Question about Samsung SyncMaster 740N 17" LCD Monitor
Our Syncmaster 740BX does not turn on the picture and the power button continues blinking until heated with a hair dryer or after a very long time. A bad solder joint?
  • 11,361 Answers
That sounds more like bad caps with high ESR, the ESR will go down when the cap is heated, this is one of the tool I used to locate bad caps.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jul 13, 2010
Testimonial: "A great specific answer supported by repair experience! Thank you."
Lite in the front of the TV when you turn on keeps blinking and no picture.
The blinking is giving you an error. Even thou you say your TV is working fine, there is something wrong. It could be anything from the convergence(like Color problems slightly out of line) or Sound problems, or you may have problems just in the power supply. Could you remember the set acting funny like in the past? If so do you remember what went wrong or what gliched? This could tell you what is going on now. If none of this it could be a capacitor in the Power supply.
Jan 06, 2008 | Toshiba 55H70 55" Rear Projection...
Power supply in HP slimline s7310n
It sounds like the CPU is over heating. It probably has poor ventilation. Unplug the unit and open the side panel. Carefully vacuum all the dust inside. Be careful not to damage any electronics. You can use a small brush to loosen the dust before vacuuming. Good luck!
Apr 11, 2017 | Computers & Internet
Samsung led monitor blinks on pc but only on desktop picture
presss four buttons on the control panel simultaneusly and keep pressed untill
unlocked message will appear when unlocked message will appear your problem will be solved .all procedures will carry in power on condition
Oct 31, 2011 | Samsung SYNCMASTER 570DXN MONITOR 58.1 X...
Shows some sines of power but dosn't turn on.
U MUST HEAT IT UP BEFORE IT WILL TURN COMPLETELY ON U HAVE TO HEAT UP THE CURICIT BOARD AND THE BACK OF THE T.V. BEST WAY TO DO SO IS USE A HAIR DRYER AND TAKE OF THE PANEL IT WILL WORK FASTER.
Jun 15, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Will not turn on blinks 9 times then 5 times
heat the deflection board with a hair dryer 1-2 min before turning on tv
May 28, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Honeywell oil radiator
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off.
Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature.
The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear.
Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear.
Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking.
The heater will automatically turn on when time expires.
Hope this helps!
Sep 24, 2007 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
Power light blinks
I found a solution, Heat. When the set is on and heats up it stays on, but once off for the night it gets cold and can't start, try using a hair dryer on full blast and put the heat around the back top vent like structure and wait for the light to stop blinking, this only takes about 2 min or so
Sep 05, 2007 | Samsung LTN1565 15 in. HD-Ready LCD...
Samsung SyncMaster 740N 17" LCD Monitor Logo
505 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
