Back to:
Tags:
CD ROM Drives
Generic problem for all CD ROM Drives
HL-DT-ST DVDRAM GSA-T20L ATA Device is not working... (by 31 users)
posted by SACT on Apr 20, 2008
I have uninstalled and restarted. HP is of no use at all. the error code is 10. any ideas?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
30 Other Users Have The Same Problem
Comment by mohammed272, posted on Sep 19, 2008
HL-DT-ST DVDRAM GSA-T20L ATA Device is not working all of a sudden
Comment by vengeancefor, posted on Sep 11, 2008
HL-DT-ST DVDRAM GSA-T20L ATA Device is not working all of a sudden problem, and notify you when a new solution is offered.
Comment by Guest, posted on Sep 05, 2008
Comment by milo_sama, posted on Sep 05, 2008
I had the same problem and after the solution posted by angryagain, Hey men you are great..... I was two hours trying a Microsoft Solutions....
In my case HP Pavilion TX1320US HL-DT-ST-DVDRAM GSA-T20L doesn't work properly on Vista, can't see the dvd icon at the Computer access devices shortcut. thanks I really apreciate it
Comment by rican_biatch, posted on Aug 29, 2008
could not be installed code 10
Clarification Request
by angryagain, posted on Jun 15, 2008
well i tried this and now i have no DVDRom icon or itunes.. 2nd toshiba laptop to do this... never again!!!! looks like a MAC for me
Best Solution
posted on Jun 06, 2008
FixYa! (100)
droobie6
Rank:Apprentice Apprentice
Rating: 90%, 14 votes
You must delete yo0ur iTunes. I had the very same problem and as soon as I deleted iTunes the drive was active again. Hope you all didn't spend as much time as I did before you figured it out.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on HL-DT-ST DVDRAM GSA-T20L ATA Device is not working all of a sudden:
I don't want to Accept this solution
Solution #2
posted on May 16, 2008
Helpful (85)
dilipbagdi
Rank:Guru Guru
Rating: 86%, 478 votes
Error Code 10 loadTOCNode(2, 'moreinformation'); If the device has a "FailReasonString" value in its hardware key, that string is displayed as the error message. The driver or enumerator places this registry string value there. If there is no "FailReasonString" in the hardware key, the following generic error message is displayed:
This device is either not present, not working properly, or does not have all the drivers installed. (Code 10)
Try upgrading the device drivers for this device.
Solution button: Update Driver
To resolve this error code, make sure the device is connected to the computer correctly. For example, make sure all cables are plugged in fully and that all adapter cards are properly seated. Follow the suggested solution button and update the device driver. It may be possible to remove the device and redetect it using the Add New Hardware wizard.
Thank You!
Can you Help with these CD ROM Drives problems?
Dell Inspiron 1200 14.1 XGA LCD...
Won't recharge when charge plugs in. Charger and battery...
HP Compaq Presario 2500 HP Pavilion ZE 5000...
About two years ago the AC adapter supplied with my HP...
Compaq Presario 1200,1600 (297657-001)...
I have hp compaq presario 1000. Dvd rom and cd re writable...
E-Machines emachines (emachinees) CD-ROM...
when i try to burn a dvd with convertxto dvd it fails with...
HP HP Pavilion ZV5000, ZV6000, ZX5000...
My sound is alway on mute mode. If I try to pop the...
30 Other Users Have The Same Problem - Continued
Comment by kyle_derrick, posted on Aug 27, 2008
Thanks for the regedit post... Worked within seconds!
Comment by Guest, posted on Aug 16, 2008
This seems to happen anytime there is a Apple update.
Comment by Guest, posted on Aug 14, 2008
me 2
Comment by daniwales, posted on Aug 13, 2008
I did everything as advised and dont have the upper thingy
Comment by Guest, posted on Aug 10, 2008
Yes! I had this exact problem - I was happy to see a HP-Tech solutioun (regedit -> device manger) posted for it. That solution worked completely! Thanks a million!
Comment by raintoad, posted on Aug 09, 2008
I had this problem and had to fix it twice. First of all deleting Itunes did nothing.
I first decided to do a system recover back to the time the system worked. That worked only for one day. I finally broke down and sat on the chat line with HP. I wish I did this in the first place. The fix is much easier than banging your head against the wall. So.... for future reference here is the fix for an HP Pavillion dv2815nr with a HL DT ST DVDRAM GSA T20L ATA device:
You will need to delete the upper and lower filter from registry.
steps:
1. Tap Window key (flag key on the keyboard) and R key on the keyboard, at once.
2. You would see the Run window on the screen. Type Regedit in the open field and click OK.
3. Click plus sign (or arrow) next to HKEY_LOCAL_MACHINE
4. Click plus sign (or arrow) next to System
5. Click plus sign (or arrow) next to CurrentControlSet
6. Click plus sign (or arrow) next to Control
7. Click plus sign (or arrow) next to Class
8. In the left hand window pane click {4D36E965-E325-11CE-BFC1-08002BE10318} to select that key
9. In the right hand window pane select the UpperFilters registry key and press the delete key on the keyboard Confirm with an OK
10. In the right hand window pane select the LowerFilters registry key and press the delete key on the keyboard Confirm with an OK
11. Click on the "X" in the upper right hand corner of the Registry Editor window to close it
After that......
12. Open the device manager window Tap (Window key (flag key on the keyboard) and R key on the keyboard, at once) Type in devmgmt.msc
13. Expand DVD/CD-ROM Drives and right click on the device and select uninstall.
14. After uninstalling, plese click on the system icon on the top and select scan for new hardware changes.
The systm will update and will fix the problem. I hope this helps.
Comment by DESERT LQ, posted on Jul 27, 2008
YEP, NOTHING WORKS. I THINK THE ONLY WAY TO GO FOR THIS DRIVER PROBLEM IS TO INSTALL THE ORIGINAL DRIVER DIC THAT CAME WITH THE COMPUTER, IF YOU HAVE IT. FINDING THE DRIVER FOR THE DVD/CD OPTICAL DEVICE ON THE WEB IS LIKE LOOKING FOR A NEEDLE...YOU KNOW THE REST. UNINSTALLING AND REINSTALLING DOES NOTHING. GETTING RID OF I TUNES DOES NOTHING BUT GET RID OF ITUNES. GOOD LUCK. THANKS HP FOR THE CRAPPY DEVICE!!! WAY TO GO!!
Comment by AlexWillWin, posted on Jul 25, 2008
I have the same problem, except my error code comes up as '39,' instead. I've taken the automatic update and deleting my itunes (I don't really use Itunes on this computer anyway) routes, but nothing seems to work. And I've also tried looking up a place to just download the driver from, which I know is dangerous, so please don't give me some comments about how I shouldn't try and find it.
Comment by crushonice, posted on Jul 02, 2008
I have toshiba satellite L100 laptop. my dvd ram device suddenly shows as cd rom device and do not boots up, however it shows cd rom icon sometimes. when i try to inject the media , it do not reads or displays anything. system hangs i click on the icon. I tried to upgrade the driver also, but do not helps.
Comment by pa3gda, posted on Jun 20, 2008
same problem
GSA-T20L is not working??
try to uninstall, and reinstall , also system restore points, still not working!
please email me.
Comment by ekweani2002, posted on Jun 18, 2008
Comment by oloruntoba, posted on Jun 12, 2008
The device does not work properly(error code 10)
Comment by Robert_RS, posted on Jun 03, 2008
Having the same problem but whenever i got to my computer the Cd drive icon does not appear and when ever i put a cd/dvd it does not autoplay
Comment by quique2, posted on May 26, 2008
Yes...and no way to fix it
Comment by Guest, posted on May 20, 2008
the device out of date
Comment by cornaile, posted on May 19, 2008
I have the same problem, too. Error code 10. I'd bought my computer 7 days before. It's brand new...
Comment by Guest, posted on May 14, 2008
Comment by vividr88, posted on May 13, 2008
I have exactly the same problem with an hp computer, error 10
Comment by Dennismedeir, posted on May 08, 2008
Same problem. Using vista on pavillion notebook Code 10 also, have upto date driver
Dennis
Comment by Guest, posted on May 08, 2008
I have an HP pavilion notebook. (new) all of a sudden the drive stopped working. device manager reports not working Code 10 ?? yet says I have the latest driver using VISTA
Comment by Guest, posted on May 05, 2008
Code 10 - the CD Rom is not starting - yet the drivers are up-to-date... I can't even find drive E: on the compter....
Comment by Guest, posted on May 02, 2008
I installed the GSA-T20L inside my Toshiba Satellite 5200.
It give me "Error reading from disk" message.
Someone have a solution?
Thanks!
Comment by Guest, posted on Apr 30, 2008
I have the same problem. It starts suddenly and a cound't solve yet.
Comment by hedde, posted on Apr 27, 2008
HL-DT-ST DVDRAM GSA-T20L ATA Device code 10
Comment by Guest, posted on Apr 22, 2008
TO CHANGE REGION
Loading problems.
Repair Service
Find CD ROM Drive Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
