Question about Garmin Nuvi 760 Car GPS Receiver
Garmin nuvi 760
Car charger 12 volt light is green, the other light come's on red then starts to flash amber twice over and over
    Top Expert:
  • Garmin Master
  • 83,772 Answers
What is the GPS doing, sounds like you need to replace the battery based on the symptom
Posted on Jul 12, 2010
Battery low signal, then shuts off.
Make sure the car charger and adapter is working (has power), is the Green light on? If not, use a 12 volt test light available from any auto parts store for about $4.00 and check to see that the lighter outlet is hot, the light should light up when you probe the centwer of the lighter socket. If the lighter is ok then replace the car charger for the GPS about $50.00 from Ebay.
Please rate my help for Fixya, it helps to improve my standing on the site. Thanks
Jan 17, 2012 | Garmin Nuvi 760 Car GPS Receiver
I have a Garmin Nuvi 755T. I noticed that the unit was not charging via the car charger. I checked the charger and noticed that the green light was on. I also pulled the fuse and checked it and it is...
found female jack on the 755 mount where the car charger pluges into the GPS was not securely soldered onto ckt bd so after multiple times pulg in or unpluging the unit or just stressing the connection the fine wire conncetions (about 12) tend to break forcing the unit to operate on battery mode untill battery is discharged. you an purchase a replacement GPCCradle Holder compatible with Garmin Nuvi on Amazon GPS Cradle Holder Compatible with Garmin Nuvi for about $20
Aug 26, 2011 | Garmin nuvi 755T Car GPS Receiver
The charger/traffic receiver glows green but it does not charge the unit. How can i test whether the fault is a, the charger, b the cradle or c, the unit
hi,
1st of all let me say im on my 3 cradle now for my 760 because the connection inside the cradle where it mounts to the board is pretty poor.
since you said the traffic/charger has the green light lite, that means the charging part of it is working.
you can verify if its the cradle or the connection on the bottom of the gps where the cradle mounts by using the usb cable supplied with your garmin.
plug it in for a while, then check the battery meter after you unplug it..if its charging, the meter would have risen beyond what it was before you tried to charge it. the same can be done with a regular garmin charger (the one that uses the usb connection for the car charger to charge it)
bill
Apr 12, 2010 | Garmin (010-00583-00) for nuvi 750/760/770
Cannot recharge using car recharger - no red light showing on charger plug in. Do not seem to have been supplied with a mains adaptor. Help Thanks Paul
Check the fuse in the car charger by unscrewing the tip - the red light should be on whenever it is supplied with power. Otherwise check your vehicle fuse to the 12 volt outlet (or try another device in the outlet).
Nov 04, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin won't come on
plug it in to the wall charger or car charger for about 4 hours, then slide and hold power button for up to 15 seconds till it starts.
if that fails, unplug the nuvi then press and hold the lower right hand corner of the screen until you see the message " Do you really want to erase all user data?" remove your finger from the screen and select YES. (this will erase all your saved data) this should reset your nuvi to the factory settings.
use the web updater to update your nuvi once you get it started again.
you can get it HERE
let me know if you need further help.
bill
Sep 05, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Where do i plug in my 120v charger on my garmin nuvi 760 gps
Hi I have this model too. You must have the 120v charger with the Mini-B  port on it. It plugs into that port on the bottom(PS3 controllers cameras, and other Computer devices often have a mini-B USB
Apr 04, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
No power
Slide the power key to the left 10 seconds.
Update at Garmin.com/webupdater
Jack to Computer and run.
your Software/data is safe.
check fuse in the end of the adapter
Regards.
Sep 02, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin Nuvi 760  Car GPS Receiver Logo
260 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
