Question about Danby 22 in. DDW396 Free-standing Dishwasher
Danby dishwasher seems to be leaking on front left side - how to fix
  • Danby Master
  • 12,061 Answers
Http://www.retrevo.com/support/Danby-DDW396W-Dishwashers-manual/id/886dj685/t/2/
Above is a user manual, below is a self help dishwasher repair how to.
http://www.acmehowto.com/howto/appliance/dishwasher/dishwasher.php
You really must get a service manual. But if you cannot find one, simply open up the inspection hatch, and look for the source of the leak, usually around the Pump, filters etc, often a fitting has come loose... as related locate and repair your leak.
Posted on Jul 12, 2010
Ow do I fix leaking door on Danby countertop dishwasher?
Either replace gasket or calk it with clear silicon.
Sep 14, 2014 | Danby Dishwashers
New dishwasher already wet inside when opened for first time! Is it ok?
Sounds like it was in a flood.
I'd sure try to send it back.
Be blessed.
Apr 14, 2013 | Danby DDW1899WP Portable Dishwasher
GE Dishwasher Quiet Power III Dishwasher leaking
The average life of dishwashers is 7-10 ten years so it might just be dying but try this. If the leak is a small one that seems to always be near the left side of the dishwasher put a cup of white vinager in the upper rack and run the unit on pots & pans or heavy duty. This is caused by a build up of detergent that make the unit oversuds, when the suds turn back into water it leaks out the left front corner. The amount of water is not huge, one towel to clean up. If the leak is larger it could be the pump is leaking and you can order a new one with your model # from marcone.com
Nov 27, 2010 | GE Dishwashers
Dishwasher: danby ddw1806bsl. Getting error code E4 "too much inlet water". How to fix that?
There is a tank with an overflow sensor on the right side of the dishwasher. The tank needs to be drained of water to reset the sensor. If necessary remove the insulation on the lower front corner of the machine and drain into a cup or container by removing the black rubber plug at the bottom of the plastic tank.
Consult the manual for detailed procedure.
The error can occur from excessive foaming.
Sep 22, 2010 | Danby DDW1806BSL Stainless Steel Built-in...
Danby dishwasher leaking from underneath
It is still under warantee-contact the company you bought it from. If you fix it yourself you could void the warantee.
Jun 14, 2009 | Danby 22 in. DDW399 Free-standing...
Water not flowing into Danby 18"
Okay, this might seem crazy, but it worked. I spent the last 2 days trying to contact Danby customer service to no avail, so I came back here to look for solutions. Found two:
(1) Someone said to open the little rubber cover under the front right of the machine...I couldn't find such a cover.
(2) Someone said to pull off the front plastic panel...mine doesn't seem to be removeable.
So! I turned my Danby DDW1805 upside-down (!) to see if I could locate the aforementioned rubber cover, and a bunch of water drained out of the machine. This is what both solutions above said I wanted to happen, so I flipped it back right-side up and hooked it back onto my faucet.
Golden. Works perfectly again.
May 15, 2009 | Danby DDW1805W Designer Series...
My portable danby is stuck on the Drain cycle
take bottom front panel off to expose bottom tray and you will probably find it full of water. disconnect from electricity and mop water out and machine should work. if fault reoccurs then you have a leak
Sep 25, 2008 | Danby DDW1805W Designer Series...
Leaks
try to use lass soap
May 12, 2008 | Danby 22 in. DDW396 Free-standing...
Danby DDW496W Leaking Brand new
Check your hose connections in the back for tightness and sealing (there should be some rubber seals inside the screw-in connections) and if tight and not leaking, you might have a loose clamp inside the unit, or a leaking/damaged hose, or even a defective/leaking pump. If it is brand new and returnable I'd return it for a new one rather than try to fix it...
Apr 05, 2008 | Danby DDW496W Free-Standing Dishwasher
i would think the drain hose from the unit is leaking from the description you give.let me know
Dec 24, 2007 | Danby 22 in. DDW396 Free-standing...
Danby 22 in. DDW396 Free-standing Dishwasher Logo
380 people viewed this question
Top Danby Dishwashers Experts
Kevin Getz
Kevin Getz
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
