Question about Sony KP-57WS510 57" Rear Projection HDTV
I PUT NEW IC BUT I HAVE SAME PROBLEM PIC LOOK FUNNY DID I DID SOMETHING WRONG
  • Sony Master
  • 3,459 Answers
Many things can go wrong if you did not have any help or instructions to follow - solering - blown picos - missing cables - etc. If you need help with the repair goto www.TvRepairKits.com and get their support opton
Posted on Sep 24, 2010
INTEL 865 MOTHERBOARD IS NOT DISPLAYING I HAD CHECKED ALL THE HARDWARE IT'S PROCESSOR IS NOT HEATING HOW CAN I SOLVE THIS PROBLEM.
this is ur hardware problem in this pic i am showing u an ic (adp 3188).if u can change that ic ur processor power supply will ok.sure
Mar 31, 2015 | Intel Computers & Internet
AKAI MODEL CT3216. SET COMES ON AT PLUG-IN. PIC COMES ON AT 10SEC. NO PIC PROBLEM. SET HAS POOR AUDIO WITH NO CONTROL FROM CUSTOMER CONTROLS. SET CUTS OFF IN ABOUT 15 SEC. LEAVE PLUGGED IN AND IT COMES...
there may be some problem in the remote control board inside ..
either something is not connected or some thing has it burned out like capacitor ....
so you are not able to see the menu .....
Jul 03, 2008 | Akai Televison & Video
What part do I need for my Sanyo LCD DP46848 to fix the pic?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
Apr 27, 2014 | Sanyo DP46848 LCD TV
My battery will not hold a charge for more than about 12 hours. I replaced it with a new one and still have the same problem. HELP
Hi, most causes of battery cell running down very fast is because the problem is from the battery, but from the phone.
Some times a phone will just starting funny may be because sometimes, when something happens to a phone and no action was taking during that particular period in time, it might that malfunctioning later on.
The problem of the phone is an IC that has been damaged that is making the battery cell to discharge.
You will need to replace the IC inside the phone.
THe more you don't repair the IC on time inside the phone,you will keep on buying more batteries.
To fix or replace the damaged IC, you will need to contact an expert on phone for help.it's a little bit technical to handle.
Hope it helped.
Thanks for using fixya..
Jan 17, 2011 | LG Neon GT365 Cell Phone
My dell laptop .. latitude d600 "ic" has been melted...i want to know the ic number??
The "melted" IC - this has shorted out, and something has cause this to happen, even if you replaced it, it could short out the new IC unless you identify the cause.
The D600 is an old laptop, it would be better to put your money towards a new laptop.
You could remove the hard drive and put it into an USB hard drive adapter case and use it as an USB external hard drive..
Oct 13, 2010 | Dell Latitude D600 Notebook
Battery life is very bad. i can put in a new battery and it will last. maybe 3 to 7 pictures. and the low battery will come on. and maybe get 1 more pic. and then die.. am i using the wrong battery? i even...
With no mechanical problem,
It may Cost 90$ to fix it
I hope there would be a capacitor or an IC problem
But first test A Proper Pair of Ni-MH rechargeble Batteries
Good Luck
Nov 11, 2009 | Cameras
Hello my tv power comes on but nothing else
250 is actually really cheap to get the tv fixed...the ic board and all that have to be checked by a pro and the transformer also has to be cheked by a pro unless you know how to work on tvs id send it for repair...
Jan 21, 2009 | Hitachi 53UDX10B 53" Rear Projection...
What hybrid amplifier I.C. does this product contains ?
you will need to show me a pic of the area along with the measurment of the pak from hole to hole and at least the voltage.
Aug 14, 2007 | Pyramid PR530A Amplifier
No picture, only sound
The set has a shorted vertical output IC, probably a TA8427k. The capacitors around the heat sink of this IC dry out and cause the IC to run hot. The correct repair is to replace the vertical output and the electrolytic capacitors near it. Also use 105 centig instead of the original 85 centigrade. The is some time a pico fuse or current limittng resistor which must also be replaced. This a common problem with Toshiba and is not a bad picture tube. The usual cost of this repair is around $120-150 depending on the integrity of the technician. Scrivitron
Jun 18, 2007 | Toshiba 27DF46 27" TV
Sony KP-57WS510 57" Rear Projection HDTV Logo
169 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
