Question about Haier HSB03 Compact Refrigerator
Cools but constantly runs
The frig is a Haier HSB03 Compact. The frig cools but has started to run constantly. We have unplugged it and replugged it in thinking it might be a stuck thermostat but it starts running again shortly after plugging it back in.
    President:
  • 2,702 Answers
You hit the nail on the head there,,,its the thermostat its dead!
change it they often stick in the on poshion when they stop working to save any food inside of the fridge
Posted on Jul 12, 2010
My Haier compact refrigerator, Model # AES27, stopped running. I unplugged it and then plugged it back in and only hear a humming sound for like 10 seconds and then nothing.
These are noted for bad controller boards. It is located under the back cover. Look under the cover and see if the control circuit board is blackened or smells burned. You can get parts at this link:
http://www.repairclinic.com/Haier-Parts?gclid=CMajgvvFpqYCFYdi2godeBsFmA
Jan 06, 2011 | Haier HSB03 Compact Refrigerator
Stopped cooling. Light comes on but does not cool.
Once pluged in to the power outlet try noticing these:if the motor runs(located behind the ref)it needs freon refill(also question why it ran out of freon? must be a leak fix the leak first before refilling.If no motor is running?then you need to replace it together with the freon refill.
Oct 27, 2010 | Haier HSB03 Compact Refrigerator
My fridge freezes everything. What may be the cause? How to fix?
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 24, 2010 | Haier HSB03 Compact Refrigerator
Not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
fgjdhgk
Aug 20, 2010 | Haier HSB03 Compact Refrigerator
It runs but doesn't cool. Model BNA17B
From the reviews I have seen of this product it needs air all around it. The manual says it needs at least 4 inches in the back. It also helps the farther it can be off the ground such as on a stand or table or bricks or something.
Aug 09, 2010 | Haier HSB03 Compact Refrigerator
I have a Haier compact refrigerator (Model: HSP03WNWAWN-01, Serial Number: A205673063 - I defrost it and know it will not get cold. It comes on but will not get cold. I tried plugging in in for 24 hours...
Unplug the unit then turn the thermostat all the way on then all the way off, then slowly move from off to fully on position do you notice a spring popping sound at a certain point? Yes No? if yes turn it all the way off and wait ten minutes then plug back on, notice if the compressor comes on or not. If it does then turn the thermostat to half way on does it cool now? if yes you have the problem solved, if not you have an issue with the defrost circuit and you need tools to test it, if you have an ohm meter let me know and I will help you further. Thanks for using fix-ya
Jun 05, 2010 | Haier HSB03 Compact Refrigerator
Haier HSB03 does not cool, just clicks, when it kicks on.....
Most of the times the problem is the compressor relay that get stuck , try replacing it (no more than $30) , but if the compressor still clicks and won't start probably is burned out.
Oct 15, 2009 | Haier HSB03 Compact Refrigerator
My Haier compact frig runs all time, at #1 setting: freezes all
no 1 setting is close to zero degrees C the setting should be around 4 for normal every day use
call a technician to fix /replace the thermostat
if you continue to use a metal object ( screw driver , knife, fort etc ) when defrosting , you problems with the fridge will soon be over as you will puncture the evaporator section and that is not repairable so you will require a new unit
Jul 05, 2017 | Haier HSB03 Compact Refrigerator
HNSE05SS Compact Frig
There are very few parts on this unit. UNPLUG unit jump out the 2 wires to the t-stat. plug it in, if it runs the t-stat is bad.
After that theres the overload /start component on the side of the compressor. UNPLUG remove cover look for burnt wires , wires are ok feel if the compressor is HOT to the touch. if it is it could be off on internal overload. let it sit for a while plug in and listen for a hum or click in the compressor. If there is a Hum then click your back to eather your overload /starter is bad of the Compressor is bad. If you have an amp meter you can check the compressor by clipping the meter on power wire. on the information tag that has the model and serial # there is a amp draw for Lock rotor. If the unit draws Lock Rotor amps the compressor is bad.
May 21, 2008 | Haier HSB03 Compact Refrigerator
It will not get cold
You need a qualified technician with your problem, may be the unit have leak and out of freon or system is restricted.
Jan 10, 2008 | Haier HSB03 Compact Refrigerator
Haier HSB03 Compact Refrigerator Logo
358 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
doggzzz
Level 1 Expert
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
