HD suddenly asks for Password, never set one!
I have a freecom toughdrive external harddrive which (as i found out just now) usually comes with passowrd-protection programme. i used the harddrive frequently, but there password-programme never showed up.
now i plugged the harddrive into another laptop and it asks me for a password, which i have, of course, never set! if i don't have a password it asks me to completely reormat the drive. NOT an option, the data on there is crucial!
unfortunately i am far away from the PC i normally used the HD with and can not plug it in there again to see if it is ok...
help!
  • rejokevenge Jul 13, 2010
    thank you so much for your answer! I'll update when I found out more :)
  • Robin Tolbert
    Robin Tolbert Jan 27, 2016
    I have exactly the same problem. Never set password and suddenly asks for one. I have had this for a long time and do not have manual as I have moved many places. Like wise data is crucial. This is a totally f*&%ed system that does this randomly. How do I fix it? How do I contact Tech support. They MUST know about this glich!!!
    President:
  • 2,923 Answers
The password-protection program is designed to protect your files, so that if in case your HD is stolen, any important files will remain intact in the HD.
You have to refer to the use manual of the HD and look for the default password. Since you mentioned that you never set any passwords, it means that the HD is still using the default or manufacturer's password or code. Check the manual and you should find it there.
Or you may want to contact the tech support of the manufacturer and see if they could give you the default password.
Thank you and good luck!
Posted on Jul 12, 2010
When turned on the harddrive does not make its normal startup noise and worse; the computer does not see the harddrive anymore! The blue light on the front pannel is lit though. Help...
Hi
Check all cable connections in firmly & correct way round, from motherboard & hard drive. Check in bios, make sure hard drive setting is set to Auto. Place you hand on the hard drive to feel vibration. Hard drive could bd faulty. Western Digital are renound for it.
Jun 26, 2014 | Freecom ToughDrive 400 GB USB 2.0 Hard...
Computer doesn't recognise hardrive
It may seem obvious, but did you try a different USB port? Did you try a different computer? and did you try a different cable/cables?
Oct 03, 2012 | Freecom ToughDrive external hard drive -...
I am trying to transfer all my photos from my old freecom external HD to a new external HD, but the Freecom keeps switching itself off mid transfer, every few minutes. I'm worried I'm going to
sounds like a faulty drive, afraid without sending it off only way you will be able to get info off is by transfering it bit by bit,
best u use cut files at least u dont have to keep copying same files over and over that way
Jun 16, 2012 | Freecom Computers & Internet
What should i do when my freecom toughdrive does not recognize of any computer
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Feb 19, 2012 | Freecom Computers & Internet
Window 7 and Freecom Touchdrive
May be it does not have a compatible driver for the drive. Launch the Add/Hardware wizard and use it to search for a driver on the internet. If a driver is available windows will download and install it.These driver issues usually happen with new operating systems. Even Vista had these problems when it first came out.
Dec 05, 2009 | Microsoft Computers & Internet
No response at all from laptop regarding my toughdrive 160GB
Your files are safe on the HDD, the trick to retrieve.
You should have backup at the end of your sessions
If you have the setup disc, reinsert and run!
Nov 13, 2009 | Freecom Portable II External DVD Drive
I have lost the cd which came with my freecom classic hd 80gb and I had to wipe my computer. Now my computer will not read the files on my freecom harddrive
You don't need any software to use this device. If your hdd is external, you just plug it in to any computer via the USB port. If it is an internal hdd same thing again. You can read your files after restoring your computer. But of course it must be your secondary hdd.
Oct 27, 2009 | Computers & Internet
Freecom hard drive problem?
Unless you "GHOST" or "CLONE" the programsd over to the harddrive, instead of just copy and paste, they will not open. What you will have to do mo0re than likely is remove the installation files through control panel and reinstall the program onto the external harddrive.
Mar 23, 2008 | Computers & Internet
Freecom Password Delete
Everything is possible. Few points. Is this external hd? Did you used the software and the drivers given by the manufacturer? Which OS are you using?
Yes it is possible to erase everything on any type of the drive and start from scratch. You can do this by formatting the drive make sure you do NTFS format.
Let me know please!
Dec 12, 2007 | Freecom (24358) 160 GB Network Hard Drive
Export saved emails from toughdrive, import to my laptop
A little more information. What email program are you using Outlook express? Outlook?
If you are using outlook express open it. go to File / Import / Messages.
select the type of program the emails are in when you saved them to the external harddrive.
click next select import mail from OE6 or whichever you had from above. and click ok.  then click browse. and find the drive the email was saved on. then click the folder you have the emails saved in. and click ok. ( it may be easier to save the email folder to your desktop of your computer and just browse to your desktop).
click next select your folder you want the emails to go to and finish the emails will be imported
Oct 26, 2007 | Freecom (24358) 160 GB Network Hard Drive
Computers & Internet Logo
583 people viewed this question
Alun Cox
David Payne
David Payne
