Question about Cycling
How to reset the trip details without having to reset all the items?
    Problem Solver:
  • 10 Answers
Is this for a bicycle computer? What brand and model? If you do a google search of the brand and model you should be able to download a users manual. If you have problems, please reply back and I will see if I can find it for you.
Posted on Jul 14, 2010
If the circuit breaker as tripped ,how do I get it to untripp it
If the fault that caused the breaker to trip still exists, it will not reset. Unplug any devices from the circuit in question and reset the breaker. Then plug in items one at a time until you find the device that is causing the breaker to trip. Then fix or replace. You may also have a bad breaker that needs to be replaced if it will not reset even with all devices off the circuit.
Feb 08, 2016 | Electrical Supplies
Speedo trip rest button broken
dealer item.$$$$$ I would get one from a wreckers
Mar 09, 2013 | Cars & Trucks
What hygiene items do I need to take with me on my camping trip?
There aresome basic hygiene items that you should remember when packing for your campingtrip:
  • Soap/cleaneryou can use as soap/shampoo/dish cleaner
  • Toothbrush/toothpaste
  • Portabletoilet/ toilet waste bags/***** funnel (for women)
  • Toilet paper
  • Lightweightcamping towel
If you havespace, add any items that you really feel you can't live without for a fewdays.
Aug 02, 2012 | Camping, Backpacking & Hiking
Reset oil change on a 2012 kia rio
From Kia's website.
"If you would like to reset or inactivate the maintenance system press the RESET button for more than 1 second. The display will change to "Engine Oil Service Message" mode.
You can move to items by pressing the TRIP button and select the desired item by pressing the RESET button."
Jul 27, 2012 | 2012 Kia Rio LX Sedan 1.6L 4-cyl. 6-speed...
2009 TOYOTA VENZA MAINTENANCE REQUIRED LIGHT ON-WHY? CAR NEW W/ ONLY 9,000 MILES ON IT.
I finally found the solution. It is actually detailed in the owner's manual but you really have to hunt for it. Look at page 450/451.
Step 1: Switch the display to the trip meter A with the engine running.
Step 2: Turn the engine off (but don't turn the key all the way to where you can remove it from the ignition).
Step 3: While pressing the trip meter reset button, turn the key to IGNITION ON (but don't start the engine). Continue to press and hold the trip meter reset button until the trip meter displays "000000".
Jan 20, 2010 | 2009 Toyota Venza
Hello, I've got a Daewoo 5200btu window a/c that I
sounds like a direct short. Changing the plug and circuit protection may not eliminate the problem, but it would let you know for sure. I would not change that plug without ground fault interruption.
Dec 11, 2009 | Heating & Cooling
My 1300 doesnt seem to calculate trip data such as time or average speed, miles, etc. stays on zero. does show max speed.
is it set in similation mode?? try reset by holding down finger on bottom right hand corner of screen before you power up, and go to www.garmin.com for software update
Dec 01, 2009 | Garmin nuvi 1300 Car GPS Receiver
Is there a reset button on the Badger 5
Yes, on bottom a little recessed button should be pushed to reset the device. If the blade is stuck, the reset might not work but just keep tripping the breaker so you have to free up the blades with a broom stick or other item stuck into the disposal (with the power off of course) to turn the blades manually. Then try the reset button again. and hit the switch. Otherwise, check your kitchen's electrical breaker to see if it has tripped as well.
Aug 02, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Our circuit breaker just tripped and for no reason, we didn't turn on additional items. The circuit breaker now won't reset, suggestions?
This problem is due to a worn out and or faulty circut breaker. Allow breacker to cool 30minutes in "off' position then try,if the problem reoccurs without intention you will need to change that breaker out. Recommend qualified electrician. If you want me to give you step by step instructions just ask for me, jj505@bellsouth.net when you post your request.
Please rate
Apr 05, 2009 | Siemens Electrical Supplies
Cycling Logo
59 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
