Question about Brother MFC-7220 Plain Paper Laser Fax
Unble to receive a fax
Set up is all correct but still unable to receive any faxes. Need to figure this out asap as I own my own business and have been missing faxes all day. please help
I have not received any faxes and the screen keeps saying change drum soon when i already changed it.
Posted on Jul 13, 2011
  • 313 Answers
It may be a silly question but it is a common error have you checked the cable is in the line socket and has not been put into the tel socket on teh back of the fax machine as this will cause a fault.. youcan check this also by dialling the fax number and see if it rings out.. also check the rx reception mode is set to fax and not tel/fax or manual setting this is on the display it should have the date and to the right say auto or fax make sure it isnt displaying tel.. Letr me know if this helps
Posted on Jul 13, 2010
Unable to receive faxes. Able to send and cartridge printing OK
There can be a few things wrong lets take it step by step
1)Receive mode,your receive mode must be set correctly.If you don't have a tel connected to it, you cant use it as a Manual receive mode,it must be set on Fax only.If there is a telephone connected to it and it is set on manual mode make sure your Incomming ring is set to ON,you will find it under additional functions,RX settings,Incomming ring.
2)Make sure you have enough memory to receive a Fax.Go additional function,dataregistration,TX settings,Erase failed TX,set it to on.
3)Make sure there is enough toner and paper for the machine.
4)Tone or Pulse Dialing,depents in witch country you are make sure it is set correctly Tone or Pulse.You will find it under user settings.
5)There can be a problem at the you local exchange,you can send faxes but the exchange can be faulty and you would be able to receive faxes.
6)And then there can be a problem with you fax machine' NCU PCB board,there is to gas arresters one for send and the other for receive.If one of them are faulty you will have to replace the NCU.The gas arresters is not available as a part.
Dec 09, 2009 | Canon FAX-L360 Plain Paper Laser
Can't receive a fax
There are some settings that you need to change.
You need to turn off the following:
Error Correction Mode
Auto Reduction
to get to these options you need to go to the setup menu by pressing the setup button
then scroll to advanced fax settings and select it and you will find the options listed under it
You also need to check the fax speed under Advanced fax settings.
set it to medium.
hope this will help you :)
Aug 09, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Got new hp elite m9402f computer but new hp fax doesnt answer
hi there,
initially you have to check and correct this few settings.
To receive a fax manually
1. Make sure the device is turned on and you have paper loaded in the main tray.
2. Remove any originals from the document feeder tray.
3. Set the Rings to Answer setting to a high number to allow you to answer the
incoming call before the device answers. Or, turn off the Auto Answer setting so
that the device does not automatically answer incoming calls.
4. If you are currently on the phone with the sender, instruct the sender to press Start on their fax machine.
5. When you hear fax tones from a sending fax machine, do the following:
a. Press the left arrow or the right arrow to select Fax B&W or Color fax.
b. Press Start.
c. After the device begins to receive the fax, you can hang up the phone or remain on the line. The phone line is silent during fax transmission.
Hope this initial info helps you.
micromaster-
Jan 19, 2009 | HP J4680 Office Jet All-In-One Printer
Can't Receive Faxes
Promotional faxes are coming through fine everyday. However, we can not receive any of our business faxes. No changes have been made to the fax. Please Help ASAP.
Aug 14, 2008 | Canon FAXPHONE L80 Laser
My model Kodak 5500 printer/fax
Just found your post and I'm having the same problem. Everything else seems to be working correctly. I can copy, scan, print and I THINK I can send a fax correctly, I should have called the person and made sure it arrived. However, I cannot receive faxes. I have an answering machine on the line, but it is not plugged into the Kodak Pinter, it is in another room. The answering machine answered the call, the FAX noise came across, but the Kodak Printer never picked it up and printed out the fax. I think I have all the settings correct, but the instructions are not very clear. Do you think I HAVE to have the answering machine plugged into the Kodak Printer? That doesn't make sense, but I might try it.
Feb 02, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Fax problem
Check your preference settings and make sure the fax is set to receive faxes (my friends has 6 different settings) Your manual should tell you how to do this. The default is different for many fax machines.
Jan 02, 2008 | Lexmark X4270 All-In-One InkJet Printer
Canon MP830
When i am trying to fax a document it is saying that the memory is full. But when i go to the menu and to fax memory it is saying empty. How to solve this problem
Dec 19, 2006 | Canon PIXMA MP830 All-In-One InkJet...
Brother MFC-7220 Plain Paper Laser Fax Logo
102 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
