My Philips flat screen, Model 42PFP5332D is distorted in color. I can see the picture, but it's distorted or snowy in color Pink. Sounds is clear and good. This happens after a few mins into turning it on when I get home.
  • krysb22 Jul 13, 2010
    I understand this is a problem problem with the scan of the screen. It is usually called "mal discharge" or "pixel misfiring". The pixels light up when they shouldn't. The best way to troubleshoot this when it works after warming up for a minute is with freeze spray. But how often would I need to spray the Freeze spray? Do I need to unscrew the back panel? Which area should I be spraying this?Is this a temporary fix? I would like a long term solution. Thank you
  • 736 Answers
When you are having a problem like that this is the repair strategy. Check these parts in this order. 1. LCD Control Unit
2. AV/Terminal Unit
3. Main Unit
4. LCD Panel (I really hope it is not the panel)
Check for damaged LVDS cable
Check all INPUTS for video
Check LCD Test Patterns in Service Mode; confirm video is ok on test patterns
Perform the appropriate factory resets
Posted on Jul 13, 2010
  • 505 Answers
This is a problem with the scan of the screen. It is usually called "mal discharge" or "pixel misfiring". The pixels light up when they shouldn't. The best way to troubleshoot this when it works after warming up for a minute is with freeze spray. You can buy this at a tech supply retailer online like www.jameco.com or similar website. The method is to turn it on with the back off, spray the boards one at a time, and see which one is causing the issue when it gets hot. Typically it would be the logic board in my experience.. if you can check it with a volt meter this can help too.. let me know how you want to proceed.. a repair at a service center would run you about $250-400. Let me know, thanks
Posted on Jul 12, 2010
  • 1 more comment
  • krysb22 Jul 12, 2010
    How often would I need to spray the Freeze spray? Do I need to unscrew the back panel? Which area should I be spraying this?
    is this a temporary fix? I would like a long term solution. Thank you
  • thielectronick
    thielectronick Jul 13, 2010
    The freeze spray method is purely for diagnosis, the TV is broken and needs some part replaced. You will have to fully disassemble the TV to do the free spray diagnosis, but it is the way a technician will narrow down your issue. That or checking the voltages to see if one goes high or low, etc... but usually it would be the logic board.
Philips model: 42PFP5332D/37 The other day it clicked and the picture went out. The blue light comes on and it stays blue with no picture or sound
Your set need a thorough check-up. Contact the authorized service centre or an experienced service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 14, 2015 | Philips 42PFP5332D 42 in. Plasma...
Picture settings
check your colour stings on tv and if you dont have a dish that is where your snow comes from
May 17, 2013 | RCA 46 46LA45RQ LCD TV
Color distortion-Sony Bravia Model KLV32EX500
check for a loose connection in the t-con board tried with re seat the cable wire in the t-con board.
Oct 04, 2012 | Televison & Video
My Philips Plamsa won't turn on, has a black screen but the power light is on. There is also a constant clicking noise. Any ideas of what this might be. The tv is a couple of years old.
The picture is White or Black:
1. Adjust picture setting such as brightness or contrast
2. Check the color settings
3. Check to ensure you cable connections are connected properly.
Jan 20, 2011 | Philips 42PFP5332D 42 in. Plasma...
Color and picture is distorted. Colors are predominately bright green, yellow and pink. Sometimes color will clear but picture is still fuzzy.
Hi
Thanks for using FixYa.
Please post a comment with the manufacturers name and model no# of the unit so that I can assist you further.
Thanks
Rylee
Sep 21, 2010 | Insignia Televison & Video
New tv
You can go into the menu and adjust the picture setting. If that does not fix the iss and the set is under a year old then it will still be in warranty. Contact Philips at 1-88- 744-5477 and have them do the repairs under warranty. Don't do it your self because that will void your warranty.
Dec 16, 2007 | Philips 42PFP5332D 42 in. Plasma...
Laptop screen flickers and color is distorted
Sounds like the CCFL is failing.. (Backlight)... Pink hue is common when these start to go out..
Dec 14, 2007 | Computers & Internet
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
