Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
How do you tighten the deck belt on a craftsman dyt4000?
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
  • 6 Answers
SOURCE: how do I tighten the deck belt on my craftsman
You should not have to. If the blades are not turning, either the tentioner is frozen and not able to apply tention to the belt or the belt is too large for the tentioner to be effective. Check the routing of the belt and make sure it is following the correct path.
  • 57 Answers
SOURCE: craftsman 42 inch deck won't run
Check proper belt routing. These models are a little tricky. Also check tensioner spring.
Posted on May 18, 2009
  • 133 Answers
SOURCE: need a diagram for a sears craftsman 42 inch deck drive belt and
I don't have a deck diagram but you should be able to figure it out it you put the back part of the belt (flat) up against the pulleys that are wide and the narrow part (v) into the smaller pulleys. It might take a couple of times but it is not that hard to figure out. Also put the (flat) side of the belt on any tension idlers. Hope this works.
Posted on Jul 29, 2009
goldenglove1
  • 144 Answers
SOURCE: I need to tighten belt for the mower deck, how is
Each of the pulleys on top of the deck should have tensioners. These tensioners are usually the type which have a bolt for you to tighten while attached to the pulley. While you tighten the bolt, the pulley puts tension on the belt.
Posted on Aug 05, 2010
Got a craftsman mower 42 inch deck changed spindles and blades and deck still shakes belt may not be tightening up
did you put the blades on right ??? they have a star pattern and it needs to be lined up correctly... if that's ok does the belt have a bad spot in it or is the engagement mechanism operating correctly ???
Oct 20, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
How to tighten a craftsman LT1000 belt ?
There is an idler pulley that engages the mower deck and tightens the belt automatically on your model. Check to make sure the belt is routed correctly, return spring is in place and that your cable is operating smoothly.
Jul 19, 2014 | Craftsman Garden
I need a belt diagram for the mower deck on a Craftsman DGT 4000 mower w/ 48" deck... Can you help??
If you go to sears.com and click on parts. You will need to enter your model number-not dyt4000-but the model number on the machine's ID plate, probably with the serial number.
It will respond with your mower parts diagram!
May 07, 2011 | Craftsman Garden
I need to tighten belt for the mower deck, how is that done? it is a 2004 craftsman 17.5HP 42 " deck. Can you help me
Aug 05, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Hydro trans slips on dyt4000 craftsman
I'm having the same problem on a 200 and have narrowed it down to belt slippage. Problem is I replaced both pulley's and belt with Sears parts and made it worse. You can pull back on the brake/clutch pedal and it doesn't slip but there is no adjustment I can find. ANYONE got a CLUE
Apr 14, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Engine dies when i engage the blades on my craftsman 24hp 48" deck model dyt4000
There is a safety switch that is connected to the seat, so that if you get out of the seat with the blades running, it will shut the mower off. That switch may be bad, or disconnected. Look for a pair of wires running up under the bottom of the seat. As a short-term fix or a test, you could connect those two wires together.
Mar 07, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
Diagram for dyt4000tranmission belt
Go to Partsdirect.com, this is sears website. You will find a diagram on there for the belt routing.
Sep 28, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
How to replace deck belt on lt 1000 craftsman riding mower
there are several belt guards that you will need to loosen then the belt will slip right on. having someone hold the clutch will make it easier, and the belt diagram should be on the deck. If not, these are common mowers, so a search for this or a friends/neighbors mower may hold the answer. Be sure to re tighten all guards or your belt will pop off and wear out very fast against these metal parts
Sep 15, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
How do I tighten the deck belt on my craftsman riding lawmower
Apr 04, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
342 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
