Hp w2007 why does the computer go pink everything that is green is now black
    Brigadier General:
  • 10,406 Answers
All the colours on the screen are created by "mixing" the 3 "primary" colours (red, blue, green).
Once the production of "green" ceases, anything that should be "100% green" becomes "100% black",
and every colour that indicates some percentage of "green" becomes a mixture of just RED and BLUE, i.e., various shades of PINK.
First, try the monitor on another computer (desktop or laptop). If the problem persists, it's time to replace the monitor. If the problem vanishes, it's the video-card in your computer that is not generating GREEN, or it is the "data" cable between your monitor and your computer that is not transmitting the GREEN request. So, you can try replacing the data-cable, or try replacing the video-card.
Posted on Jul 13, 2010
Lcd monitor pink/green tint
Check the cable going into the back of your monitor and the cable from your monitor into your computer, one of them is most likely loose.
Dec 24, 2013 | HP Computers & Internet
Hp w2007 moniter is on but no light
try connect it to other pc or laptop, sometimes your pc video card won't work replace it
Joel
Apr 20, 2013 | HP W2007 LCD Monitor
HP w2007, monitor display goes slightly pink in color, gets dark. Caps?
That can be bad lamps, or bad caps also, but I suspect the lamps.
When lamp gets old it usualy turn on pink and turn white after warm up, but if it is really bad, it will cause the inverter circuits to go into shut down to protect the circuits since bad lamp can draw excessive current. You can see bad lamp album.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Dec 29, 2010 | HP W2007 LCD Monitor
The color is "off" on
ladywoman197, 2 things for you to do. 1. disconnect-reconnect vga cable a few times from the DB15 vga port on the pc. If problem (pink hue) persists then try here: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-blackout-solution/ Your unit may need some new capacitors installed on the power supply printed circuit board. Read fixya profiles of "budmrtn" "12fixlouie" and also visit youtube for video clips of lcd monitor repair. Do the vga cable thing first!!! Could also be vga graphics card inside pc not making good contact with monitor cable. 12fixlouie
Nov 08, 2010 | HP W2007 LCD Monitor
My monitor, hp w2007, shows for about 20 seconds when turned on then goes blurry then black how do i fix???
The most common problem that causes the screen to go to a black screen is due to bad capacitors in the screen's power supply board. The bad caps are the cylindrical and will appear to have bulging tops. 66c561df-0d01-416a-ae23-71f3b3965c88.jpg
Oct 24, 2010 | HP W2007 LCD Monitor
Monitor turned green
There should be adjustment buttons either on the front of the monitor on the computer itself. Then your can try taking the green out.
Dec 05, 2009 | HP W2007 Desktop Monitor
My hp w2007 moniter keeps going black after about 10 mins. of idle .turned off screensaver because i want moniter to stay on but it doesnt.
Where you go to select "no" screen saver, there should be a "Power Settings" button. Press this and in there you can set the power save feature to "never" switch off monitor. Hope this helps. Ian.
Oct 21, 2009 | HP W2007 LCD Monitor
HP w2007 LCD monitor goes off Monitor going to
Make sure that everything is connected to the monitor properly. Go to the back of it and make sure the VGA or DVI cables are secured and then check the back of the computer to do the same.
Sep 16, 2009 | HP W2007 Desktop Monitor
Computers & Internet Logo
David Payne
David Payne
