Question about Amana PTH123B25AJ Heat Pump Air Conditioner
Wiring Amana Heat pump to inside unit and 9520 robertshaw
Outside to what
inside to what
stat to what
Thanks
  • jball58 Apr 20, 2008
    Colors used on Heat pump
    Colors used on Inside unit
    Colors used on Thermostat
    Thanks
    J.B.
    Problem Solver:
  • 25 Answers
Colors can vary. you should be able to locate a wiring diagram inside the airhandler and out door unit. you will have to remove the panels. generally though Green is fan RED is power WHITE is reversing valve Blue is common YELLOW is the contactor (usually have to jump w and y terminals at robertshaw tstats. PLEASE DOUBLE CHECK AT SYSTEM DIAGRAMS!!
Posted on Nov 22, 2008
My(38ycc030340)carrier heat Pump ac unit blows 5 amp fuse on board in handler in attic when switch stat to heat.
Miss wired or shorted low voltage wiring. Have you changed stat? Animal chewed wires at foundation wall or in attic?
Oct 10, 2016 | Carrier Heating & Cooling
I have an amana heat pump a/c PTAC unit 14700 btu and it seems the compressor is not engaging or blowing cold air
could be a bad run capacitor or the unit needs to be cleaned take it outside and wash the condenser coil the outside coil and the evap coil on the inside be careful not to get the electric circuits inside the unit wet. I would wash the coils first and then see if it cools. Hope this helps
Aug 13, 2014 | Amana PTH123B25AJ Heat Pump Air...
Heat pump i dont know the model
The "R" terminal on the back of the stat should be 24 volt supply to the stat. For a heat pump, when the stat calls for heat, the "W" terminal goes hot (24 V) and should actuate the reversing valve and start the outside unit for heat. when the stat calls for cooling, The "Y" terminal goes hot and starts the outside unit without the reversing valve. The heat strip is used to temper the air while the outside coil is defrosting when in heating. You need an OHM meter to test for a short in the heat strip. A lot of installers are wiring it to heat all the time when in the heating mode if the heat output is too low on really cold days. Try jumping "R" to "Y" and the outside unit should start. Disconnect the heat strip from power while testing. This is really brief, its a big subject. Good luck.
Dec 13, 2013 | Water Heaters
Hello i want to conect a trane condensator 2twb0036a1000ba to a trane evaporator mww536k10raa i need a wiring diagram
Your wiring concerns may be more with the thermostat wiring connections than the condensor connections. if you look inside the cover of the evaporator unit (usually called air handler) there should be a wiring diagram glued to the panel cover. This diagram will show all 3 units (stat,cndsr, airhndlr) and the wiring needed between them. Trane and Lennox are notorious for having the most wiring between components. You also need to be sure the stat is the correct type for the system (i assume this is a heat pump system) and there can be as many as 9 wires from stat to system and 6 wires from inside to outside units. Also, the stat will have a wiring diagram with it that shows most typical system wiring including the wiring between in and out units. Your best bet (if you have no diagram on the unit or with the stat) is to call trane and have their tech division fax a diagram to you. Goodluck,Macgivor
Jan 27, 2010 | Heating & Cooling
Amana 16 seer heat pump is not heating just blowing cold air just installed in july
Than the reverseing valve is not changing over swict to emergency or aux heat. then the wireing outside needs to be checked to make sure orange goes from O @ stat to the outside. More than likely youll find the reversing valve tied together with the red outside in the wiring panal where an installer forgot to untie them...
Jan 03, 2010 | Heating & Cooling
It's cold out, and my Central Air kicks on every time my furnace kicks in. I get heat, but don't think my outside unit (fan) should be kicking in each time my furnace kicks on. Suggestions
Hi, If you have what is called a heat pump, the outdoor unit is supposed to run. It has a reversing valve which reverses the flow of refrigerant and the indoor unit becomes the condenser and the outdoor becomes the evaporator coil. Now, if you don't have a heat pump and the furnace is gas fired, then the control wiring or thermostat is calling for both to come on. Control wiring has to be touching together somewhere and bringing on both. Look over the exposed stat wire outside if you have a dog that may have chewed the wires, I have seen this happen. If all wiring looks good, then the stat is faulty and must be replaced. Make sure you don't have a heat pump first, as the fan, compressor, and all will run on heat and cooling. I hope this will solve you're problem, please let me know, I would like to hear back. Sincerely,
Shastalaker7
Nov 20, 2009 | Heating & Cooling
Thermostat wiring diagram for heat and cool unit
out door unit staying on disconnect the yellow wire for compressor if still on contactor bad points whare main line voltage is connected if unit goes off stat bad also check for weedeater damage to stat line at unit hope this helps most systems green fan yellow compressor blue common orange reversing valve white aux heat strip remove stat cover to see how unit is wired up
Jul 03, 2009 | Heating & Cooling
Goodman heat pump wiring
ok Let me see if this helps if not please comment back with the t-stat model and make as well. The Y terminal on the t-stat needs to be connected to the Y terminal on the heat pump board. If this does'nt fix it your thermostat may have something different going on so please send me the model and make of the t-stat. Also if you know does this unit have outside temperature sensing probes, and or an automatic defrost cycle?
Jul 06, 2008 | Goodman CLQ36AR49 Air Conditioner
Amana PTH123B25AJ Heat Pump Air Conditioner Logo
515 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Shehu Pro
Shehu Pro
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
