Question about IBM ThinkPad T40 2373 Notebook
Issue with HDD
When I switch on the laptop, all indicators except hard drive indicator are on, usually I hear the HDD rattling... and I am not hearing that sound too... System not boots up.
    Brigadier General:
  • 4,044 Answers
Sounds like the Hard Drive crashed. Remove the HD and test it in another computer to be sure.
Posted on Jul 12, 2010
Rattling loud noise when plugging on & off adapter please help its annoying
A rattling noise can only be from one of three sources, two of them are mechanical. The first is the hard drive. If the hard drive is making clacking noises, it is usually soon going to fail. Now is the time to retrieve and save off any important files that you don't want to lose. The second would be the CD/DVD drive - but unless there is a disc installed they usually are dormant. The third could be from the sound card. This would be highly unlikely and indicative of a problem on the mainboard. I would lean toward the hard drive as the most likely candidate.
Dec 10, 2015 | Computers & Internet
Rattle noise
i dont think the hard drive is fixable at this point.the rattle noise you hear is usually the last indicator that your hard drive is going to crash for good. I have had the same problem with a couple of hard drives. the first time I lost everything. the second time I started hearing that noise from a hard drive ,I jumped into action and copied all I could before it finally quit for good. live and learn.
May 20, 2014 | Fujitsu Computers & Internet
My acer laptop does not display but it runs.what is the problem?
Shari,
There are many things we can try to find out why this is. To start, When the computer boots, Do you hear the windows chime? this will indicate the laptop boots. otherwise we could be looking at other hardware.
With the laptop turned on, if you hold a flashlight to the LCD you may be able to see faint images. This would indicate an issue with the LCD or the Inverter located in the laptop and you should have it serviced by a professional to repair such items.
Also while booting the laptop we want to watch all the lights on the laptop. Occasionally when a hardware item fails we identify it with a bios Beep code. In laptops this is a flashing light that will blink either by the AC plug, Right under the LCD, or the front of the laptop.
When we start the laptop does the fan spin up very hard and then slow down again? do we hear a beep shortly after? This indicates what we call "A post" it means your processor, Video, and Ram all passed intitial tests to start your computer. If there is no beep dont panic as not all laptops do this. The fan however, if it does not slow down will indicate a hardware issue. This typically can be CPU, RAM, or Motherbord.
When your computer boots, does the screen stay completely black or does it boot past a splash screen and go to a flashing curser? This could indicate a hard drive issue. Usually repairable unless we hear clicking from somewhere in the device.
The last thing I would suggest trying is if you have a regular computer with a regular monitor, you can plug the monitor into the side of your laptop to see if the screen comes up on it. There may be a keyboard shortcut you have to press and if you let me know what model Acer laptop I may be able to help you with that as well.
Good Luck!
-Rogue
Jan 01, 2014 | Computers & Internet
I am having Seagate Free Agent Go Flex and its not running on the computer just making sound errors.
Hello abhi_1998s,
This usually indicates a bad hard drive. If you are hearing grinding and its not connecting to your computer, check your warranty. If you're hearing it connect to the machine then disconnect, try a different cable. If this does not work, contact the manufacturer's technical support because it could be a known issue.
If you need to recover data from the drive please halt from any further use of the drive. Hearing grinding noises is a very serious issue if you're going to attempt data recovery.
Hope this helps!
Jun 29, 2011 | Computers & Internet
Hi, I have a Toshiba 80GB MK8037GSX 2.5" SATA in
1) have checked bios cannot see hdd mounted.
That is BAD -- the disk-drive could have "died".
2) tried a seagate hdd works fine so connections in laptop seem to be working
That shows that your motherboard is GOOD, but that your disk-drive is BAD.
3) can hear hardrive trying to do something as can hear harddrive usual noise, continous noise for about 5 sec before getting the error message
That is BAD -- the disk-drive is "dying".
4) no rattling or crackling noise from drive apart from the above
That is BAD -- none of the files can be read from your disk.
i have created a ubuntu boot up disk which allows me to access laptop but does shows error when locating hdd,
That is BAD.
once in ubuntu i can access internet but it does not show the windows partition of the harddrive, only shows ubuntu as opearing system, confused.
That is BAD. Only the CD/DVD disk has been mounted -- Ubuntu could not mount the disk-drive.
In regards to ubuntu working does this mean the hdd is ok?
No, it means that your motherboard is working.
and is there anyhting i can try via ubuntu to locate the files?
No. The disk-drive is "dead".
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 13, 2010 | Toshiba 80GB MK8037GSX 2.5" SATA II SATA...
Inspiron 1545,loaded with windows7.error 2000-0146 arises,indicating hard drive error.five times a heavy rattling sound also arised from dvd reader/writer(optic) device and then no other right...
Yes, the drive electronics are failing the self-test - and yes, have the dealer replace the drive and don't take no for an answer.
Hope this helps. Sorry you had some bad luck.
Nov 04, 2010 | Dell Inspiron 1525 Notebook
Cannot format hard drive on my T40. How can I tell
Depends on what kinda format u doing..if it's thru the XP Disk ..if it is stuck at certain stage for too long and can hear rattle sound near the HDD ...it's mostly HDD error..Try dos format using dos bootable...or i would try installing Windows NT old version and upgrade..it helps huge some times..hope this is help full..good luck..cheers
Dec 14, 2009 | IBM ThinkPad T40 2373 Notebook
95 4Runner, hearing a rattling sound underneath, from drive train perhaps (do not think it is trainie, drive rod or rear gear box?), sound occurs during drive acceleration or braking -- indicating loose...
rattling when doing what? if it rattles when it is running or when it is driving, this will tell you roughly where to look. If rattling while idling, coming from engine or transmission. If you ONLY hear it when you are driving, check you U joint. they can wear out and start to rattle and clunk sometimes, especially when going in and out of gear...reverse to drive etc...
Jul 23, 2009 | 1995 Toyota 4Runner
IBM ThinkPad T40 2373 Notebook Logo
178 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
