Question about IBM Computers & Internet
When I go into My Computer to look at my Com Ports, port 1 is not there anymore. Because of this my modem does not work.
  • thetootall Jul 12, 2010
    When looking under Device Manager, does it show any Disabled items (denoted with a red X through it) or the "Other Devices" category?
  • d_braasch Jul 14, 2010
    No there are no Red X's in the Device Manager.
    Guru:
  • 551 Answers
Maybe the port 1 is defective. There is comports that are sell in the computer shop. Just look for it.
Posted on Jul 13, 2010
  • 26 Answers
If your modem is no longer detected you may need to reinstall the driver or in Windows-speek you will have to "Update" your driver.
Right click on "My Computer," go to "Properties," and then to "Device Manager." Here you will see a list of all items connected or supported on the computer. Go to "Modems" find your modem and "Update Driver Software." If you do not see it there either then under "Action" at the top of the Device manager screen go to "Add Legacy Hardware." Follow the prompt and install the modem!
-Paul
What port to use with ethernet cable
Hi all of you i see an app for iphone and android phone Ethernetpedia.which is i think very help full.which solve all your problem. port-use-5bezvpwuytf0bd1jcum4m4zn-3-0.jpeg
May 03, 2011 | Computers & Internet
IC VERIFY CREDIR CARD SOFTWARE WONT DIAL OUT AFTER SWAPING HD TO A NE PC. EXTERNAL MODEM WORKS FINE, SETTINGS ON ICVERIFY POINTS TO MODEM COM PORT. SOFTWARE WILL NOT DIAL OUT. aNY HELP?
Ok,
There's really only a few reasons this would fail beyond the COM settings. First, if the computer you're using has actual serial ports on the board and you're using a USB modem or if there are more than one serial ports it's possible you have either got the wrong COM assigned or that you have more than one trying to use COM 1. This will not cause conflicts with newer USB based devices but can when using actual UART chips on the motherboard or a mix of USB and UARTs.
Go into device manager and check for additional ports. Disable all COM ports except the actual modem and try again. If it still fails, check for DMA and IRQ conflicts. Do this by going into Start>All Programs>Accessories>System Tools>System Information.
Once open navigate to System Summary>Hardware Resources>Conflicts and Sharing.
Check for any conflicts with COM 1 and it's related DMA settings or anything sharing an IRQ with the modem. If you find any devices conflicting or sharing IRQ or DMA with the modem either disable the device or go into device manager, double click the offending device, click onto the resources page and find an alternate configuration that uses different IRQ/DMA that won't conflict. This will require a reboot for most devices.
Sorry my answer would be faster but I'm shaking almost a decade worth of dust and cobwebs out of my brain that have built up since the last time I even used a modem for ICVerify.
Hope this helps, lemme know how you make out,
chris
Dec 23, 2010 | Computers & Internet
Problem connecting external verizon modem to computer- error msg 'network cable unplugged'
Possible reason why your getting this message are the following.
1. defective ethernet cable
2. defective lan port on the modem.
I would advice you to do the following
1. Try another working cable
2. If your modem has multiple lan ports ( modem/router)
you can plug it on the other LAN ports and see if it will lid up
3.If you have a spare computer to try on the modem , please do so, so you can further isolate the problem . If its a modem port problem or your computer itself
Cheers.
KJ
Jul 04, 2010 | E-Machines eMachines Desktop PC
Ethernet cable 'splitter': Works on AT@T 'light' modem but not on cable modem. Are splitters speed sensitive
Splitters that work on telephone modems are not designed to work on cable modems. If you are trying to allow more than one computer to access the Internet, you need a broadband router.
You can find them on eBay and at stores for under $30. The primary difference between them is the number of "ports". A port is simply a place to plug in your PC. The more ports, the more PCs you can plug in.
Here's how you set a router up.
1. Plug a short Ethernet cable into the Ethernet "out" port on your cable modem.
2. Plug the other end into the "Uplink" or "WAN" port (will be labeled one or the other.
3. Plug an Ethernet cable into the LAN card on your PC and the other end into one of the open Ethernet ports on the router.
4. Reboot each PC.
You should be good to go!
Oct 25, 2009 | Linksys computers10: EtherFast Cable / DSL...
Usb modems will not work see's modem but will not complete driver install. Even if you manually update. Tried 2 modem's
check to make sure that your USB ports are working properly. Best thing is to hook up a usb mouse or usb keyboard.
if it recognizes those and installs the drivers properly then you know your USB ports are fine, at this point you know that its got to be something with the modems, either they are not compatible or the modems are bad.
Try a brand new usb modem and make sure whatever type of usb port that the modem requires is the type of usb ports you havve on your server.
Aug 11, 2009 | Dell PERC6/E SAS Adapter for Dell...
CG814WGv4 cable modem from Optus Australia, all 4 ethernet ports not wokring since thunderstorm in January 2009, can ethernet ports be checked if they are still ok, can it be fixed by SW reload, purch
hi i had the same problem with an optus modem thunderstorm ruined my ethernet port. i had to replace the modem from optus and all it cost me was $40(put on my next bill) cheaper then buying another modem. i was told i couldnt buy a modem from another source because apparently they have unique codes on them...hmmm don't know about that, but thats what i was told.
hope this helps :)
May 10, 2009 | NetGear CG814M Wireless Cable Modem...
Hardware conflict
You might have your internal modem set to the same com port as your com ports that are on your motherboard. You can try to go into BIOS and disable all com ports OR you can try to configure your internal modem in windows to use com 3 or com 4. Remember, that if your computer does have com ports in the back, then is is probably set to the same address as your internal modem so something needs to be moved.
Feb 11, 2009 | Hiro V.92 56K PCI DATA FAX VOICE MODEM...
Am trying to connect to the internet using my current computer and am getting no flashing light or connection to the internet although it says the modem is installed correctly on com port 3 when i have a...
in the control panel, device manager, remove the com ports then the modem. Restart the computer and the OS will reinsatll the com ports and the modem should be on a good port 3.
Sep 27, 2008 | Computers & Internet
Hard Wired Port Problem
please dont assign any manual addresses in ur computer..let it be automatic...
u said that u connected the computer to Ethernet ports in the router...
check whether the light are lit in the router corresponding to that particular port..
check the ip address to that particular computer(hard wired to the router)
ip address should be 192.168.1.100 or 101 or 102..if the ip addres comes in this range means its working good...
if ther is no ip means please follow this steps...
1,connect the blue cable between the computer and the router(any 1 of the 4 ports in the
router)
2,connect the other Ethernet cable between the Modem(came from ur internet people) and the
Router's Internet port(standalone port at the back of the router)
3,In the rear panel of the router u can see the reset button.with the help of the paper or
ball point pen,press it hardly and hold it for 1 minute..
4,Now turn off ur modem and the router..wait for other 1 minute..
5,turn onn only the modem first and wait till all the lights lit.now turn on the router and wait
till the power light is solid..open the internet Explorer it should work..
May 31, 2008 | Linksys Wireless-G WRT54GS Router...
Internet connection
Connect a computer to one of the lan ports 1-4.
Connect the adsl modem to "internet" or "wan" port of hub.
Open the hub's configuration page in your browser, usually this is http://192.168.1.1 Under Setup->Basic Setup, set the configuration for "Internet Connection Type " to "Automatic Configuration - DHCP". Under Network Setup, enable the hub's internal DHCP server so your lan hosts can get their ip's from the hub. Each local computer should have DHCP enabled. Your adsl modem must support DHCP for this to work, some do not. If it still doesnt work, try setting "PPPoE" instead of DHCP.
May 14, 2008 | Linksys Wireless-G WRT54GL Router
Computers & Internet Logo
59 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
