Question about Fisher Price Fisher Power wheels Cadillac Escalade EXT
Battery is charged car doesn't move - Fisher Price Fisher Power wheels Cadillac Escalade EXT
    Genius:
  • 1,970 Answers
Mcdevito75 here, Isn"t there a key that has to be on, also double check battery install maybe connections are backward.
Posted on Jul 13, 2010
Engine doesn't crank over, blown fuses and certain things not working?
sound like dead battery.no power to fuses if battery dead use digital voltmeter check battery volts should 12.6 volts if not have battery charged tested.if battery 4 or 5 years old battery could be faulty.
Apr 29, 2013 | 2010 Mitsubishi Lancer
We have fully charged the battery but when we pull the paddle to move it doesn't go
Reengage the wheels again then give it a slit push you should fell some resistance .seems the freewheel is not fully in
Apr 24, 2013 | Electric Mobility Mobility Electric Power...
Battery doesn't charge
It doesn't affect the charging. Have your alternator tested. If it is good, check connections between alternator and battery, and check all fuses.
Feb 18, 2013 | Cars & Trucks
I have a Uniden D1680 cordelss phone system. Often times when talking for two minutes or so--it disconnects--this happens alot. Any suggestions???
UNIDEN is notorius for this. It could be losing connection to the base - are you moving around while on the phone? or it could be the battery is not holding a sufficient charge. You can move the base unit to see if that helps - maybe something is interfering with the signal. You can try taking the battery out of the phone and putting it back in. If that doesn't work then try swapping the phones and putting them in each others charger. If that doesn't work then try letting the battery die by leaving the phone off the charger for 24 hours and then recharging for 24 hours. Good Luck!
Jun 10, 2012 | Uniden Cordless Phone
Train won't move. The sounds work great, and it used to move, but now it doesn't.
the sound runs from a different battery source, you'll need to remove the screw on the fron t of the seat and then lift the seat up and charge the battery with the supplied charger
May 28, 2012 | RC Thomas the Tank Engine
After jumper not charging charger not suuported
Many new chargers are digital devices that can detect battery issues such as bad cells so it then doesn't give out any current so have battery tested.Many times if a good solid connection via cable boosters and leaving the charging car idling awhile connected up to ur battery doesn't boost the battery it's bec the battery is no good.
Dec 18, 2011 | Cell Phones
My motoriola defy phone wont charge it has been at 0% charge all morning.
Hello and welcome to FixYa;
Take out battery, clean off the battery and gently clean off the terminals. Put battery back in and try to charge again with your charger. If this doesn't help;
Try another charger to the phone such as a car charger if you have one. If the battery still will not charge;
you may need to get another battery. I suggest you go into your local service provider first, have them use one of their spare batteries that fit into your phone model and see if the battery will start charging.
If it doesn't, you need to have your phone itself looked at instead of the battery.
Try these steps before you spend money on replacing parts needlessly.
Let me know how this worked out for you. If my solution helped you, please rate this solution!
It doesn't cost anything and only takes a second, but it is greatly appreciated.
KittyTech
May 30, 2011 | Cell Phones
Battery is charged but won't move?
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in
May 20, 2010 | Peg Perego John Deere Gator HPX Ride on...
Gateway Notebook ML6721 going back and forth between battery & AC
the socket where the cord plugs into the back of the laptop gets wattered out and does not make a good connection when it gets this way. I suggest that not move it so much it kinda defeats the purpose of a laptop. though
Jun 22, 2009 | Gateway ML6721 Notebook
Fisher Price Fisher Power wheels Cadillac Escalade EXT Logo
333 people viewed this question
Top Fisher Price Toys Experts
Bill Boyd
Bruce Mommaerts
Bruce Mommaerts
Jennifer Rock
Jennifer Rock
Are you a Fisher Price Toy Expert? Answer questions, earn points and help others
