Question about Toro Garden
I need the correct way to connect the governor linkage on a toro gts recycler model 220098 with a Tecumseh 6.5 engine.
    President:
  • Toro Master
  • 1,545 Answers
This may not apply exactly to your particular model, but it is for Tecumsehs and may get you on the right track:
http://www.angelfire.com/mb2/visitme/mower/tecumseh.html
Posted on Jul 13, 2010
Our snow blower with a Tecumseh model OHSK120 snow king engine starts but runs full throttle!! Any ideas?
Stuck or bent governor, governor linkage or throttle. Try moving the throttle and see if all the linkages move with it.
Jan 25, 2017 | Tecumseh Garden
Governor linkage need to see cannot get it set
Check out CHAPTER 4 GOVERNORS AND LINKAGE it shows the different governor systems used on Tecumseh engines.
http://www.barrettsmallengine.com/manual/tecumsehlheadmanual.pdf
Feb 06, 2016 | Tecumseh Snowblower Snow Blower Starter...
Governor linkage on toro snowthrower model#38415
If I cross reference the engine correctly it is a TEC HSK 850 so the follow service manual should be what you need.
Nov 03, 2014 | Garden
I have a toro gts 6.5hp model 20017. The enginer is overreving a lot. I had changed the carburetor and believe i put the linkages correctly, however i noticed the governor arm is rotated slightly right...
The way i set the govenor is, slacken the screw on the engine govenor arm, push the arm fully over to open the throttle wide open, now turn the actual govenor shaft within the arm in the same direction, fully retighten the govenor arm screw,
Sep 29, 2013 | Toro Super Recycler Super Bagger Lawn...
I have a 10 hs tecumseh motor on a riding mower i need an explode view of carb and linkage when start-up engine it goes wide open
Hi and welcome to FixYa, I am Kelly. I understand you have a 10 HP Tecumseh engine. There are service manuals available on line for your engine but without your engine model number it is difficult to pass you the correct one: Here is the link for the service manuals:
http://www.mymowerparts.com/pdf/Tecumseh_Service_and_Repair_Manuals
Somewhere in the list is your manual.
This is my best guess without your engine model number:
http://www.mymowerparts.com/pdf/Tecumseh_Service_and_Repair_Manuals/TECUMSEH_SERVICE%20_REPAIR_MANUAL_OHH50-65_OHHSK50-130_OHV11-OHV17_OVM120_OVRM40-675_OVRM120_OVXLC120_OVXL120_OVXL125_695244A.pdf
^-Make sure you read about Adjustments in section 1 also.
Running wide open causes:
1. Broken throttle control plate spring
2. Governor spring problem
3. Internal Governor flyweight has departed the governor gear.
4. Throttle plate (butterfly) attached to the throttle shaft in the carb throat has come off the throttle shaft.
5. Broken / missing linkage
6. Someone loosened the governor shaft bolt at the base of the governor arm and allowed the governor to get out of adjstment.
Thanks for choosing FixYa,
Kelly
Aug 12, 2011 | Tecumseh Garden
Need a scamatic of how the spring and linkage mount to the motor down on the left side if your useing the mower there is a linkage attached to the motor and 1 spring and one linkage from the top of the...
If you have a Toro, then you probably have a Tecumseh and most of them I've worked on look something like this:
Truly hope this helps.
James
Jun 28, 2011 | Toro Garden
Need linkage hookup diagram for Toro Super
Go to TORO.com and view parts for your model.
May 19, 2009 | Garden
Garden Logo
1,170 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
