Question about Frigidaire ATF6000ES Front Load Washer
Replace door seal - Frigidaire ATF6000ES Front Load Washer
    President:
  • 2,702 Answers
Its not to easy to do but,,,
look at the bottom of the washer were the door closes the seal is held on with a spring wire,,unhook this wire and fold the seal inside the washer,,look for the inner drum there is another spring wire holding the inner part of the seal to the inner drum undo this as well,, pull old seal out through the door hole,,,now fold new seal so that the inner wire can be fitted round the new seal first to the inner drum,,then pull the new seal through the door hole and fit the outer wire to seal,,,
and then job a good un?,,, not easy a,,well i did tell you this!
Posted on Jul 12, 2010
How do I replace the front door rubber gasket and seal ring?
Greg, new seal but need to know how to swap it out. Check the attached links,instruction and guides, If you want to google your make and model Washing Machine door seal replacement. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Replace Washing Machine Door Seal
How to replace washing machine door seal on Hotpoint washer
http://www.how-to-repair.com/help/how-to-replace-whirlpool-washing-machine-door-seal
How To Replace Front Load Washer Door Boot DIY
Jul 25, 2016 | Washing Machines
Lg p/no 3850dd3006a leaks at door
Every dishwasher door has a door seal. If the dishwasher is leaking water, it might be that the door seal is defective or worn out. Try closing the dishwasher door on a sheet of paper and see if the door seal is making good contact all the way around the door. If not, replace the door seal. If the door seal is good or has been replaced and there is still a leak check the door hinges. If the hinges are bent the door will not close properly and the hinges will need to be replaced
Jun 19, 2014 | LG Dishwashers
How do I replace the metal retainer ring arond the rubber door seal of beko washing machine
This video will show you in detail how to replace the door seal gasket and fit the new one properly to Beko washing machine How to Replace Beko washing Machine Door Seal
Jan 25, 2013 | Beko Genuine Washing Machine Door Gasket...
GE French Door PFS22MIS Door seals are torn at top of both doors. How difficult to replace?
use your model # to order new seals. they are easy to replace. Just grab an edge with your fingers and pull and the door seals will pull out of the groove they are in. to replace, start at the bottom center of each door pressing the seal into the groove. don't stretch the seal as you replace and it will fit perfectly.
Nov 29, 2010 | GE GBS22HCP Bottom Freezer Refrigerator
Changing a door seal how do you replace the door seal ?
  1. Check the door seal size. Measure your door or doors, and take down the make and model number. Ads by Google
    '; for(i = 0; i '+ '' + google_ads[i].line1 + ' ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
    ' + '' + google_ads[i].visible_url + ''; } s += ""; document.write(s); return; } google_ad_channel = '+7733764704+1640266093+5860073694+9911500640+9665908481+9016233241+8388126455+8941458308+8509902424+8509902424+9683278076+7122150828' + xchannels + gchans; google_ad_client = "pub-9543332082073187"; google_ad_output = 'js'; google_ad_type = 'text'; google_feedback = 'on'; google_ad_region = "test"; google_ad_format = '250x250_as'; //--> google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
  2. 2Order a replacement door seal. It's easy to find them online. Make sure to check the model number for your refrigerator when you order it. When it arrives, hold the new door seal up against the old door seal to compare the size. The sizes are rarely incorrect, but it will save you the trouble of doing the job twice if you happened to receive the wrong door seal.
  3. 3Locate the screws. Lift the edges of the seal and find the screws underneath that are holding in the plastic liner and door seal. Often, the screws hold in a plastic liner, which in turn clamps the door seal to the door.
  4. 4Loosen the screws. Begin to loosen the screws that hold in the door seal. DO NOT take the screws all of the way out. It is unnecessary and will create more of a job for you. If at all possible, loosen only a few screws at a time, as you go.
  5. 5Remove the old seal. Once all of the screws are loose, the door seal should easily slide out from behind the plastic liner. Don't be too forceful when doing this step, since some plastic liners can be quite brittle and crumble if you are too rough. If the plastic is old, replace it.
  6. 6Insert the new seal. Begin slipping the small lip of the new door seal behind the plastic liner of the fridge. The best method is to start in the top corners and work your way around the door.
  7. 7Tighten the screws. Once the door seal is in a certain section, you can begin tightening the screws. Begin with the 8 corner screws, and then check the alignment of the door while closed. Also check that the seal is even and straight. If the door is twisted, you can easily manipulate the door to twist back into shape whilst the screws are loose. Then tighten the remaining screws.
  8. 8Apply powder. Use a bit of baby powder or talcum powder to prevent sticking. Rub some powder around the hinge side corners of the door seal, and where the seal slides. This will help to prevent the door seal from twisting as it meets the metal of the fridge. If this still doesn't prevent twisting, then wedge a screwdriver under the seal as you close the door and leave it shut for an hour.
  9. 9Check for gaps. Look for any gaps in the door seal, especially at the top on the opening side. These can form due to the door dropping or being out of alignment. One way to check is to turn on a flashlight and place it inside, then close the door and look for light.
  10. 10Fix any gaps in the door seal. Pack out the seal underneath the areas where the door seal has the gaps. This can be done with a small strip of weather stripping, as shown here, or a bit of tightly rolled up paper under the door seal. Alternatively, you can heat the door seal up with a hair dryer to fix the gaps. This softens the door seal and allows you to stretch it.
  11. 11Check the corners. If the application of powder hasn't prevented the door seal twisting, then wedge a screwdriver under the seal as you close the door and leave it shut for an hour. The door seal will then have enough time to mould into the correct shape.
Aug 29, 2010 | Refrigerators
The seals on the doors need replaced. They leak cold air and when you shut the freezer door the frig door pops open.How do I replace the seals?
You can peel back the seal looking behind it and there should be screws all the way around it. Or you problem could be caused by- The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Aug 09, 2009 | Refrigerators
How to find and replace a freeezer door seal
on many models, it is not possible to fit a replace,ent door seal - they are foamed into the door and to replace the seal means replacing the whole door
Aug 27, 2008 | Freezers
Frigidaire Dishwasher Leaking
I just found a service release number for my Frigidaire dishwasher that says it applies to Serial numbers TH632 through serial number TH737 made in 2007 for a replacement kit for the door seal at the bottom of the door. The bottom door seal has been changed, adding side seals that restrict the water surge from the center spray arm. The part number for the new seal is p/n 154588201. This seal can be replaced without removing the dishwasher or either of the door panels.
The seal is located on the bottom of the inner door panel and appears as a cream colored flexible
rubber blade bonded to a milky white colored plastic strip. To remove and properly install
replacement follow the instructions carefully.
1. Replacing this seal can be accomplished without disconnecting power from the unit.
Always use extra care when electrical power is present while serving an appliance.
2. Open door all the way down and remove lower rack. Set rack aside to a safe location.
3. Locate the seal on the bottom of inner door panel. Facing front of unit, the right side of the
seal can be pulled down slightly to facilitate removal.
4. Pull seal straight into the tub from right side.
5. With seal removed, and before installing replacement seal, locate the channel in inner door
panel that the seal mounts into. Locating this channel before installing the replacement can
make this procedure easier.
SERVICE FLASH
DW071
6. Place the new seal on a flat surface and measure from the bottom of the seal, (See Figure
1 to determine bottom of seal), up 3/8 "of an inch and place a mark with a pen or marker on
both ends (See Figure 2). If needed, scribe a straight line between these two marks this
will give you a guide when installing seal into the inner door panel.
7. The seal can only be installed one way. The end that holds this seal into the inner door
panel has a ½ inch notch cut in the right side. This notch allows the seal to be installed
around the end of the inner door channel that holds the seal.
8. Line up the seal along the bottom of the inner door panel and start from the right side, push
the seal into the door channel to the line marked in step #6.
9. With seal in place close the door, the tub will align the seal as needed.
10. Reinstall lower rack and operate unit to check for leaks.
If leaks continue to occur at the bottom corners, order Splash shield kit 154701001 for
dishwasher.
Before installing the kit remove and reinstall the lower door seal. To install the lower seal make
sure you measure up from the bottom of the seal 3/8 of an inch and mark the seal, do this on
both ends. This locates how far down the seal needs to be before closing the door. Do not
install this seal without measuring it first. After the lower door seal has been re-installed then
install the splash shields according to the instructions accompanying with the kit.
Sep 18, 2007 | Dishwashers
Frigidaire ATF6000ES Front Load Washer Logo
199 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
