Question about Maytag MMV4205 Microwave Oven
Error Code E-13
The unit still works but what does this code Mean
What does code f6 mean on microwave
It depends on the manufacturer. It is an error code and something is wrong inside. What brand or model is the unit??
Oct 22, 2017 | Microwave Ovens
Kenmore Elite Microwave Model No: 79080373310 giving E-11 error code
I do not know what an E-11 code is on that unit. But the fact you say no buttons are working gives me a clue that you may have a bad touch panel. Could be a Goofed up Microprocessor on the board. A Lot of units will give a code for a bad pad. If an air pocket in a pad colapses, the microwave thinks you are pushing and holding down a pad, so it will give a error code. An E-11 code may mean a bad touch panel on your unit. Try to unplug the unit, give it a minute and plug it back in, try to set the clock first and see what it does. When setting the clock try all of the number pads and see if they all respond. If one doesnt that mey be your bad pad. Or if a number comes up on its ownwithout pushing it, that pad could be shorted.
Aug 18, 2017 | Kenmore Microwave Ovens
What does E 13 mean on a Kenmore microwave oven?
Kenmore microwaves are made by several manufacturers. The E-13 error may indicate a humidity sensor issue or a problem with the control board. It could also be an issue with the wiring between the sensor and the control board. Try unplugging (or turning off the circuit breaker to) the microwave for at least 30 seconds. This may reset the error. If the problem recurs, the sensor or the control board may need to be replaced. Microwaves can store an enormous amount of power in the capacitor and may be dangerous. Repairs are best done by a professional.
I hope this helps.
(The E-13 code diagnostics above apply to Samsung-made microwaves.)
Mar 12, 2016 | Kenmore Microwave Ovens
What is SMH18165 -Error code: E-13?
It is a T1 maximum time error (oven did not preheat properly). usually caused by a failing thermistor/sensor, a bad seal, bad control circuit board or connector. Unless you are a really good electronics expert and have the test equipment for after-repairs microwave emission measurement, it has to be dealt by the service people.
Read more http://www.kgbanswers.com/on-a-samsung-over-the-range-microwave-what-does-the-code-e-13-mean/11020759#ixzz37XLvUOq8
Jul 09, 2014 | Samsung SMH9187ST Microwave Oven
Kenmore elite microwave troubleshooting
<- If you had listed your error code, I would probably have been able to tell you what it means.
But of course, I'd also want the full model number from the tag on the unit.
You can also look here:
http://www.appliancepartspros.com/repair-help/appliance-fault-codes.html
Jan 05, 2014 | Microwave Ovens
Indicater light shows S. E. what does it mean?
Good Afternoon Sandra, thank you for allowing me to assist you!
Typically error code SE indicates a shorted key on the keypad. Try unplugging the microwave or flipping the household circuit breaker off first. Wait approximately ten minutes and turn the unit back on. If the error code continues to display, then I recommend contacting a professional to make a precise diagnosis.
Oct 05, 2013 | Frigidaire Over-the-Range Microwave
Error code 13
All i kind find is it's a sensor error. turn it off or unplug for a few seconds then switch on again. if the fault is persistent it will need an engineer to look at it. is it under it's 12 month guarantee still?
Jan 13, 2013 | Samsung SMH9187ST Microwave Oven
My Samsung SMH7178STD just started showing error code E-13
Hi, please click on this LINK then select 'Display Panel', then 'Microwave Is Displaying An Error Code' for instructions on what to do in the event of an error code, such as 'E-13'
Oct 31, 2010 | Samsung SMH7178STD Microwave Oven
Maytag MMV4205  Microwave Oven Logo
97 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
