Question about Whirlpool Washing Machines
Whirlpool wfw9300vu washer Code 70/71
I have a Whirlpool wfw9300vu washer that's about 1.5 years old. It now does not work and displays error code 70/71. How can I fix this? I think it's the CCU but I want to know how can I change it?
jsrock516
  • 5911 Answers
SOURCE: Error code F09/Whirlpool Duet front loading washer
"F09" is an Overflow Condition error. This is usually attributed to a malfunctioning pressure switch, loose or broken connector between the Pressure Switch, Drain Pump and Central Control Unit (CCU), or...a drain pump or drain line that has become clogged.
Since this problem occurs periodically during the wash cycle, I would check your drain pump filter for obstructions first. It could be that you have debris lodged in the pump causing it not to drain properly. To access the pump:
1. Unplug the washer.
2. Remove the lower kick panel under the door by removing the screws under the bottom edge. HINT: Placing a couple of blocks of wood under the front feet of the washer will make access much easier.
3. The drain pump is located under the wash tub in the center. HINT: If you own a shop vac, remove the drain line from the standpipe at the wall and pull a vacuum through the drain line. This will remove all residual water from the washer and make clean up later a lot less messy. Now, remove the cover on the drain pump and remove. Clean out the pump filter and check the pump impeller for obstructions.
If you do not own a shop vac, place a bunch of towels around the drain pump BEFORE you open it. There's about a gallon or so of water in the tub, drain line and pump.
Try this first, and let me know if this corrects your problem. If not, you may need to check the pressure switch and wiring. I hope this helps you.
Posted on Apr 14, 2008
SOURCE: Whirlpool Duet Washer Error Code F-11
earlier i just researched code "dl" (door lock), the washer would not start, door would not lock. this site under this code failure came up with a Wiz called "Coldcut".
I took the motherboard out and searched around for the crack with a microscope, I found that every one of the relays had bad solder joints with micro-cracks around the legs. This did not happen due to wear or vibration.This was a new replacement board. It was just a bad solder job on the factory wave solder machine. QC issue.
After re-soldering all the relays legs I have run the machine for a month now without any issue.
So there it is the final fix for the dreaded door lock F dl issue. and likely any other random error issue.
Comment by Coldcut, posted on Jan 25, 2008 the constant clicking and then F DL failure is symptom
If you want to test that the relays have a bad solder joint as I had found. after opening the machine top metal cover ( 3 screw in top rear), on the front of the CCU motherboard push up on one of the white connectors that has the black wires gently .you can safely do this as this is the low voltage area,
the machine will then gain control of door lock and the front buttons will now work.
stay away from the pink wires they are 110volts.
Yes resetting the power to the machine will sometimes work but the failure will reoccur randomly.
Just mark all the connectors location and remove the board open the plastic and remove the board. flip it over and add new solder to all the relays ( white square boxes) legs. Reassemble and rest assured you have fixed the issue.
BTW if you need to open the door manually, unplug unit , remove top washer cover, reach down (tight area) and below the front door latch you will feel a ring, push it down and the door will open. the same can be done from the bottom access panel but you will have a cramp in no time.
Comment by Coldcut, posted on Jan 26, 2008 yes those white boxes are the relays that control the door locks.
but while you are in there soldering there is another relay off to the side as I remember re-solder it too. I found that any relay on the board had micro-cracks around the legs.
Comment by Coldcut, posted on Jan 26, 2008 Also can you take a closeup of the bottom of the board before you fix the solder joints to show folks the issue before and after. Comment by Coldcut, posted on Jan 30, 2008 On a side note I have found that this same board is used in many brands of top loaders.and have of course the same issues.
I have notified the makers of this model what I found and they are forwarding it to their engineers . sic.
Posted on May 08, 2008
duby1990
  • 370 Answers
SOURCE: Kenmore 70 series will not drain or spin
It sounds like the lid switch. If it ws the coupler the water would drain. Check to see if the lid switch is clicking when you put the lid down. replace the lid switch. You have a great washer. Fairly cheap fix.
Posted on Nov 20, 2008
SOURCE: Whirlpool Duet washer, about 1
http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html
Posted on Mar 27, 2009
maintenacemi
  • 95 Answers
SOURCE: Six year old Whirlpool 3357978 washer stops spinning violently
the bowden cable requires adjusting like the brakes on a push bike
Posted on Nov 18, 2009
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    Duet. What does F8E1 code indicate needs to be done to restore operation?
    Check out the Link and the info below.
    Question: Front Load Washer - Error Code - F8 E1 or LO FL Answer Product Symptom:
    F8 E1 or LO FL Code in display:
    No water detected entering washer after 13 minutes, the pressure switch input has not been detected.
    If the washer has an F8 E1 error or LO FL error, the door will be locked, and the control will be unresponsive. The washer will start a drain routine which takes approximately 8 to 10 minutes, during which time the pump will run continuously. The control will not accept any input during this time. Please wait 10 minutes before trying to perform any functions.
    Check the water supply:
    Turn on the water. Check the household water supply to see if the hot and cold water faucets are turned on. Make sure to open both faucets completely for proper fill.
    NOTE: Both Hot and Cold water must be supplied to the washer.
    Whirlpool recommends that appliances be direct connected to the water supply for optimum machine performance.
    If a "flood saver" device is being considered:
    • Check with the manufacturer of the device to ensure it will not affect the performance of the appliance.
    • Whirlpool has experienced that "flood safety" devices can interfere with the performance of the appliance. Whirlpool typically does not recommend these devices.
    Two types of "flood-saver" devices, hoses and valves are illustrated below. anti%20flood%20hose%202.jpeg floodsafe%203.jpeg Whirlpool Duet Washer F8 Code Appliance Repair Forum
    Jan 19, 2016 | Whirlpool Washing Machines
    Fh error code wirpool duet washer
    Display shows F20 or FH - Front-load washer ' Whirlpool ...
    https://www.whirlpool.com/...fh-front-load-...
    Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
    whirlpool duet error code FH - Appliance Repair Forum
    forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
    Jan 5, 2009 - 10 posts - ‎1 author
    ... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
    1 post
    Dec 5, 2014
    Whirlpool Duet Washer HF Error Code
    Jun 10, 2013
    FH Error Code on Whirlpool Duet Washer
    Mar 11, 2013
    FH error code
    Sep 13, 2008
    More results from forum.appliancepartspros.com
    Stumped on error code FH for Whirlpool Duet front load washer .
    Jan 08, 2016 | Washing Machines
    What does f23 error mean?
    Display shows an error code - Front-load washer ' Whirlpool ...
    https://www.whirlpool.com/...error-code...w...
    Whirlpool Home AppliancesCheck the following answers for error-code related issues you can correct: ... Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33.
    What does error code f23 flashing mean on a Whirlpool ...
    Nov 30, 2015 | Washing Machines
    Cabrio washer is giving an F 51 Code
    The "F51" error code is common problem with the Cabrio. This is an RPS sensor error. The sensor is mounted along the motor windings under the washer and detects the rotation spin speed. The sensors on these units can go bad, causing the error code, and it has been a frequent problem. I would recommend you contact Whirlpool first (due to the unit only being a year old) and see if there is a recall or upgrade on this part. I believe there is. The repair would then be covered by the manufacturer. If I give you the steps to access and/or replace the sensor at this point, you may be voiding any existing warranty you may still have. Some components carry a longer warranty than your normal one year limited warranty from the manufacturer. Something you may consider.
    If you have further questions, please let me know. I hope this helps you in some way.
    Jun 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    I have the error code F-01 on the display
    I go to our electric breaker box (in the basement), locate the breaker that provides electric to my washer, flip it off and then back on. This should reset the washer. I received the F01 code twice in four years, and each time this has worked for me. Unplugging the washer may reset it but I haven't tried that because I would have to move my washer. Good luck!
    May 27, 2009 | Whirlpool WFW8300SW
    Whirlpool Duet Sport ~ E28 Error Code
    serial communication error between central control and motor control.
    Check connections at ccu (top front right corner) and mcu (bottom by motor), check belt drive for wear.
    Did motor run ? Any other codes in diagnostic? (any one modifier button 4 sec on 4 secs off 5 times.) F codes are failures and C codes are portions of test cycle(automaticly run)
    Apr 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet Error Code F11
    its your ccu board under top in back easy to change about 300.00 that is f 11 code "plz"
    Nov 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Washing Machines Logo
    128 people viewed this question
    Sal De
    Gerry Harvey
    Gerry Harvey
