Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Ice maker stopped making ice, water is going into the small part on the bottom but no water is getting into the plastic hose. is that connection to a small pump?
  • GE Master
  • 43,501 Answers
Pull the line off at the icemaker and check for a filter at the inlet...often stuff builds up there and stops off the water...
Here are some basic tips for ice maker troubleshootingice maker stopped making ice, water is going into - 2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Posted on Jul 13, 2010
No water no ice
Change the=> 67006531 Water Inlet Valve I believe the side of your 67006531 Water Inlet Valve that controls water flow to the ice maker has weakened and cannot open properly. Replace the water valves and I believe the ice maker will work fine, Sea Breeze
Jun 07, 2012 | Whirlpool GX5FHTXVA Bottom Freezer French...
My ice maker quit making ice on my amana bottom freezer
Hi, If your ice maker has stopped making ice then you need to check these things.
The lever that controls the ice maker has been pushed up which turns it off. If you have a red lever, pull it down to the wire and if you just have a wire then just pull down the wire to start your ice maker up.
Make sure the freezer temperature is below 10 degrees F If the freezer is too warm ice production will be poor because the ice maker will not cycle properly.
The ice maker fill tube may have ice formed in it, blocking it. Use a hair dryer to melt the ice. Watch out for the plastic parts, so that you do not melt the plastic. Also check the water inlet valve and the shut off valve, to make sure it is not plugged with debris. The openings in those valves are very small.
Check the gears in the ice makers to see if they are broken or stripped. Also look to see if the ice rake is broken. All parts in the ice maker are replaceable individually, If you find broken parts replace them.
Take care
Jul 23, 2010 | Amana ABB1927DE Bottom Freezer...
Refrigerator does not produce ice or water. Kenmore Elite Refrigerator Model Number: 795-775-69600
If you have both ice and water stopping you have a water supply issue.
Water enters under city pressure through an eighth inch supply line.
Start simple and work from there.
If the fridge was moved the line can get kinked. Slide the fridge out and check you have water to it. You can loosen the supply line connection just a little and you should see water leaking. If not it is a plumbing issue in the house. Most likely a the supply line is kinked or possibly someone closed the shutoff valve to the fridge.
OK so we have water to the fridge.
Water comes in and connects to a water filter and then to the door.
If the filter is badly clogged it can cause low pressure to the door and that would cause the problem. Check the filter.
If no go still then check where the water is stopping.
Remove the from cover from under the unit. That is the plastic grate at the bottom of the fridge. It will just pull off but be gentle and take your time so as not to break anything.
Water supply will run through a clear plastic hose. It runs to the filter then to the bottom of the freezer door and up through the door.
You can sometimes see where the water has stopped and clear or replace parts as needed.
There is a connection just before entering the door from the filter. You can loosen that to see if you have water to that point.
If you have water past the filter the problem is in the ice maker and water supply inside the freezer door. Water can leak here, expand, and crack plastic parts easily.
If there is water to the door then you need to dig into that. This gets a little more complex to describe but in short take the ice maker out and check for water supply or broken parts. The problem is probably before the ice maker as your water in the door is not working. This indicates it is not just the ice maker.
Hope this helps.
Mar 12, 2010 | Kenmore Refrigerators
The ice maker does not make ice anymore
There's no ice If your ice maker has stopped producing ice completely, check these, in this order: It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly. The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
thanks.
Aug 27, 2009 | Whirlpool Refrigerators
Ice maker stop making ice, water is still coming our of water spo
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
  • Thanks! mannu_rakesh
Aug 24, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker is not making ice
hello. i can help.
Small or too few ice cubes If the ice maker is producing ice poorly--making small cubes or too few cubes--you probably have a clogged water line, a defective water-inlet valve, or a defective ice maker mold thermostat that isn't cycling properly.
Jun 25, 2009 | Sub-Zero 245
Icemaker does not make ice. Appears no water is getting to maker.
May 20, 2009 | Refrigerators
Leaking water on floor only happens when making ice
I wonder if you just notice the noise now because the leak has you more aware? First things first. Lift up the arm on the ice maker (a few hours prior to attempting service) to stop it's operation. You need to roll the unit forward to give you access to the back. You'll see a plastic tube that runs from the bottom compartment (water valve) to the ice maker fill tube. Lower the arm of the ice maker and observe the plastic tube for the location of the leak. The most likely spot would be at the top. A hose clamp can be put on the fill tube after making sure the plastic supply tube is completely inserted into the fill tube. The fill tube is the piece that goes through the rear bulkhead and delivers the water to the icemaker. It may be neccessary to remove the icemaker to thaw out the fill tube using a hair dryer.
Apr 28, 2009 | Refrigerators
Ice maker will not work
Small or too few ice cubes If the ice maker is producing ice poorly--making small cubes or too few cubes--you probably have a clogged water line, a defective water-inlet valve, or a defective ice maker mold thermostat that isn't cycling properly. Check these:
  • The water line that's attached to the back of the refrigerator. Make sure you have good water flow. If the flow is poor, repair, clean, or replace the tubing or the shut-off valve that supplies the water.
  • The water-inlet valve. Replace it if it has failed.
  • Check the freezer temperature. If should be 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker mold thermostat. Make sure that it's cycling properly.
Specks in the cubes If you find black or gray specks in your ice cubes, have a look at the ice cube tray. If the protective coating is peeling away, the most economical solution is to completely replace the ice maker.
Apr 01, 2009 | Frigidaire Optional Icemaker Kit
Ice maker is dripping into ice bin after water refills?
I had this problem on my refrigerator. I talked to a service tech at the local appliance dealer and here's what he said. There is a valve at the back of the refrigerator (mine is a side by side, but the basics are the same When the Ice maker goes thru it cycle, a part of that cycle is to turn on the water to fill the ice tray, then the next portion of that cycle is to turn off the water. What is happening is that the valve is getting the signal to close but due to mineral build up on the valve surface it is not able to completely shut off.
The solution is to replace the valve. This is not difficult. Turn off the water to the refrig. It's usually runs under the cabinets to the sink and you can see a plastic hose under there with a small handle you can turn to shut it off. Pull the refrig out so you can get to the back and you will see the valve. It will be connected to the same hose that is under the sink Remove and replace the valve. make sure all the little hose fittings are tight. Turn on the water under the sink and check for leaks.
Hope this helps PS you can get a new valve at most any appliance dealer.
Good luck Loringh
Oct 24, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Refrigerators Logo
129 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
