Question about Equipex PZ-330 Electric Single Oven
Converting aan LP oven to gas
I have found a very good deal on a jenn air oven that is perfect for my kitchen But, there is just one problem -the stove is lp and my house has natural gas. Can this oven be converted to gas? If so, is it expensive or difficult? Would it cause a problem with the efficincy of the stove?.
  • 3 Answers
IT IS BEST TO CALL A PRO but for conversations sake, it can be done. A lot of times the replacement orifices are included, hidden somewhere under the top. The pressure regulator usually has a cap that changes the pressure between Nat and LP. How difficult depends on the access to the regulator and burner orifices. ALL burner orifices have to be replaced not adjusted. LP uses much smaller orifices (hole size) than Nat (YES LP= SMALLER hole size). LP uses twice the working gas pressure as Nat.
LP is heavier and requires more pressure to push, therefore requires higher pressure. To maintain the same BTU rating for each burner, the orifice size needs to be smaller.
Therefore, going from LP to natural, the pressure has to be reduce almost in half . LP ranges use about 1/2 PSI, Nat gas use less than 1/4 PSI. THEN the orifices have to be larger. You could install the proper orifices size or if your PRO knows what he or she is doing, the orifices can be enlarged using the proper size drills and an orifice sizing chart to match the BTU rating of each burner. You could have 5 different size burners that will need 5 different size orifices.
Improper orifice sizing and pressure could result in an under-gassed or over-gassed condition that could lead into CO poisoning or gas leakage.
Posted on Sep 23, 2015
    Novelist:
  • 161 Answers
In most cases the pressure regulator has to be changed or adjusted. The orfices on each burner, oven, broiler and surface burner may need to be changed also. Sometimes they can be adjusted. Sometimes the threads on the pipe are different also. This is to prevent accidental connection to the wrong fuel. The big difference is the gas pressure. LP is usually around 10 - 12 lbs and natural gas is usually around 3 lbs. Properly adjusted you will like natural gas much better than LP as it is slightly hotter. The information will be in the instruction book and also on the Jenn air web site. Whirlpool owns both Maytag and Jenn aire so check all sites. The conversion kit is usually less than $50.
Posted on Jul 15, 2008
  • Ludog Sep 23, 2015
    10-12 lbs for LP and 3 lbs for natural gas??? What kind of ovens use that much gas pressure? Are we talking crematorium ovens or kitchen ovens?
Convert LP Lincoln oven Impinger II series 1700 to natural gas series 1600
Yes. You need a set of natural gas orifices to replace the LP ones on the oven and all the burners too.
Jan 28, 2014 | Ovens
Convert to lp gas
You will need the owner's manual to follow their LP conversion instructions. You will need the make, model and serial # in order to buy the LP conversion kit (if needed) from a local appliance parts store or from the store where you bought the appliance. Typically, you will be either adjusting (turning down) or exchanging the main burner orifice(s), as well as adjusting the air shutter on the burner venturi tube, as needed for a bluer flame. The appliance regulator will need to be converted, which is usually done by flipping the cap. If you don't have your owner's manual, leave another comment for me with the model # and I'll see if I can find it online for you. I have not worked on this particular type of oven in my neck of the woods, but ovens are all pretty similar in design. Some also have a thermostat that needs to be converted by turning the Nat to LP selector behind the temp dial. Hope that helps. Douglas
Jul 20, 2010 | Imperial ICV-1-H Turbo-Flow Electric...
Recently purchased Frig. gas stove.Want to convert from natural gas to Lp.Do you remove spud and insert Lp oriface in spud then screw spud back onto line?Lp oriface is a lot smaller than oriface for...
Not really sure which model you have but when converting the over, ether bake or broil burner you tighten down the orfice cap. If you remove the burner off the oven valve you will notice that you can put a wrench on the orfice cap. Just tighten snuggly. If you over tighten you will crush the orfice under the cap.
Dec 22, 2009 | Frigidaire Ovens
My Jenn-air oven won't turn on. It's model number
My Jenn Air 1995 wall oven was working fine until one day the oven and the oven gas burner did not turn ON. I had electricty (make sure you did not trip a breaker) since my front panel LCD and clock was OK. I had a good gas supply.
My oven is an "pilot-less" oven, it uses an electric igniter. Although the "ignitor" was "glowing red hot", the problem is that the gas valve depend on a certain amount of current. If you have a 120V house system, I think the valve needs 3.3 to 3.6 amps to turn on. The current flows through the igniter and then through the valve, as in a same path, like water. So you need an AMP meter to check proper current flow. I read 2.4 amps. I replaced the "glowing red hot" igniter with a new one, Vo"la it was fixed.
Bottom line if you have the oven plugged in OK and you see some life (clock), and you have the gas turned on, most likely the igniter is bad. Second choice would be the oven's thermostat (the temp knob that you turn, say to 350F), or it could be the gas valve.
All three are in same current circuit. The igniter gets the most abuse so I would start there first -good luck!
Sep 24, 2009 | Jenn-Air Ovens
I have a jenn air cook stove that was used with propane. I would like to know how to convert it to natural gas
You will need a conversion kit. The kit should be about twenty dollare, and it will explain exactly what to do. if you have any questions get back. You need a Jenn Air kit so go to any Jenn air dealer to get it.
Jul 07, 2009 | Jenn-Air JGW8130DD Gas Single Oven
Jenn-air w156, displays f1 fault code. how do i
This is a Defective touch pad or membrane
Replace touch pad or membrane (this problem is usually the touch pad)
Jun 17, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
GE PGB975SEMSS Broiler and Oven flames too large and yellow
It sounds like your not getting enough air mixed in with the gas.if you can't adjust for more air make sure you were not supposed to change the spuds that feed the gas on the lower units.
Mar 16, 2009 | Ovens
Upper & Lower Broiler Flame Adjustment
MY KENMORE OVEN BURNER FLAME IS TO HIGH AND IT WILL NOT TURN LOW
Jul 16, 2008 | Ovens
Equipex PZ-330 Electric Single Oven Logo
201 people viewed this question
Top Equipex Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Equipex Oven Expert? Answer questions, earn points and help others
