Question about Friedrich QuietMaster SM18J30BR Air Conditioner
There is water leaking from the front of the unit and also sometimes it is coming out of the vent when the ac is running. how can i fix this problem? the unit is a friedrich sm18j30r it is thru the wall , it has been fine for the last 5 yrs, it started to leak recently.
  • shock68 Jul 14, 2010
    thank you for the help it was exactly right
    Brigadier General:
  • 4,044 Answers
Make sure it is leaning just slightly to the rear and that the drain paths are clear. The water you are seeing is condensation from the cooling. You can also reduce this some by making sure you clean the filter every other day or weekly instead of monthly. The water should be draining out of the back of the AC on the outside.
Posted on Jul 12, 2010
  • shock68 Jul 12, 2010
    do i have to remove the unit from the sleeve to clean the drain paths?
  • James Young Jul 12, 2010
    That will depends on what kind of access you have to the rear of the unit. Sometimes you can clean the paths with a garden hose and a sprayer attachment and spraying the trash out of the unit. Sometimes you have to remove them from the sleeve. You have to kind of play that by ear and adjust to what you see when you start cleaning them. sometimes it helps to go ahead and remove the front plastic panel on the unit so you can clean the coils out while your doing it. This can be done easily with a Dog Flea Brush with all the very thin wires in it. The biggest thing is make sure it tilts just slightly to the rear.
2006 Tiffin Phaeton water leak by refrigerator
If you have been in a cold climate, there may be a possibility the water pump has frozen up and cracked. Open the lower vent cover outside for the fridge (about 14"x18") with a few long horizontal air vents in the middle. Use a coin to rotate the tabs from the two upper corner and remove cover. Locate the water line coming into the pump. If you see water in the immediate area, it may be leaking but dry the area up and have someone inside help you by filing a cup with water from the dispenser on the fridge door. If it has cracked, you will see the water start running out. It will also less when the ice maker is filling the tray. These units are plastic and cannot be fixed do you need to get it replaced. Before trying to remove the pump to take it to an RV dealer, make sure you turn off the water supply to the fridge. Most units will have a valve connected by a "T" at the cold water supply going to the kitchen sink
Mar 29, 2014 | Tiffin Motorhomes RVs
AC vents not working
Does this vehicle have one AC unit in the front or two units one in the back and one in the front ?,if two units then the gas content is low as a two unit vehicle should hold at least 1.5 kgs if this drops over time due to leaks then only the front unit will work
May 30, 2013 | 2005 Honda Odyssey
My Ruud ac is not cooling
Have you replaced your relay capacitor?
Sep 03, 2012 | Ruud Heating & Cooling
Water coming out of front of unit, thru vents leaking on floor
Darlene, if this is a window or thru the wall unit, the leaking is usually caused by two things:
1. The drain pan under the unit has a drain hole (in the rear outside part of the unit) that is clogged.
2. The AC unit is not tilted down at the rear 1/4" to 1/2", so that water will drain to the outside drain hole.
Be prudent when you look for the drain hole in the drain pan. As the clog can blend in with the drain hole, making it difficult to see.
Hope this helped you troubleshoot and solve the problem.
Jul 18, 2011 | Haier Heating & Cooling
I have a Amcoraire that leak water during running AC
blow in to the drain from outside also check and make sure the filters are clean
Jun 07, 2010 | AmcorAire UCHW-H24AF2 Split System Air...
AC not cooling during the day
Your AC cooling efficiency is low when he ambient temperature is high and naturally it cools well when the outside temperature drops.
Please remove the filter on the grill and try to clean it under the tap water and after removing all the dust fix it back to the unit. This would increase the cooling efficiency of the unit.
Your AC is also five years old. Please avoid frequent opening of doors or windows.
Ensure that the exhaust fan and the blower of your unit are functioning normal.
The technician might not have done a proper job in fixing the area where the refrigerant would have leaked out. Please check the refrigerant pressure to ensure that no further refrigerant leak has taken place. Or even servicing your unit he would have punchered the tubes resulting in very slow leak of refrigerant resulting in no cooling or less cooling. It takes around a month to feel the pinch of it and the refrigerant. One fine morning after sometime the unit will run and it would start throwing hot air instead of cool breeze!
Jul 13, 2009 | Heating & Cooling
Friedrich AC through the wall ac leaking water out front vent
pull it out and check for packaging left in ac unit, and make sure drain is clear and large enough for water flow ,,,go ahead and tilt ac unit more and see if that doesnt do the trick
Jul 04, 2009 | Friedrich CP12C10 Wall/Window Air...
I have an amana ac unit that is leaking water out of a hole that is right beside the drain pipe. i cleaned the drain pan out and made sure the drain pipe was cleared out.water starts coming out when the ac...
check filter or coil plugged if drain is clean or there is no vent so the fan holds the water while running then when fan shuts off it lets it go
Jun 21, 2009 | Heating & Cooling
Leaking water from ptc ac unit in front .vents all open
make sure unit is has slight fall toward outside.
Jun 15, 2009 | APC Heating & Cooling
Mothers AC unit
That has nothing to do with the water. Sounds to me like it needs cleanning, (the water is not drainning toward the back of the unit) ,,(dirty filter, which its trying to **** air anywhere it can even thru the drain hole, or not enough slope, leanning toward the back so gravity can flow the water to the back of the coil! Thank you-very-much!
Aug 28, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Friedrich QuietMaster SM18J30BR Air Conditioner Logo
215 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Michael Vincent Cruz
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
