Question about Frigidaire GLGR331A Gas Dryer
Dryer will not heat
This gas dryer is a Frigidaire Gallery about eight years old. It was working just fine until I decided to clean the lint screen and the outlet to the outside. I used a vacuum cleaner and an air compressor to remove excess lint. I was successful with my cleaning but I think I may have blown the pilot light (if there is one) out. As a consequence - I cannot get the dryer to ignite. I didn't take it apart and left the gas and electric hooked up. I know I have power and I know the gas line is not kinked and producing gas except I don't smell any coming in. And I know I have ac because all the mechanical partswork. jr
  • Frigidaire Master
  • 8,220 Answers
My guess is you probably got some lint on the ignitor and cause a burnout or a limit to trip. If you don't hear the clicking associated with the ignitor heating up and the flame sensor kicking it off then I would check to see if maybe a limit was tripped. On gas dryers when the limit trips the dryer will operate but simply will not heat up. I have a full page with service manual included HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jan 13, 2012
Fridgidaire gallery gas dryer + burn marks
Good Afternoon Friend,
I understand that the dryer on your Frigidaire laundry center, model# GLEH1642FS, has burn marks. It sounds like the air flow in your dryer could possibly be blocked. I suggest cleaning out the lint trap, the ducting, and the vent outside. I also suggest cleaning the lint filter, by running it under the hottest water you can handle and a small scrub brush. You should be able to clean the burn marks with a small scrub brush and warm water. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 09, 2014 | Frigidaire Gallery Series GLEH1642FS
How to clean debris below lint filter Frigidaire Gallery GLER341as1
Pull the exhuast vent off the back of the dryer, remove the lint screen and then turn it on for a few, should just blow out the back.
Jan 09, 2013 | Dryers
I have a Frigidaire Gallery Supreme gas dryer. It's 20 years old. It doesn't heat up. The answers I got were all about top lint screens and in the door lint screens. Mine screen is in the front...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 05, 2011 | Dryers
I have a Frigidaire stackable full-size washer/dryer. I don't have the model number, but it is about eight years old. The dryer does not get hot enough to dry even a small load well.
When was the last time you cleaned out your vent? It should be done every 1-2 years to prevent build-up of lint and possible blockage. Also make sure your outside dryer vent flap is not stuck closed or clogged. I use a plumbers snake to twist inside the vent and clean out the lint. It makes a huge difference in drying time. Also disconnect the vent from behind the dryer and check for lint build-up inside the back of the dryer itself. (Be sure to unplug the dryer before you do this!) When you push the dryer back, be careful not to squish or pinch the dryer vent if it is a flexible foil or plastic tube. These are the easy fix-it's. Try them first before resorting to more expensive trouble shooting. Douglas
Sep 06, 2010 | Frigidaire Dryers
I've got a fridgedaire gallery gas dryer, approx 8 years old. Takes too long to dry clothes. I've cleaned inside as best I could and the dryer duct. Is seems to get hot some of the time, but not constant
if you use fabric softener. i recommend you slow it down...alot. an appliance guys nightmare is just that. inside fabric softener, is wax. your lint screen may look clean. but run it under hot water. ive come across many a lint screen where the water will simply not go through the screen, even though it appears to be sparkly clean.
Sep 29, 2009 | Frigidaire FGQ332ES Gas Dryer
Gas Dryer blowing cool air and will not heat up.
Look inside door and get the model number for me. Could be igniter, gas solenoids or temp control switch inside. Let me know, Thanks Sea Breeze
Mar 19, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Dryer works but won't heat
2 things ,,no heat whats so ever ,sounds like ignitor,, or little heat possible coils )gas)
Nov 29, 2008 | Frigidaire Dryers
My Gallery series dryer shuts off.
Check your lint screen. If you do not get a complete "lint pattern" you probably have a clogged or partially clogged vent which will cause your dryer to overheat and prematurely shut off. Clean your vent and you'll return to normal operation. If you have a vertical vent (goes up through the roof) get a proffessional to clean it. Dryer vent issues are the #1 cause of house fires according to the U.S Department of Consumer Affairs. Over 16,000 per year.
Nov 24, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Gas range
I have a frigeidaire classic gas range 12 years old worked fine until a pot of water leaked over the stove top burners. now the door locked lite is on and the door lock is activated , the oven door is open and won't close. The oven also does not work now, although the stove top burners work fine.
Can you help ? Thanks, Tom
Apr 07, 2008 | Frigidaire FGF378AC Gas Kitchen Range
Frigidaire GLGR331A Gas Dryer Logo
192 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
