Question about Gateway M275 Tablet PC
When I power it up nothing comes up on the monitor??
  • 69 Answers
1. check the RAM is seated
2. Try any other RAM
3. still the same problem check the video or graphics card , if any
4. if no graphics card and problem stiil changing it clear your CMOS by removing battery
5. if its new system then, remove battery, then take a small wire piece and short the positive and negative of the battery socket, then only CMOS is cleared
6. still problem , check the processor heat sink
7. still problem then suggesting checking motherboard and processor
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Posted on Jul 12, 2010
Screen will not come on, have disconnected power adapter, screen will not come on,
Buy a vga, dvi or hdmi cable depending on what your pc uses and plug it into a different monitor or tv. If this works, you can also purchase a wireless board and mouse and have it working on the tv
Nov 06, 2014 | Acer DA220HQL All-In-One Multi-Touch...
My 7" zeki tblet model TBDG773B comes on and shows android and nothing else will.
You can try a factory restore, but if that doesn't work you will need to buy a new tablet. These cheap tablets are throw-aways unfortunately. Note that a factory restore will erase any files you have on the device.
Factory Restore on Android devices:
- Turn off the device
- Hold Volume Down and also press the Power button until a menu comes up
- Use the Volume Up and Down buttons to select Factory Reset (or Restore)
- Press Power to select
Oct 28, 2014 | Shopnbc Zeki 7" Multi-TouchTablet
I need a Power cord for emachine monitor?
Power cord for monitors are really easy to get the first place I would go to is best buy
Jul 18, 2014 | eMachines E15Ts LCD flat panel monitor...
What do you do when memo will not come on?
I called Asus. Told to connect charger & hold volume up & power for 40 seconds. Nothing happened, then press power & volume down. Nothing happened. Then told to hold volume up & power for 60 seconds, and it should come on, which it did.
May 28, 2014 | ASUS MeMO Pad HD 7
Gateway M275 display scambles
I suspect it may be a problem with the video cable coming from the convertible tablet, up through the hinged support for the LCD screen, AND/OR the screen Inverter.
I would like you to connect a VGA monitor, to the VGA port on the back of the convertible tablet. The VGA monitor will now be an External Monitor.
[ Looking at the rear of the convertible tablet, start at the Left side.
Vent, USB port, Monitor port. The Monitor port is the VGA port ]
The VGA monitor can be a CRT type, (Looks like a small TV), or a flat LCD screen monitor with a VGA cable.
Notebook OFF, monitor OFF, connect the VGA monitor to the M275's VGA connector. (Port)
Turn the monitor on. If a CRT type, allow it to warm up.
Turn the notebook on.
By the factory default settings, whatever is shown on the convertible tablet's internal monitor, should now be shown on the external monitor.
(VGA monitor)
If not, press, and hold down on the Fn key (On the bottom row of the Keyboard, all the way to the Left), and tap once on the F3 key.
(Top row of Function keys. The F3 key is the Display Toggle-Over Key )
No graphics shown on the external monitor? Hold down on the Fn key again, and tap the F3 key again.
There are at least three options available;
1) Convertible tablet's internal monitor - ONLY
2) Convertible tablet, AND external monitor
3) External monitor - ONLY
If graphics are fine on the external monitor, you have a problem with the video cable, and/or the screen Inverter. At this time we will bypass the LCD screen, and come back to it.
At the bottom/middle of the tablet's LCD screen, is the Hinge. The Hinge Cover is 'T shaped', and has one single Philips screw holding it on.
If you remove the screw, and the Hinge Cover, you will see two wire harnesses.
One Black, the other White.
See that these two cables are plugged in tightly to the connector.
After checking this step come back in a Comment, and state your findings.
Regards,
joecoolvette
[ Additionally;
Here is the Service Manual (Free) for the Gateway M275 Convertible Tablet,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-gateway
Where it states - Gateway 400, go down to the second line, and across to M275. Left-click on M275.
This is a PDF file. It may take up to 30 seconds before the first page comes up.
Dec 11, 2011 | Gateway M275 Tablet PC
I have a Fujitsu stylistic ST5112 which powers on, all of a light show up, I can hear the hard drive spinning, I have it in the docking station in a DVD drive works, but what I turn it on all I get is a...
Might be an LCD problem.
Notice if the LCD monitor turns black when you turn it on, turns gray if you turn it off. That means the problem is the LCD, back light/inverter is not functioning anymore.
Tell if that happens.
Thanks for asking FixYa!
Sep 12, 2011 | Fujitsu Tablets & eReaders
Monitor shuts off
You can set your power management to ignore or control the time that your monitor, hard drive or other peripherals stay on in Control Panel or BIOS setup. It powers your monitor down to save the battery power so the computer itself does not shut down thereby losing data you may be working on. Familiarize yourself with the battery power length of time so you can determine whether this is normal or if you have a dying battery.
Oct 29, 2008 | IBM ThinkPad X60 Tablet PC
Toshiba Portege 500 Laptop
need a toshiba mother board for m40x250
Aug 04, 2008 | Toshiba Portege M400-S5032X Tablet PC
Gateway M275 Tablet PC Logo
161 people viewed this question
Top Gateway Tablets & eReaders Experts
ashburton
Ricky Ostrom
Ricky Ostrom
vojvodabudva
Are you a Gateway Tablet and eReader Expert? Answer questions, earn points and help others
