Question about Toshiba Satellite A105 Notebook
Still having problems with windows xp installation
I have formatted and done it again and still i am having trouble. i still cant get it to do anything.
    Brigadier General:
  • 6,966 Answers
If I may add to the other posts...
A couple of things:
1. When you formatted, it is precluded that Windows will have to be reinstalled, were the appropriate drivers likewise reinstalled? This could be verified with the absence of any yellow or red marks in Device Manager. If there are any marking (red/yellow) then that is indicative of the drivers missing or a hardware problem;
2. Most problems could be software in nature, what specifically does the laptop fail to do after your reinstall of Windows?
3. Have you tried using the recovery CDs that came with the laptop?
4. But then again, it is also possible to have hardware issues, any message when the failure occurs? BSODs? restarting again and again?
Hope this be of additional help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 24, 2008
Does windows always have this problem? I think it can be fixed through a <a rel='nofollow' href="http://www.pcaholic.com"> computer check up</a>. Might want to have a good at the website <a rel='nofollow' href="http://www.pcaholic.com"> http://www.pcaholic.com</a>.
Posted on Apr 22, 2008
    Genius:
  • 3,422 Answers
Hi ,
come on,line on yahoo coolguy4u_008@yahoo.com
Posted on Apr 20, 2008
Hi install Windows 7 on my hp compaq nx6310 Celeron M. and put a 500GB HD I worked fine but after installing some programs are lost anrranque files then I wanted to install windows xp tells me not see the...
restart your computer witht he XP cd in your drive and maiing sure it boots to cd by either pressing F12 or going into your bios and setting the priority to cd first then hard drive second after you have done this if it still cant see the hard drive then the hard drive has developed a fault and will need replacing if you havent formatted it yet try and see if it boots up to windows 7 if it does then it means the xp cant format the drive. if you have more problems then please use the comment below to describe whats being done. Kronoguy
Jun 29, 2011 | HP Compaq Business Notebook nx6310 -...
How to uninstall win xp
You cannot uninstall Windows XP from your laptop. But you can install it over again if its Windows XP that you want to install again. Restart your computer and press the F8 key. On the next screen select Repair Computer. Follow the instructions. This option lets you re-install Windows XP to your factory condition,
Nov 18, 2010 | Dell Latitude D600 Notebook
How can i remove windows 7 starter and install windows xp
Boot to you bios and make sure you can boot off your dvd rom first. boot off you win xp disk and follow the instructions.
First locate drivers that are compatible with your computer and win xp.
Apr 06, 2010 | Acer Aspire One PC Notebook
We are unable to load window xp on hard disc, before we only find the 32 GB in 80 GB hard disk ... we successfully installed the window xp, but when jumper setting done in accurate place, it shows 80 GB,...
I think this model is still an IDE type. You set the 32GB limit then jump the settings to read the full capacity of the drive. If you are trying to load XP OS from a blank drive.
First prime the hard drive, you can do low level formatting and use third party software to partition and format the drive. on FAT32 partition you can only use 8GByte to make the drive bootable. Make it primary if I remembered it correctly and active. Or use the NTFS format.
You can use also if it have the manufacturers' hard drive utilities to check the hard drive integrity. I know they have it. It also equip with zero fill to renew chain and links of the drive. Then partition, format, primary and active. Then load your OS.
Check also your CD disc integrity, scratches do make a lot of troubles. And also your cdrom/dvdrom drive.
Oct 27, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Recovery disk
Your description tells me that you have a bad XP installation, but you do not need a recovery disk, unless you wish to use that bad installation.
Because the installation is bad, I would just delete the partition and start over again.
If you have formatted your hard disk in order to install a new Operating System (I assume Vista), one of the steps of the install detects that an existing installation of Windows does exist (XP in your case), and it asks you whether you wish to use this existing install and overwrite it, to install to a different directory, or to delete the partition and start anew.
I'm confused by your statement about trying to install Outlook after reformatting your hard drive. That cannot be done directly. First you need to install Windows (any version) before you can install either Office or Outlook.
If you're installing Windows from a CD or DVD, allow it to go through the steps until you get to the prompt for you to use the existing installation or not. Here you have the chance to delete the previous XP installation and continue with the new install, whatever that is.
Aug 14, 2009 | Computers & Internet
Acer asire 5920 wont boot up cant get to windows to type anything in just a black screen asking for password or harddisk password. have acer aspire 5920 system disk it works asks for recovery disk 2 runs a...
For the psswords i can recomend to reset them from BIOS but to do that you must first know them. The problem with recovery disks is solvable if you boot from an XP disc and format the C: partition in NTFS file sistem and when it starts copying files to install the windows stop the installation ( F3 or press the power button for more than 4 seconds.. don't worry you will not sustain disk damage... done it myself with the same notebook for a dozen times ) After formatting the partition C: try recovery again and it will work.
NOTE: for the formatting of the partition you must set the HDD mode from AHCI to ATA witch permits the XP setup utility to "see" the HDD. If it is set in AHCI mode the setup utility for windows XP will not detect youre HDD
Jun 16, 2009 | Acer Aspire 5920-6727 Notebook
Window Xp Pro Setup Hangs at Logo Screen after reboot
You can try also to do reformat your hard drive as fresh unallocated one before doing formatting again to install windows. And check your installation disk for scratches.
May 07, 2009 | Microsoft MS Windows XP Professional SP2
Reinstalling windows XP
you need to have the windows XP installation disc.  your going to want to back up all files onto some other drive (e.g. usb) and then reinstall the files.  this will delete everything off of your computer so thats why everything must be backed up.  if you dont have the installation disc, let me know and i can get you the files another way
Dec 02, 2008 | Compaq Presario Notebook
Auto format new hard drive in new custom pc
If you mean boot from cd with xp pro during setup you will have the opportunity to format drive either fat32 or ntfs use ntfs
I have never done it but if you can do it partition your hard drive so that you can save personal file and programs on second partition then if you have to format drive again your files on second partition will not be lost
Aug 04, 2008 | PC Chips (M925G) Motherboard
Hello sir
the anti virus cant remove it coz then your pc will not start again and so windows denies it so format ur drive containing ur xp then install xp again it will be done
Dec 14, 2007 | Acer Aspire 5610-4648 Notebook
Toshiba Satellite A105 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
