Question about Cuisinart SPB-6 Smartpower 6 Speed Blender
When plugged in and on light is flashing, the device will not work.
Why won't the blender start? the on/off light keeps blinking
my Ninja blender wont turn on, power button keeps blinking red ...
https://answers.yahoo.com/question/index?qid...
Dec 11, 2011 - I know I"m not supposed to drown myself in the toilet yet the don't build in a head protector. The blinking light won't go off. It worked last night ...
Ninja Blender Red Light Is Flashing ' Appliance Repair ...
appliancerepairquestions.com/question/ninja-blender-red-light-is-flashing/
Mar 29, 2015 - My new Ninja Blender has a power button that is flashing red. ... and the top of the blender is on and secure but the light keeps blinking / flashing. ... How do I set the oven off from demo mode asked by Anonymous, 2 months ago ....Whirlpool MDU1955XTSS2 won't turn on asked by Anonymous, 4 months ...
cuisinart blender red light flashing but Questions & Answers ...
www.fixya.com > Forum > Tags
Dec 26, 2015 | Euro-Pro Ninja Nj600 1000 Watt Xl...
Not working
How to Fix a Blender ' DoItYourself.com
www.doityourself.com/stry/how-to-fix-a-blender
A food blender is a far less complex machine than most people might imagine. Because of this simplicity, you can easily determine the cause of a non-working ...
The Ninja Ultima Blender: What To Do When Power Light Is ...
? 0:36
https://www.youtube.com/watch?v=LfY_-VA5m8A
Oct 16, 2013 - Uploaded by Ninja Kitchen
... Blender start flashing. If the light on your Ninja Ultima Blenderis flashing, check the following... ... Still not working. Read more Show less.
Dec 09, 2015 | Blenders
Soup mate pro won't start
try powering off, removing contents from the container, refill using less contents and push the contents to the bottom plate. Turn power on. If beeping stopped it will work. Another thing to try is turning the rubber gear on the base or bottom of the container slightly then put container back on the base, as before do this while power is off at the power point for safety. Regards Greg T. My mother bought one and Ive had to step in as Im the only one to make it work. Hope this helps you. I am about to go past for the 3rd time of her using this device to see if I can help do a re-heat as she made a soup and its now not playing ball again 4 her. Forced to contact the distributor of course!
Jan 09, 2014 | Oster 6678 14 Speed Blender
Ginny's blender lights keep flashing
you have to have the top part on before you turn on the blender
Sep 09, 2012 | Blenders
Blender stopped working
Sounds like the motor burned out.
Jan 30, 2012 | Black & Decker Blenders
Kitchen Aid blender KSB560 capacitor exploded
Someday people will learn that MANY of the stepdown convertors are useful ONLY for hairdriers and devices WITHOUT electronics. ONLY use convertors with a big transformer in them for electronic devices. Yes, they are expensive, but so are repairs. Now on to your problem:
The device was probably an MOV varistor transient suppressor.
Trace the circuit out and if it is across the input lines, try one of the same MOV's you find in the surge plug strips.
If the device blew apaart, there is likely further damage. You may be able to get a whole board from an appliance repair company.
Do testing of the unit with a 150 wat lamp in series with the power line.
Sep 08, 2009 | KitchenAid KSB560 5 Speed Blender
KitchenAid Blender KSB5WH3 flashing lights how to get to the fuse
i found broken solder connections on triac on circuit board. it's the part with the cooling fingers that surround it. pencil soldered the cracked connections; now works fine.
Jun 19, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Cuisinart SPB-6 Smartpower 6 Speed Blender Logo
69 people viewed this question
Top Cuisinart Blenders Experts
eyecam
ray gallant
richie46
Are you a Cuisinart Blender Expert? Answer questions, earn points and help others
