Question about Karcher PSI Electric Pressure Washer
The pressure washer hose blows off when I close the trigger and it is screwed on tight. Whats wrong?
  • 92 Answers
The first thing is that for sure the screw thread on the machine or at the end of the hose is damaged. Now it seems thar when you close the trigger the machine is not stopping due to a spill valve problem or micro switch problem. You are a bit lucky that the hose blows off, because if the hose stays in place, with this problem...more damage is done to the machine, especially the intake valves. Now the spill valve is a control valve that when there is presure built up, the valve moves and makes off a micro switch. This Spill Valve often gets stuck with detergent or chemical. So the Micro switch stays ON. Thus the machine will not stop...and blows the weakest point. Now you can either service the spill valve or as I do, replace it with a new one. To locate it you have to open the cover, and where there is a wire coming out at a place...there is the spill valve. First check the micro switch...then tackel the spill valve. As a general rule one must always rinse with clear water after using chemicals and soap. If these are left there..problems with the automatic stop of the machine will start to give trouble.
Fulltech.
Posted on Aug 03, 2010
Pressure washer pump not pressuring
Some of these pumps have a pressure bypass valve when you release the trigger on the gun it won't blow the hose ( safety feature) I could be that the vale is stuck
May 26, 2014 | Karcher 2500 PSI Pressure Washer
020209 pressure washer has no pressure
Your water inlet may be stopped up. Whether this model only has a screened hose washer or a better filter, pay special attention to that. Be sure the pathway is free and clear.
Take each of poppet valves and while pushing (with a pencil or something) on the part that moves up and the spring pushes it back down - with magnification and lots of light, be sure there isn't a small piece of debris affecting one of those valves. Its easy to miss, so look very closely.
Next, remove the hose from the pump. We are by-passing the entire unit that includes pressure hose, trigger gun, lance, spray nozzle. If it seems to pump a lot of water out of the pump--then the problem is most likely the trigger gun is clogged or the pressure nozzle is clogged. Some trigger guns can be taken apart -- some, not so much. Same with nozzles.
I hope this helps you, Randell. If yes, please take a sec to rate me. Thanks!
Don
Mar 23, 2012 | FAIP Garden
I have a honda 2600 pressure washer. After running fine for a couple of seconds the water will stop flowing out the tip. It is receiving water,but will not flow it to the pressure hose. I even disconnected...
This happens when air gets inside the hose. An air bubble of sorts is in the hose and will not build pressure until you blow the air out of the line. Start the pressure washer, turn on the water. pull the trigger on the gun. It will spitter and spatter and come to a trickle. release the trigger on the wand. Pull the trigger again and it will eventually work it self out.
Jun 13, 2011 | Honda Black Max 2600 PSI Pressure Washer
2500 pressure washer 2.3, its running noe buy the water will not come out of the nozzle..whats wrong?
Check he screen where the hose screws in. There is a screen inside the fitting you should clean. Take it out carefully by using a screw driver around the edges and make sure the screen is clean. After you put the screen back in take the hose off the gun and see if water comes out of the hose. If it does you have to take the gun apart and clean it.
Mar 19, 2011 | Craftsman Garden
I am trying to disconnect the lower hose on this unit is a quick disconnect or does it screw off
If it is the trigger hose, more than likely it will screw off. You may need to squeeze the trigger to release the pressure in the hose. Then it should screw off.
Jan 28, 2011 | Simpson PS3200 Powershot 3200 Psi Direct...
Why dose my Karcher K2.35 keep blowing the gun hose off?
There is a good chance you are missing the black plastic clip that holds the hose into the trigger gun. If you look at where the hose goes into the gun there should be a flat slot where a black plastic clip would slide in and keep the hose into the trigger gun.
Oct 24, 2010 | Karcher 2500 PSI Pressure Washer
I own a Karcher 3000 pressure washer. There is no water pressure. I've checked the obvious...hose to house, kinks, attachment is tight....Enging runs, no water pressure.
I had the same problem. On the top of the pump there is a little nickle colored button cap. It is attached on both sides with a screw. What this actually does I don't know but when I took it off with the motor running and put my finger over it the pressure come up. I also discovered that having the motor running and taking the nozzle tip off and pulling the trigger would clear the pump to work until you let of the trigger again. Weird but it works for me.
Aug 06, 2010 | Karcher Garden
Why doesn't the unit stop running when pausing while pressure washing, it use to
Hi If you have any leaks on the high pressure side then the unit will keep starting. Please check all external hoses etc and o rings to make sure that they are water tight. The most common one is where you screw your high pressure hose on,there is a o ring inside the coupling that usually wears. Also check all o rings at the trigger and lance. If there are no leaks then it sound like you have a problem with your pressure switch.
Jun 14, 2010 | Karcher K238CCK 1600 PSI 13 GPM Electric...
Honda 2400 psi before it went out i cold tap the end of the wand on the ground and the pressure would return now when pull the trigger there is no pressure only a fine spray .its a karcher with a honda...
hi,
there is a small ball bearing inside the nozzle on the end of the lance , this can get jammed or missaligned and the nozzle orifice can get blocked , clean this or replace the whole lance with another 200 Bar lance .
hope this helps
Feb 01, 2010 | Honda Karcher G2400HH-R Pressure Washer
Karcher PSI Electric Pressure Washer Logo
2,135 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
