 42" deck, clogs
Wet and or excwssively high grass? Blades sharp?
Apr 21, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Yard machine 21" 6.5 does not catch all clipping when bagging dry grass. Under deck is clean and the deck height is even. Also leaves blades of grass uncut. The mover is brand new and the blade is very...
Did you buy this mower from a dealer and built up and checked over or did you buy it in a box and put it together yourself? i suspect you probably bought it in a box and put it together yourself as it sounds as though the engine isnt reving high enough. Briggs and stratton engines are well known to come out of the box with the engines reving much lower than they should be. you will need to check and adjust the high speed engine revs to approx 2900-3100 rpm
Aug 18, 2010 | Mtd 22" Yard Machine Push Mower
I have a Murray 40 inch riding lawn mower and I had to replace the blades - which I did but when I went to mow the lawn it dug up my lawn so I thought I put the blades in wrong so I reversed the blades and...
It sounds like your mowing deck is too close to the ground. Can you adjust the blade height with a lever? I have a Craftsman riding mower, my deck height is adjusted manually with the use of a locking level shifter, be sure yours is set to the proper minimum height and this will eliminate driving the blades into the turf.
Sep 21, 2009 | Garden
Deck unlevel cutting unevenly
with deck up,, take a ruler and measure mid way each side,,if off you have nut on the deck you can screw up to raise,doen to lower,, but if side to side level,, then you have 2 rods at the front at the front axle, measure the rods and make sure that both the same length if one is off turn to match the other,, but if you turn both make sure you turn both the same turns,, hope this help you,, good luck
Aug 09, 2009 | Garden
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
232 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
