Question about Maytag Dryers
My maytag 3000 series dryer is not even a year old untill 2 more days, it does not dry my clothes no matter what setting I have it on the lent trap gets cleaned about 2 or 3 times during each cycle,yet it still has to go another cycle. Lent still gets in the dryer through lent trap and the lent that escapes under trap is wet, the next day I have about 20. Ounces or more of water in it. They look nice but I hate my crimson red MAYTAG FRONT LOADER WAsher and dryer!!!!!! I would be very happy if I had a plain jane top loader large washer and dryer, because I sure as heck ain't saving any money.
    President:
  • 2,702 Answers
Oooow,,,temper temper,,,,take a deep breath,,,
i think the temp censor has stoped working thats why its not getting very hot its that or the heating coil/s are broken,,also check the air vents at the back are not blocked up if so its not getting any air to it,,,
then go out and find a big stick,,,and batter it with the stick,,,
this realy wont help fix it,,but it will make you feel soooo much better?
Posted on Jul 12, 2010
Maytag Centennial Dryer (MEDC400VW) not drying properly
First of all, please make sure the vent is clear all the way through. Next the vent must be straight as possible. Next it can not be to long. People think that because they feel the air outside the vent is clear, not always true. The vent can be partially clogged. So make sure. Next, if the vent hose has sags or bows and even tight turns. It can accumulate the moisture in it from the drying proceed. If water has collected in the vent hose the clothes will not dry properly. If the vent is to long it can not dry properly either, the blower on the dryer can only move air so far. So the shorter the better. If all of these requirements are meet. Then, I would have to start checking the thermostats. I hope I have helped you. Please respond if you need further assistance.
Jan 29, 2014 | Maytag Dryers
Not catching lint or drying clothes
Hi Diane
Sounds like you have a clogged vent
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
Bud
Oct 12, 2013 | Maytag Dryers
My dryer is heating fine but there is no air blowing out of the vent. Therefore, clothes are not drying properly. I have cleaned the lent filter, checked the outside and and inside vent for clogs or...
run the dryer with the vent hose off, if it drys correctly then it is in the vent tube. The best way to clean the vent hose is with a leaf blower, now if it is not drying with the vent hose off then you will need to disassemble the dryer, and clean from the bottom of the lint trap back to the back of the dryer with a brush(paint) and a vacuum:
http://www.partselect.com/dryer+wont-dry-clothes+repair.htm
Feb 16, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
My maytag neptune dryer is taking twice as long to dry cloths. i've had it 5 years & it's gas.
Clogged Vent
Cycling thermostat
This is a free answer, Please rate me.
Oct 05, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Our model medt5870tw0 maytag dryer does not dry properly
First , remove the vent hose from the dryer to see if good air flow is coming out the dryer vent . If not , could have a bad blower wheel . If so , then check the vent hose AND vent to outside to see if blocked . A dryer will either heat or not heat . Since your dryer heats , try drying a load without the vent hose connected to the dryer and see if it heats fine (telling you , a vent problem is apparent . Sometimes a dryer is pushed too far back , kinking the vent hose also .
Aug 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer not dring clothes completely
need to check your vent duct. if clogged it won't let the air flow through the dryer needed to dry your clothes.
Jun 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My lint trap has very little lint.
Older clothes do not produce as much lint as new ones. Also, if your dryer isn't getting as hot as it used to, then you won't get as much lint either. Does it seem to take a bit longer to dry your clothes? Also, check your dryer vent, if the airflow is reduced, the amount of lint that is expelled through the filter will deminish as well. You may have a build up of lint in the vent ducting to the outside that is restricting airflow.
Apr 08, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
During the drying cycle, the dryer door opens
Chances are the little plastic latch keep is broken. Look at the door and locate a peice that will press into the front area where the clothes go in.
Once you see it, check the keeper and see if it is broken. The door should not just pop open.
Feb 25, 2009 | Dryers
Dryers Logo
396 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Archie Ferrarini
Archie Ferrarini
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
