Question about Fisher and Paykel Washing Machines
I lost a manual of washing machin . So please let me know how to get it. Model no is WL80T65CW1.
  • 973 Answers
You can go to this link and either download one or call Customer Service and have them send one to you.
http://www.fisherpaykel.com/customercare/userguide/index.cfm
Posted on Jul 12, 2010
I have a fisher pykel washing machine model WL80T65CW1 and it keeps coming up with a code 245
That is a water draining problem. From Sears: "Remove any clogs from the house drain for the washer. Remove any clogs or kinks from the washer drain hose. Unplug the washer and check the drain pump for a clog. If the drain pump is defective, replace it."
May 12, 2015 | Fisher Washing Machines
Aquasmart model WL80T65CW1
shouls not make any diffrence but i dont know you original question ?
Feb 08, 2013 | Fisher Paykel Fisher & Paykel AquaSmart...
Fisher & Paykel Washing Machine WL80T65CW1 Aquasmart - Machine keeps saying it is unbalanced.
this model is prone for the suspension rods to weaken and cause fault,fit new set of suspension rods
Nov 10, 2017 | Washing Machines
Fisher & Paykel WL80T65CW1 - Washing machine keeps saying unbalanced.
Yes the shop you bought it from. At only 12 months old the warranty should still apply.
Nov 03, 2017 | Fisher and Paykel Aquasmart wl80t65c
I have a model WL80T65CW1 aquasmart washing machine. It stopped working and showing fault 49 on screen. I do not have a manual. Would you please tell me what fault 49 is?
In AquaSmart machines the pump over-currents and blows the water valves fuse, Motor controller board and pump needs replacing.
49. (00110001) Cold Valve or Cold Valve & Hot Valve Faulty
The Motor Control Module has measured a voltage from the valve diagnostic circuit that
indicates the cold valve or both the cold and hot valve is faulty. The most likely cause is
that the valve harness has not been connected correctly or the valve(s) is open circuit.
Primary Source: Wiring.
Action: Check the valve harnesses are correctly fastened to the valves and
the motor control module or the pins are not bent backwards.
Secondary Source: Water Valves.
Action: Measure the resistance of the cold and hot valve coils.
Tertiary Source: Motor Control module.
Action: Replace the Motor Control module.
Apr 30, 2012 | Fisher and Paykel Washing Machines
Require an owners manual for L G -H950 top loader
Do you mean the LG WT-H950 top loader? LG' s Australia site had the manual for the washer on their support site: http://www.lg.com/au/laundry-floorcare-appliances/washing-machines/LG-top-loader-washing-machine-WT-H950.jsp . Click on the Support tab and the link to the PDF of the manual is on the right hand side of the page.
I hope this helps. If you have a different washing machine, please add a comment with the full model number.
Feb 28, 2012 | LG Washing Machines
Error code 49 on fisher and paykel 8kg aqua smart washing machine, model number: wl80t65cw1. What does this mean?
Hi just read your posting.Error code 49 means the computer has measured a voltage from the valve diagnostic circuit that indicates the cold valve is faulty.Would you like help in confirming that the cold valve is faulty?You need an electrical test meter.Please reply and I can guide you thru the testing procedure.Looking forward to your reply.
May 15, 2011 | Fisher and Paykel Washing Machines
Fisher & Paykel Washing Machine WL80T65CW1 Fault 9
sounds like a size error . when you changed the display did you size your machine to the new display module?did you get the re-size set of instructions with the new display board? ring up where you brought the display from and i"m sure they can help. if not reply back and i will guide you thru it.
May 26, 2010 | Washing Machines
Washing machine manual lost
do you know the model # its found usually on the rim near the lid opening.. whirlpool.com or whoever the manufacture is should have information and manuals on their website...
Apr 29, 2009 | Washing Machines
Washing Machines Logo
99 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
