Question about Bissell 8920 ProHeat 2XTM Upright Vacuum
How to get water to spray on my bissell 8920 - Bissell 8920 ProHeat 2XTM Upright Vacuum
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
eytytu
Posted on Sep 30, 2010
  • 184 Answers
SOURCE: bissell carpet cleaner won't spray water or cleaner
If I may! In most cases the heater is clogged. It might be clogged with soap that has harden over time. You need to take the handle apart. You will see a metal box(thats the heater) besides the wires there are two tubes connected to the heater. remove the tubes but label or watch which tube goes where. now turn the heater upside down. there are 6 screws on the side and 1 in the middle. remove them carefully. the 6 on the side have a small gaskets under them..you don't want to lose them. the 1 in the middle has no gasket, now the bottom plate of the heater can be taken off (there is a gasket with that plate ...be careful . you will now see the long channels inside the heater and need to clean it. the holes where the tubes where connected have to be clean also but carefully. the metal is soft.so it bends. now put it all back. hope this helps. if you want to keep this from happening.the best way is to run clear water after you are done.this will remove any soap in the machine which will harden after the machine drys out. hope I helped .
and to mr. reddevil6 I am learning lots from you. Thanks
Posted on Feb 13, 2008
reddevil6
  • 1673 Answers
SOURCE: I have a Bissel Proheat
Could have a bad pump, also there are solenoids, one of these could be bad.
Posted on Apr 20, 2008
Lildv8one
SOURCE: bissell 8920 won't release fluids at the rollers
clean your heater out that is in the handle hard water builds up in it and then causes it to become clogged
Posted on Oct 10, 2008
SOURCE: Bissell carpet cleaner won't spray water on floor setting
I have the same problem, can someone help.
Thanks
Posted on Jul 30, 2009
  • 10 Answers
SOURCE: bissell proheat 7 will not spray water or cleaner
Thanks to many others who have posted on similar problems -- water and/or solution sprays through the handheld tools, but not through the main machine.
As others have suggested, I removed the water reservoir, which exposes the 2 main water sprays mounted above the rollers. Using, pliers, I carefully slid the clips back. Gently but firmly removed the two red nozzles.
Elsewhere I have read suggestions to just do one nozzle at a time. However, I found out that if you remove both red nozzles, you can then blow through one side and it will come out the other. In my case, that dislodged a nice collection of crystal-like chunks (guessing it may be crystallized residue from the cleaning solution).
There was also a bit of blockage in one of the red nozzles, which I cleaned out. Make sure you can blow through both of them with little resistance.
Reassemble: Push red nozzles back into hoses. Using pliers, reposition sprung clip back over the red nozzle. Snap nozzles back into place. Refill tanks and power it up.
In my case, that resolved the problem of no sprays from the main machine. Sprays like new now. Hope yours does too!! g
Posted on Sep 26, 2009
Bissel pro heat 8920 no spray water ,soap and roller will not turn
It may have a drive belt that's gone bad. Try the video Ive attached.
Jul 25, 2016 | Vacuums
Cant find heater in bissell 8920
I have one and watched a video on youtube that shows the red washer in the improper place under water tank. It shoed in unit base. He removed with screwdriver and placed back on nipple on the water tank and it worked.
Jan 21, 2014 | Bissell Brushroll Proheat 2X 8920 9200...
My bissell proheat 2x 8920 has poor suction and wont spray water
take a tooth brush to the very back of the roller and u will free the dirt in the small holes at back
Mar 22, 2013 | Bissell ProHeat 2X Upright Deep Cleaner,...
Bissell proheat2x 8920 wont spray water
Hey Patti, spray is important when you want to clean. Here's a link to toroubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1122
Jan 26, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
I cannot get my bissell proheat to spray
open the machine and remove water heater, then remove all seven crews and clean the inside of the water heater, then replace the heater.
Feb 26, 2011 | Bissell 8920 ProHeat 2XTM Upright Vacuum
We have a Bissell Proheat 2X (model 8920). The problem we are having is when water/soap is initially released (all settings) it continues to leak out the front water spray nozzles unit the water...
Return it. It is faulty and should not do that. Mine does not. Does require changing water about evrery 10 minutes but one can see the filth in the water. Also re-clean with plain water over areas that were cleaned to remove all cleaner. Old cleaner in carpet to dirt is like a bug attracted to a bug zapper. It can be time consuming, but it will pay for itself and can do a great job if you pay attention when water or cleaner runs out, otherwise it will not clean properly!
Jan 30, 2011 | Bissell 8920 ProHeat 2XTM Upright Vacuum
Bissell 8920 won't release fluids at the rollers
I have an 8920 ProHeat 2x as well with the same issue - no spray at the rollers. Seeing that the hand tool worked I checked the finger switch for continuity and it was good. Turns out the red spray heads that clip into the unit just under the water tanks were the culprit. I popped those off and ran a paper-clip through them from the front. I must have contaminated the fresh water tank while emptying the grey tank. Works better than ever now, just thought I'd share what my issue turned out to be.
Oct 10, 2008 | Bissell 8910 ProHeat Clear View Upright...
Bissell 8920 ProHeat 2XTM Upright Vacuum Logo
548 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
