Question about Canon PowerShot A560 Digital Camera
Blank image when you turn on
When i turn on the A560 the LCD screen is blank with a white square in the middle and does nor show the image that you are pointing at?
  • 1 more comment
  • dhccreative1 Jul 03, 2008
    Tried everything, from resetting the settings to replacing the batteries and memory card. Camera has hardly been used (probably fewer than 200 shots taken so far, and the problem occurred without warning. Can anyone offer a solution?
  • wosie Dec 09, 2008
    Blank screen when turned on. Can rerview old pics but cannot take new. HELP
  • kommer Dec 10, 2008
    I have the same problem. When I turn on the camera I have a black screen. I can view old photos, can take photos without viewing them on the screen, and if it is in video mode I can view things on the screen. The camera is only a few months old!!
I have same problem and just tried the "reset all" function in the menu. Then I turned off the canera and when I turned it back on the screen worked. I hope this works for others!
Posted on Dec 10, 2008
Have you checked the settings dial, it doesn't like to be between choices... See if it plays back stored pix.... C
Posted on May 28, 2008
How to fix vizio tv that turns on but no picture
LCD & LED TV Repair - No Image & Blank Black Screen ...
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on the Screen ... Was working fine and now blank ...
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
My tv stopped working, it had the sound but no picture, so I did a little research and fixed it. ... vizio E701i-A3E ...
Vizio LED TV Repair - TV Has Backlights but no Image on ...
? 5:06
https://www.youtube.com/watch?v=fSCf1xxLjNA
Aug 27, 2015 - Uploaded by ShopJimmy.com
Basic Troubleshooting Help if your Vizio LED TV has a blank screen and no ... It is on an UPS but turned off ...
Dec 10, 2015 | Vizio M3D650SV 65 inch Class Theater 3D...
Blank picture
hi frined
i tink your camera lcd gone a bed so chanege it go with agood techision of camera
Apr 20, 2008 | Canon PowerShot A560 Digital Camera
Sanyo dp50747 plasma tv is only showing in the middle of screen no video blue square showing horizontal 20 inches wide.The outside of square is blue solid both sides inside the square fuzzy lines red,...
It is line fault. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 17, 2014 | Sanyo Televison & Video
I have an A560, LCD screen goes blank
try the display button if thats not the problem, then ccd lens sensor went bad and need to be repaired by canon http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=183&modelid=14904#SupportDetailAct
Sep 13, 2009 | Canon PowerShot A560 Digital Camera
LCD SCREEN IS DAMAGED IT AS A BLACK CIRCLE IN THE MIDDLE OF THE SCREEN ONE IN THE BOTTOM LEFT HAND CORNER NO IMAGES SHOW UP ON IT IT IS JUST BLANK
there is only one way out, you need to replace the lcd screen (only screen)
there is no chance of repair in your old screen
Nov 11, 2008 | Cameras
LCD Display Blank
I have a sony cybershot DSC-S650, the LCD was very dark and could not see anything except if I pointed it at a bright object, everything else worked ok. I could take pictures but could barely see them in playback as well.
I took it to Sony authorised repair outlet and was told the CCD was damaged, they charged me USD $55 to repair it (in Quito, Ecuador)
Jul 31, 2008 | HP Photosmart R607 Digital Camera
Canon a560
Stay in a bright place or room and then try to press the Disp button once twice or even thrice. By doing so u shd be able to notice the picture or the LCD's backlight turning on.
Pentax a10
Ok here it is open the camera and re insert the fine lcd ribbon into is holder problem solved. Your camera must have had a sharp knock to dislodge the lcd screen and pulling out the ribbon. Worked for me.
Cheers
Feb 19, 2008 | Pentax Optio A10 Digital Camera
White Square with brighter Oval in middle on LCD and Pictures
have you checked the lense assembly. One of the possible cause may be any of the lense element, inside the lense assembly may have dislocated from its fitting. Just swithc on the camera look inside the lense from the front and try to zoom the camera. if you happen to find any obsticle in the movement may be i am right.
Sep 07, 2006 | Fuji FinePix S7000 Digital Camera
Canon PowerShot A560 Digital Camera Logo
95 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
