Question about Samsung T220HD LCD Monitor
I cannot see display in my screen it is full black
  • 50 Answers
Disconnect the power and VGA cable from the comp. and monitor and wait for 2 minutes
Press and hold down the POWER button on the monitor for 1 minutes and then connect everything directly.
It shold work if the CRT gun of the mnitor is OK otherwise u may hv 2 install drivers.
Posted on Jul 12, 2010
  • 69 Answers
1/. Remove the LCD housing
2/. Remove e Main Power supply (label the 4 connectors for the 4 lamps before you unplug them)
3/. Locate the 1000uf-25v Cap (i think c806) check the top of the cap, if the top is buble up then replace it. I replaced my with 1000uf-35V 105 C, use the cap with long leads, solder it to the PCB and lay the cap down away from the heat sink (there should be plenty of room)
4/ check all solder joins, if it look like cold joins simply re-solder it
5/ when you are done, you can apply power to the board and check for the voltage at the cap, it should read about 14.7VDC
6/. Re-install every thing and it should be good to use again
Please post your feedback and Vote if the problem resovled as per your satisfaction.
If the converter goes out does the tv not do anything no screen light uponly red standby light?
if your question is that if cable or sat converter goes off for any reason , will your tv display a black screen , then the answer is yes , without an input most all tv sets will display the opposite of full white , this being full black , also any on screen displays might not work as well (no video to sync too)
Jan 10, 2017 | Televison & Video
No display
HOLD D BUTTON ON KEYBOARD AND POWER ON THE LAPTOP
IF YOU GET COLOUR FULL SCREENS NO PROBLEM IN SCREEN
IF NO COLOURS DISPLAYED PROBLEM WITH SCREEN
Jan 10, 2013 | Dell Inspiron N5010 Black
On starting my screen is getting black on right side of the screen!!not full screen is getting black on few cm 's are getting black!!nd m unable to any thing!!tell me what to do!!i have lenovo g55
From your description you have a display issue, you can hook a monitor to the video output to rule out the video graphics chip, if okay! the LCD screen on the laptop will need to be replaced, you can check prices at www.ebay.com type make and model of laptop, refine search to screen.
Jun 23, 2012 | Lenovo Computers & Internet
Screen savers
Go to Control Panel choose Display Properties go to Desktop tab there is a selection from Position: center, stretch, tile choose the stretch then apply and ok, your picture will displayed in full screen in your desktop
Nov 09, 2009 | Computers & Internet
LCD monitor have Vertical lines and black colour become greenish
normally the 19" resolution can support up to 1280*1024, but if it comes with vertical lines in full screen, it might indicate the panel is no longer to work and probably it's time to replace new one.
Aug 12, 2009 | Neovo S 19 19 in. Flat Panel LCD Monitor
If we close the screen a little bit it goes bright white. Have to switch off and restart. Also, after doing a power point presentation the display is only opening about 80% of full screen with a black...
In LCD screens is a common problem that after setting a lower resolution than recommended you'll see a black stripe sometimes up and right, right click on any empty spot on your desktop and select properties then go to display options and move the resolution bar to a higher point and click apply also click yes in the warning display and accept.
Regards.
Jun 15, 2009 | ASUS A6Ne Notebook
Picture display format doen't fit 32'' screen
if you have cable box or a sattelite change the resolution of the STB to 4.3
Feb 06, 2009 | Sanyo DP32746 32 in. LCD Television
Full screen on monitor
you can use the menu and adjust the vertical size.or if did already but it doesn't work,try to open your monitor and look for a trimmer in the vertical section,then try to rotate by these you can adjust now the vertical size
Oct 18, 2007 | HP Compaq FS7600 17" CRT Monitor
Samsung T220HD LCD Monitor Logo
616 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
ismael castillo
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
