Question about LG DLE7177 Dryer
Dle7177wm filter light on dryer will not start
    Problem Solver:
  • 12 Answers
The filter component is located directly inside, bottom, behind the door. Looking at it from the inside, you will see 4 screws. Two will be close to one another remaining two, one on each side. Before you remove the screws make sure you have removed the lint slide that sits in the filter housing
Carefully with not too much force the filter housing should come off in 3 parts. The smallest and most lover peace will have 2 metal strips running flat parallel to each other on the plastic housing which is attached to a white connecter, carefully remove it from the connecter, remove all pieces out of the drum, clean thoroughly, vacuum cleaner will work great, however you will need a sharp and narrow instrument like a small thin screw driver to pull out dried up lint from small areas.
Once completed put back the connecter, put all parts into place screw back don’t use force if screws are tight, undo the screw, and slightly move the parts to make sure the screws tighten in place.
Make sure you have a general idea how to put parts back in place as you remove them.
Posted on Aug 09, 2010
Where is the reset button?
There is no reset button, the issue is most likely a heating element
Feb 02, 2015 | LG DLE7177WM 7.3 Cu. Ft. Electric Dryer -...
Will the Check Filter light being on prevent the dryer from starting?
need to check the filter relay
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tom_db3a51ff0ca57f20
May 20, 2014 | Dryers
Filter light is on. I pull filter - its clean. I put filter back in - filter light goes out. I start dryer. It runs for about 5 seconds and stops
Did anyone come up with a solution to the problem, we are having the same problem, except our dryer keeps running, the filter light goes out, and when the dryer is turn back on the filter light is back on, the filter is clean.
Oct 22, 2010 | Kenmore Elite HE4 Electric Dryer
DLE7177WM - Seems to work ok, but it is taking
Its going to be an issue with the wall vent of your house. The dryer is not venting the air at a good enough volume and that is why it is taking longer to dry. Sometime you may have to run a second cycle and I bet there is lint on your door gasket around the 6 o'clock positon.
The flex vent behind the dryer, the wall vent, and or the vent's outlet (roof or wall) outside the home needs to be cleaned to improve the air flow.
Good Luck.
Jul 04, 2010 | LG Dryers
Check filter light remains power light blinking
Hi friend,,,
welcome to fixya
try to unplug it for 30 minutes this should reset the control board. and clear any errors it has. and may start working again. let me know how it goes OR
try this to get it in diagnostic test mode have the dryer in standby mode then press and hold more time and less time and then press the power button to get out of this mode you will have to unplug the unit for at least 1 minute
if your satisfied with my solution PLEASE RATE IT
thank u...
Apr 09, 2010 | Dryers
I have a LG DLE7177WM dryer that doesn't completely dry the clothes while using the sensor dry cycle. I have had it for just over 2 years and my wife said this hasn't been working correctly for a bout 6...
What I would do is check for air restrictions inside and out. Clean the dryer good and then check the thermister for proper tolerances using this service pamphlet
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 06, 2010 | Dryers
Dryer does not heat up/ dry clothes
sound like heater or stat call them out.
Sep 28, 2009 | LG DLE7177 Dryer
LG DLE7177WM began making loud RuMbLiNg sound.
I have the same problem; pulled it apart and discovered the drum was cracked at the seam where it was welded. the noise occurs as it passes over the wheels the drum rests on. called LG's Cusomer Diservice and nobody was interested. found the same problems by others while searching myself so its clearly a manufacturing problem.
Jan 24, 2009 | LG DLE7177 Dryer
LG clothes dryer (DLE7177WM) signals completion of cycle when clothes are still damp. This even occurs when 'Very Dry' option is selected, which seems to now be required.
Hi thanks for the question The easiest thing to check is the venting make sure the dryer is far enough from the wall so the vent wont kink check and see the air going outside is not restricted in any way . dirty vents can also cause fires especially in gas dryers thanks for the question the appliance doc
Sep 12, 2008 | LG Dryers
LG DLE7177 Dryer Logo
135 people viewed this question
Top LG Dryers Experts
Tim Whalen
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
