Question about HP DesignJet 500 InkJet Printer
Need instructions to replace carriage belt for hp designjet 500, specifically how to remove and replace on the carriage assembly
    New Friend:
  • 10 Answers
Replacing the carriage drive belt on a DesignJet 500 is not that difficult
Replacing the
<a rel='nofollow' href="http://www.computercareonline.com/carriage-belt-c-193_194.html">carriage
drive belt
</a> on a <a rel='nofollow' href="http://www.computercareonline.com/designjet-500-c-67_104.html">DesignJet
500
</a> is not that difficult, it will take longer if you have never done it
before. Make sure you have all the instructions on hand and reviewed
before you start. Do not remove the trailing cable from the carriage
assembly if you can avoid it. Be sure to do all the appropriate
calibrations and tests once the replacement has been completed. If you get
stuck, give us a call, we will make every effort to assist you. http://www.computercareonline.com/contact_us.php
Posted on Feb 07, 2014
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 105 Answers
If you're not sure how to do it better leave it to professionals. Although it's not a hard job, you should at least have users manual next to you. Download it here: HP Designjet 500
Posted on Nov 28, 2013
  • 38 Answers
When you order the belt from hp it will come with the instructions, if not email me and I will send it to you.
Posted on Jul 12, 2010
Hp designjet 500 with error code 02:10 can firmware be reloaded?
the error code gives :
Carriage failure. The possible cause could be:
The Carriage PCA is not compatible with the rest of the Printer.
The Carriage ASIC has problems initializing.
The +2.5V reference voltage generated in the Carriage PCA is out of range.
One of the Carriage ASIC's cannot be found within the Serial Bus that connects the Electronics Module to the Carriage.
One of the Carriage ASIC's did not respond to the Serial Bus that connects the Electronics Module to the Carriage Assembly.
Go To Below official Hp Printer Page For Your problem, DesignJet 500 error 02 10 Print Head HP Enterprise Business Community
Feb 24, 2014 | HP DesignJet 500ps (42 in.) InkJet Printer
Hp designjet 500 carriage assembly it's vibrating
Get carriage assembly out from the service station area, remove right door, check right side pulley of carriage belt, weather its cracked or dirt particles deposited on it, clean/replace it, lubricate carriage rail, fix back every thing check .. best of luck.
Nov 26, 2012 | HP DesignJet 500 InkJet Printer
Hp designjet 500plus ,first time i change carriage belt ,but now it shown allignment error..
Two thing you need to check:
1. Are you replaced genuine carriage belt?.. Original belt having two type of inner tracks.. Right side horizontal & left side vertical tracks. Are you fixed it properly or not..
2. Check carriage assembly play.If it is over play(carriage bushes may be warn out) alignment won't complete, If bushes are available in your country replace them & do the calibration..If not go down how to alter bush. see the snap shot
3. While carriage movement pl check trailing cable flexibility.
Carriage Bush:
Note:This modification only professional not for users:
Un screw screws both sides as shown in fig, take out bushes estimate how much warn out happened.
Thing needed:
Fevi quik(glue),small peace of miler sheet,scissor & tweezers.
Cut miler sheet in to small peace & insert warn out place of bush(between bush & rail) & apply glue, fix it permanently,do it both sides & check for the carriage play.. once its finished try for alignment.. For this activity no need to remove carriage assembly from the rail. Main aim is alter bush warn out..
May 30, 2012 | HP DESIGNJET 500 InkJet Plotter Printer
86:01 error in designjet 500 plus Paper jam...
System Error: 86:01
Problem Description: Carriage-Axis shutdown.
Corrective Action:
If this error code appeared but was NOT caused by a paper jam, then try the following:
  • Too much friction in the Slider Rod. Enter the Printer Information utility and check the Scan-Axis usage. If the percentage is close to 100%, then lubricate the Slider Rod.
  • The Carriage is bumping into the Service Station. If the carriage is stuck at the right hand side of the Printer and cannot be moved out to the center of the Print Platen it is because the Service Station cannot uncap the Printheads. In this case replace the Service Station/Aerosol Fan Assembly
  • Perform the Carriage Movement test
Aug 26, 2011 | HP DESIGNJET 500 InkJet Plotter Printer
HP 500ps showing error is System error 86:01
System Error: 86:01
* Too much friction in the Slider Rod. lubricate the Slider Rod.
* The Carriage is bumping into the Service Station. If the carriage
Apr 16, 2010 | HP DesignJet 500ps InkJet Printer
How do I replace the carriage drive belt on designjet 500
there is nothing easy about this problem. you need torx 8,9,10, and 15 drivers. remove the right cover, remove the service station without breaking it, remove the right frame that holds the service station,release the belt tensioner, remove the encoder strip, remove the display, disconnect the trailing cables, remove the belt, remove the carriage assembly, replace the belt, reverse the process. please be discouraged about this process. this is not an easy repair. if you can find someone someone who is certified on this repair it should take them 60-90 minutes. you can look up the cost of the belt at HP Parts Store. there are only 2 models 24" or 42". my recommendation would be to find an authorized hp dealer. ask them for a quote, the pricing should vary between $300-400. if you can find it cheaper i would be highly suspect and if you've had this printer for awhile then spend the money. make sure they clean and lubricate the rail assembly. good luck!
Aug 11, 2009 | HP DESIGNJET 500 InkJet Plotter Printer
Carriage belt replacement
Use the carriage replacement procedure in the service manual. Download here: www.lpscomputer.com/ec/manuals.htm
Aug 10, 2009 | HP DesignJet 500ps (42 in.) InkJet Printer
1055CM WITH BAD BLACK PRINT HEAD DISPLAY
more than likely the slot in your carriage assembly is faulty. try cleaning the contacts on the carriage assembly if that doesn't help, than more than likely you need to replace the carriage assembly and also the trailing cables. if you are going to keep this printer for awhile than you should also replace the carriage belt. if you can find a certified hp repair person, the cost should be around $500-600.
Mar 14, 2009 | HP DesignJet 1055cm InkJet Printer
HP DesignJet 500 InkJet Printer Logo
1,058 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
