Question about Refrigerators
My Maytag side by side MSD2758DRW ice maker no longer makes ice. The arm was having trouble "pushing" the cubes out awhile back, so I disconnected the icemaker power coupling. I tried plugging it back in to do some troubleshooting, and the arm just keeps going around and around (no water or ice are in the tray). No water comes to fill the tray. The water dispenser in the door works fine. I previously had problems with the fill tube in the past, so that was the first thing I tried. I checked the fill tube to make sure it was not frozen, and even ran the blow dryer to melt anything that might have been frozen in the fill tube. In addition, it seemed that the push arm was having trouble pushing the ice out, so when I used the blow dryer on the fill tube, it also seems to have warmed up the ice tray enough so that it was able to cycle once more. However, this was months ago, and I never got it to fill again. To review: -Ice maker is not making ice. -No water is going into ice maker. -Fill tube is not clogged, I already used a blow dryer. -If ice maker is plugged in, the roatating arm of the ice MAKER (not dispenser) keeps rotating. For lack of a better term, let's call it the rotating "ice pusher" that dispenses the ice into the bin. I'm leaning towards just buying another icemaker and installing it, but wondering if the issue is with the thermostat or another part.
  • 2,272 Answers
Its a ice-maker problem.The rotating arm should stop.But still there is no ice been made this indicates that the problem is in the Thermostat as its not sensing the water temperature and the procedure is not starting at all.get the thermostat checked.If the thermostat is fine then its ice maker problem.
To test the thermostat:--
The thermostat is located near the bottom of the support box. The thermostat is connected by two or three wires. Label the wire placement before disconnecting them. Remove the thermostat by loosening the clamp, by pushing back the retainer clips, or by removing the retaining screws.
Test the thermostat for continuity using a multimeter set to the ohms setting X1. Start by testing the thermostat when it has come up to room temperature (about 20 minutes after removing it from the freezer).
If the thermostat has two wires touch one probe to each wire. You should get a reading of infinity. Chill the thermostat in the freezer for about twenty minutes and retest. This time you should get a reading of zero (continuity).
If the thermostat has three wires, number them 1, 2 and 3. Test combinations 1 & 2, 1 & 3 and 2 & 3 and write down the results. Two of the combinations should yield a reading of infinity and one should yield a reading of zero. Now chill the thermostat in the freezer for about twenty minutes and retest. The combination that had a zero reading before, should now have a reading of infinity. One of the two other combinations should now yield a zero reading.
If the thermostat fails this test, it should be replaced.
Here's how ice makers work:
First, the ice maker signals the water-fill valve to open and flow into the ice maker tray the amount of water specified by the internal motor and switch.
When the water tray thermostat senses that the tray has reached a certain temperature, it signals the ice maker to begin ejecting the cubes.
The ice maker turns on the ice cube tray heater, which warms the tray enough for the ice cubes to move freel
Then the sweep fork rotates and pushes the cubes up and out of the tray. Or, if the ice maker has a push bar instead, it pushes the cubes up and out of the tray.
While the ice maker is dumping the cubes into the holding bin, the metal wire swings up to let the cubes drop down.
When the cubes have dropped, the wire goes back down, unless the holding bin is full. If the bin is full, the wire can't go all the way back down, which turns off the ice maker until there's room in the bin for more ice.
When the wire goes all the way back down, the ice maker refills with water and repeats the process.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Jul 13, 2010
How do I get the ice maker to produce for the first time
Is the arm that gets pushed up by the ice cubes (in order to stop making ice when it is full) in the down position? it is able to be pushed up and locked so that the icemaker doesn't make at ice and may need to be pushed down.
Aug 27, 2014 | Maytag MSD2454G Side by Side Refrigerator
Ice maker make ice but not come out
Hi there! If the ice maker is making ice properly but is not pushing it through tot he bucket or to the door dispenser, it is clogged somewhere. This could be from melted ice cubes blocking the pathway or even a faulty switch arm (or auger) that pushes the ice cubes forward. Check those areas and let me know if you find anything additional or out of place. Also check for any cracks in the ice maker housing.
Mar 31, 2013 | Frigidaire FRS3R5EMB Side by Side...
KitchenAid 25in KSRJ25CNST00 icemaker trouble. The LED light on side of freezer is blinking twice with a delay and repeats same sequence. No ice is making. Any suggestions on what to look for?
Try the reset button on the control panel. If that doesn't work, then try unpluging the refrigerator.
Also, make sure that ice tray shut off arm isn't in the up position. It should be in the unlock position one notch below the off position. This arm is used by the refrigerator from over filling the ice cube holding tray. Once the ice fills the tray. The ice in the bend will push up on the arm which
initiate the ice maker to stop making ice. As soon as you start using the ice in the bend and the arm falls below the off position. The ice maker will start making ice. GB....stewbison
Sep 04, 2011 | KitchenAid Superba Architect KSCS25INSS...
NEED PROCEDURE FOR REMOVING THE ICE MAKER FOR INSPECTION AND TROUBLESHOOTING. FRIG IS NEW...ICE MAKER NOT MAKING ICE !!!!!
Are you sure you have the ice bin properly in place?
Ice bin must be locked in place for proper ice dispensing. If necessary, turn auger driver behind ice bin counterclockwise to properly align ice bin with auger driver.
• Press the switch ON to activate ice maker. Slide bin into guide rails located on either side of the enclosure. Push the ice bin in until resistance is felt. Raise the front slightly and push the ice bin completely in. An audible "click" is heard when the ice bin is located correctly.
• After freezer section reaches between 0° to 2° F (-18° to -17° C), ice maker fills with water and begins operating. You will have a complete harvest of ice
approximately every hour.
• Allow approximately 3 to 6 hours after installation to receive first harvest of ice.
• Discard ice created within the first 12 hours of operation to verify system is flushed of impurities.
• Stop ice production by pressing the ON/OFF switch located on the front of the ice maker.
• The first one or two batches will probably contain undersized and irregular cubes because of air in the supply line.
• When the ice cubes are ejected it is normal for several cubes to be joined together at the ends. They can easily be broken apart. The ice maker will
continue to make ice until the supply of ice cubes raises the ice maker arm, shutting the ice maker off.
• Certain sounds may accompany the various cycles of the ice maker. The motor may have a slight hum, the cubes will rattle as they fall into an empty storage bin and the water valve may click or "buzz" occasionally.
Jun 01, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag sidebyside MSD2758DRW ice maker won't make ice
If the ice maker no longer make ice, check the following.
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on.
On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice.
Check your door seals and thermostat, repair/replace as necessary.
Thanks
Jul 10, 2010 | Maytag Refrigerators
The Ice maker has stopped working.
There are usually 2 small solenoid valves that are used to control water. Both are generally installed at the rear close to the bottom of the fridge. One of the solenoids controls the water flow for drinks and the other is to control water flow to the ice maker. You can determine which is which by tracing the water supply tubes from the freezer compartment to the solenoid or by process of elimination. The latter method requires that you feel for movement (clicking) or heat on the water dispenser solenoid while someone starts to fill a glass with water from the fridge.
Before going any further, make sure that the ice cube detection arm in the freezer is not up. Gently push the arm down if it is. When ice cubes are ready, the ice maker turns on a small heater to break the bond of the ice cubes to the cube mold. The arm is lifted up and out of the way. Then the mechanical fingers wipe or push on the cubes to dislodge them from the ice cube mold and they fall into the container. The arm is then lowered again and rests on top of the ice collected in the container. The position of the arm when resting on the ice cubes determines whether or not any more ice cubes are made.
If the arm is hanging down, then ice cube production should be on. The problem may be either a faulty solenoid valve (mentioned above), switch in the ice maker assembly - the detection arm in particular or wiring between.
Jun 18, 2010 | Maytag MFI2568AE Side by Side French Door...
My Kenmore S106 626636 Ice Maker is not producding ice.
You probably have the back side of the I/M hitting the fill tube and pushing the white cup at the end of the I/M in some, which would put pressure on the arm and not let the arm fall down free during a cycle.
Sep 05, 2009 | Kenmore Refrigerators
Ice maker does not make ice. Arm is in proper
Pour about 1/2 cup of water into ice maker . If it dumps the cubes , then replace the water valve . If it doesn't , replace the ice maker . Also make sure thefridge coils are clean and free of dust , lint , pet hair , etc....
Aug 29, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Ice maker will not make ice cubes...it dispenses water, but no cu
two common problems are the spring comes off the feeler arm or the ice cubes jam on the sweeper the plastic arm with fingers on the edge of the ice maker
Jul 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice/water dispenser not working
Turn the water supply valve off and back on that supplys water for this unit. Then see if you have Ice cubes up in the ice maker itself ,or the arm that pushes ice out of tray is not stuck in ice .Let me know we can go from there....
Nov 12, 2007 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
Refrigerators Logo
76 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
