Question about Linksys 1 x 4-pin Type B USB 2.0, 4 x 4-pin Type A USB 2.0 - External Instant USB 2.0 Connectivity - The E
Usb network adapter error
I have a linksys 2.4 ghz wireless-g usb network adapter. I have used it on my home computer running windows xp pro and it worked ok. I sense moved it to another computer running windows 98 and it was working. I just installed windows xp pro on this computer and when I plug in the adapter it resets my computer over and over again. the error message reads "access violation at address 00427441 in module wusb54gv4.exe. read of address 00000368. Any ideas?? Thanks
  • Helpmepleass Apr 20, 2008
    Still doing the same thing.
  • 144 Answers
What I recommend is to uninstall the driver and reinstall it back again.Incase the 1st solution doesn't work then you need to uninstall the other driver off first,like sound and display, and install this wirless beferore them.I think conflict with the other driver.
Best of luck,takecare
Posted on Apr 20, 2008
  • Technocom
    Technocom Apr 22, 2008
    I'm sorry I wasn out of town.So my last suggestion can be that its not enough power on the USB port. But you said it was working fine when you use in Win98!!!! So my quesiton is that
    1.Did you plug on the same port like last time ?
    2.Did you use any external usb port ?? If so try to connect directly behind you computer.
    3.My last quest here is that ...if you still have the same problem then it can be all of a sudden you have a bad USB port..mean not enough power supply for your USB port.
I bought AE1000 wireless N USB adapter, and i cant get it to install, says "wireless adapter setup requires that wireless connections are managed by Microsoft windows, says to try the following,...
When you insert the setup disk on your computer, you can exit from the setup and then connect the adapter to the computer and a new window will popup "Found New Hardware Wizzard" and in that select the option "Install the drivers Automatically" and click on next, so it will automatically search for the drivers and install it on your computer... Once the drivers are installed on your computer then you can try to connect to your wireless network.
The Linksys AE1000 Wireless USB Adapter helps you connect your computer to a wireless network for quick Internet access. Installing the Linksys AE1000 is fairly easy. Just follow the steps below in setting up the Linksys AE1000 on your computer or laptop.
Minimum system requirements
- A computer with 1 GHz or faster processor.
- 512MB or more RAM.
- An available USB port.
NOTE: The Linksys AE1000 is supported for Windows 7, Vista SP1 and XP SP3 but NOT for Mac.
Step 1:
Insert the Setup CD into your CD-ROM drive.
Step 2:
Click Set up your Linksys Adapter. Proceed to Step 4.
If you do not see this, click Start on your computer and click Computer. Double-click on your CD-ROM drive. Continue to Step 3.
NOTE: For Windows XP, the file may be known as Setup.exe.
Step 3:
Read the License Agreement and click Next.
Step 4:
Insert the Wireless USB Adapter into a USB port on your computer or laptop.
Alternatively, you can also use the USB Extension Base to connect the Wireless USB Adapter. Plug the Wireless USB Adapter into the USB Extension Base and connect the Base to a USB port on your computer or laptop.
Step 5:
If you have an Easy Setup key, select Yes, I have an Easy Setup Key and click Next. Proceed to Step 8.
Otherwise, select No, I don't have an Easy Setup Key and click Next. Proceed to Step 6.
NOTE: For more information on Easy Setup Key, click here.
Step 6:
Select your wireless network and click Next.
Step 7:
If prompted, enter the wireless password for your network. Proceed to Step 10.
Step 8:
Follow the on-screen instructions. Click Next once you have completed the on-screen instructions.
Step 9:
The installation is complete when you see the screen below. Click OK.
Step 10:
You are directed to the Cisco Connect screen. Click Close to exit.
Nov 04, 2010 | Linksys AE1000 IEEE 80211abg IEEE80211n...
Have a computer with a new lynksis wireless-b router. i am running windows xp but dont have internet to the computer (minus the wireless) how can I install a driver with no cd or internet?
If you do not have the drivers on media, then you will have to obtain them first. Can you temporarily hookup wired and get them downloaded? or use a usb flash drive on another computer to access and download the drivers...
Apr 14, 2010 | Linksys 2.4 GHz 802.11b Wireless - B PCI...
Adapter recognizes wifi but windows xp won't
it may need a Wireless Ethernet Password (WEP) key
Mar 16, 2010 | Linksys 2.4 GHz 802.11b Wireless - B...
Setup problem
lost my set up disk so would not connect linksys wireless b 2.4 ghz 802.11b usb network adaptor
need to dwnload disk drive for linksys wireless b 2.4 ghz 802.11b usb network adaptor
Sep 08, 2008 | Linksys Wireless-G WUSB54GS 802.11g/b
Linksys router and Belkin wireless adaptor
Anne ,
I need to ask is the driver for wireless adaptor installed ?
Thank you ,
Styme = )
Jul 28, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
WUSB54GC cannot associate with access point
Hi ian90,
Since u r using a linksys products no need to will work..
In the right bottom corner of ur computerscreen u can see a green square box(linksys
wireless icon) right click on to the green box and click on "use windows Zero
configuration" after clicking on to that u can see a small computer with wireless waves in the right bottom corner,right click on to it click on connect to a wireless network..u can see ur SSId click to connect will prompt for a network key..enter the key and confirm the will connect for sure..hope it will work..if there is any issue just revert back as soon as possible..
Jun 28, 2008 | Linksys WUSB54GC 802.11g/b Wireless...
Linksys 1 x 4-pin Type B USB 2.0, 4 x 4-pin Type A USB 2.0 - External Instant USB 2.0 Connectivity - The E Logo
418 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
