Question about HP Officejet 5610 All-In-One InkJet Printer
I am having blank lines mixed with the printing
When I print a page either from the glass or from the PC the print comes out with void blank lines at about 2 inches apart acroos the paper. I changed the inks and the printheads, reset the printer and still is happening. Can you help?
  • 50 Answers
1> Disconnect all cords and cables from the back of the printer viz. power, USB/ethernet, FAX, etc.
2> Press and hold # and 6 together and connect the Power cord directly from the wall outlet at the back of the printer, when the printer turns ON release the # and 6.
3> The printer will initialise and settle down after some time,
> Clean the cartridges and printheads of the printer.
Follow:- < http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu01831&cc=us&lc=en&dlc=en&product=441125 >
Also try to clean them manually........if this does not solves the problem then the printer has got some permanent hardware failure.
Posted on Jul 12, 2010
Testimonial: "Thank you very much for your expert help, your recomendation solved the problem."
Why won't it print test page?
If the test page placed face down on the glass does not contain text, you will get blank copies.
Jan 08, 2016 | Office Equipment & Supplies
Transfer Belt Leaving Color Streaks on Pages
Try replacing color toner of the same color that are the lines.If the void was in the same place all of the time then I would say use a Q tip dipped in 90 proof alcohol and clean laser.
Apr 21, 2014 | Brother BU300CL Transfer Belt, 50,000...
A blank vertical line appears on every page printed
if it is a white void check laser shield glass. toner might be on it causing this problem. There should be a wand in front door use to clean laser area make sure you do each color. hope this helps.
Feb 09, 2014 | Ricoh Aficio CL3000 Laser Printer
Printer is printing with horizontal blank lines
you did not indicate machine or how you are printing.
1- printing from glass or doc feeder?
did you check the small scanning glass on left side?
usually if there is a dot (pen dot or similar) it will come out as a line on docs, this is because the paper is moving while scanning, so it now sees the dot a s a line. Line up the paper w the glass you should see where the problem is comong from.
Sep 06, 2012 | Office Equipment & Supplies
Blank line down left side of outgoing fax or feeder copy
The most common cause of blank (void) lines on a scanned document is from whiteout on the glass where the page is scanned when using the document feeder.
If there is a clear mylar sheet on the bottom of the document feeder, the whiteout may be there instead.
If there was dirt or a dark smudge on the glass (or mylar), it would show up as a black line, but whiteout is white, and shows up as a void (blank) line.
Mar 11, 2010 | HP Officejet Pro L7680 All-In-One Printer
Ricoh cl3500N printing with blank streaks in middle of page and faded quality black printing and black ink blotches on sides
The voids and blotches can be a bad black pcu, the voids san also be toner on the glass slat obove the pcu,s there are 4 slats one for each color, on the pcu itself on the upper side is a narrow long opening, the glass slat is above this opening when the pcu is in the printer. It will take a flashlight to see any toner on the glass.
-Carl
Jun 28, 2009 | Ricoh Aficio CL3500N Laser Printer
When printing or faxing there is a one to two inch blank spot
INSPECT THE DOCUMENT READER GLASS THIS SOMETIMES GETS WHITE OUT OR OTHER JUNK ON ON THE LENS AND LEAVES A VOID AREA.
Feb 19, 2009 | Brother IntelliFAX 4100 Laser Fax
Fax 2820 will not print. pages are blank
what do you mean printing stage?for the blank pages,it may only require cleaning.check the toner save setting,make sure it is off.clean the scanner glass of the machine,or you may just need to replace the drum
Nov 15, 2008 | Brother IntelliFax-2820 Laser Fax
Printer won't print
Printing on stand alone has a big difference when printing from pc.... try using the kodak website for this issue www.kodak.com/go/itg and use "image quality and blank page" for subclass
Oct 22, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Horizontal lines
Depends on whether the "lines" are colored or just blank areas missing in the print . If it is blank areas , then most likely the laser scanner is dirty and the glass needs to be cleaned . If it is colored lines , then you most likely have a defective drum .
Jul 18, 2017 | HP LaserJet 1500L Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
90 people viewed this question
Seeker5211
Seeker5211
