Question about Cuisinart CPT-160 Metal Classic 2-Slice Toaster
Toaster handle won't stay down
Handle that pushes/holds bread down, then pops up when done, is broken. It won't stay down without me holding it down.
  • 30 Answers
SOURCE: Russell Hobbs RH2T toaster bread won't stay down w/o hold handle
Hi, most new toaster have a selenoid that hold down the handle while toasting then release when done so a spring bring the toast up. Possible problem with the selenoid, the electronic circuit that controls it or the plate that the selenoid holds. When you lower the handle you close the contacts of the AC line inside the toaster so if the handle is raised there is no power.
Posted on Aug 05, 2009
SOURCE: toaster when ipush the handle down to toast the
This is due to no power going through the relay that holds down the slice bar, when the setting is reached, the relay is de-energised, and it Pops Up. It is NOT doing so, due to A: No Power to the Unit, or B: Power is getting to unit, but one or more "Elements" is burnt out. or it has developed a controller fault.
Posted on Apr 06, 2010
SOURCE: toaster won't stay in down position
We opened up our toaster and scraped some baked-on crumbs off the top of the electromagnet that controls the carriage catch. When we closed it back up, it worked again.
Posted on May 10, 2010
SOURCE: My toaster doesn't stay in the down (toast) position unless I hold it down
I solved this problem on my Cuisinart CPT-90 Classic Style Toaster twice for two different problems. Of course: make sure it's UNPLUGGED while working on it and WATCH IT several times when testing so you can unplug it first and then extinguish it if it catches on fire.
1st time: There is a small solenoid mounted in the center of the circuit board. When the pop up mechanism is pressed down the circuit energizes and the the solenoid magnetically locks a plastic clip that holds the spring loaded pop up mechanism down until it's done toasting. The plastic mounts for the circuit board broke or weakened until the whole circuit board would tilt up and the solenoid clip would slip under the spring tension. I used a plastic tie-wrap to hold the circuit board firmly in place and that worked to this day.
2nd time : The four copper reed tabs can be miss aligned. If they
do not make contact, the circuit will not energize the solenoid.
The reason they warped was that, over time, the contacts build up carbon and have more resistance. Resistance equals heat. The
plastic base of the copper reed switch melted and misaligned the reeds. The second time I cleaned the reeds and bent them back into position, The third time the the plastic was to badly burned to be reliable. If I had cleaned the contacts once a year, it probably would still work now. I haven't found a place to buy a replacement reed switch so my toaster is toast. If anyone knows where to order them, I'd like to know. If the white plastic base of the reed switch is not melted, then they can be cleaned and aligned.
Note: When aligning the copper contacts, don't just hold down the pop up mechanism. The pop up mechanism will push lower than the position for toasting. Push it down and then hold the solenoid clip instead. Then the two center reeds will be at the correct spread.
Posted on Jun 26, 2010
SOURCE: problem with the CUISINART RBT-450BKPC costco toaster
We had exact the same problem. Our problem was within the circuit board controlling the release relay, on the left side. 3 parts was dead:
1) rectifier diode 200V 1amp
2) Electrolytic capacitor 220uF 25V
3 Zener diode 12V 1W
These components supplies 12VDC to the rest of the circuits from the mains, 127 VAC.
Posted on Jul 06, 2010
Fix sunbeam 3806 toaster that won't stay down and therefore heat bread.
Just a guess since I have had the same happen to my Proctor Sillex - When you push down the lever, you are actually completing the transformer frame that then magnetically keeps the toast down until it's setting lets the toaster pop up.
In my case, a piece of toast was wedged and I could not get the handle down so that the hardware was in place to magnetically hold. Have you tried to give your toaster a good thorough shaking upside down, unplugged over the garbage can or the sink?
Good luck Eric
Oct 04, 2017 | Sunbeam Kitchen Appliances - Others
Hi my girlfriend just gave me this toaster, and would like to know what the lighted buttons are for thanks
Since you don't mention the make or model number of the toaster or its age I can only make the following guesses.
It might be an electronic model. To test if this is the case, leave the toaster unplugged and push the lever of the toaster down. If it does not stay down it is an electronic toaster. If it stays down then it is NOT electronic.
The lights might be lighted push buttons.
If you plug the toaster in then put a slice of bread or two in and push the lever handle down and one light comes on then this is probably a dual purpose pushbutton. It indicates that the heating elements are on and if you push it will cancel the toasting cycle and the bread slices should pop up.
If there is a button beside the above button it could be for extending the toaster cycle time a bit longer to compensate for a thicker slice or a denser bread like a bagel. If you push it, it will light up to let you know that the cycle has been extended for this reason.
If there is a button beside this one, it could be for extending the toasting cycle to compensate for a frozen slice of bread or whatever, like a bagel or even a frozen waffle.
If you find the make and model for your toaster, it might be on the bottom somewhere, google it to see if you can download an instruction manual for it.
Hope this helps. Good Luck.
Jun 03, 2017 | The Kitchen Appliances - Others
De Longhi CT021.A x 2 slice toaser - Won't stay down
Is it plugged in. You may have to do a little handy work, unplug the unit and look to see where it catches when the handle is in down position, you may have to open the bottom door. There is a little catch when the handle is down it may need to be bent a little not much.
Oct 15, 2012 | DeLonghi RT200 Retro 2-Slice Toaster
Black & Decker Toaster, model 3550: Pressing the handle down to lower the bread and start the toasting doesn't lock in place anymore. The toaster will toast, but you have to hold the handle down so...
The fact that pressing down the lever fails, means the toaster contact will not function and can not be repaired. Since a two slice toaster is only $15 at Target, why bother fixing a toaster?
Feb 20, 2018 | Black & Decker Toast-It-All Plus T3550...
Our toaster stopped working a little while ago, but it is outside the (presumably) one year warranty period. It's a 4 slice, soft touch black toaster, cost about £75, I think it is this model. It only...
remove from the electricity supply
remove crumb tray,
remove bottom 4 os 6 screws.
at the bottom of the toaster there is what liooks like a flat fish hook that engages with the handle when you push the handle down to start toasting. clean around this and try to get it to engage when you push the handle down, it wont stay down unless the electricity is connected but dont plug it in as you will probably kill your self!!
put it back together abd try it
if it does not work 4 slice toaster from Tesco £9.99
Nov 09, 2009 | Dualit 45375 4-Slice Toaster
Toast won't stay down when handle pushed down handle comes up immediately as if not plugged in. Plug definitely in. Used only 3 times.
take it back. sounds like the magnetic coil that holds the handle down when it is plugged in is not functioning.
Oct 04, 2009 | West Bend 6220 Slide Thru 2-Slice Toaster
Aug 04, 2009 | Kitchen Appliances - Others
Bread will not stay down
Be sure the temp/time dial is not on zero.
Mar 11, 2009 | Russell Hobbs 9376 Classic 2-Slice Toaster
GE 169137 Classic 4-Slice
have you tried to turn up the heat thermostat on the side.
Jul 10, 2008 | GE 169137 Classic 4-Slice Toaster
Tfal 2-slice toaster repair
look inside your toaster. there must be something inside it turn it down and see if something comes out.. if nothing is inside then try to see if the cord that you switched on is not broken. if you see a liitle bit scratch mark on it- switch off. You can get a electric shock. it is your favorite toaster so try to consult a electricion to fix the cord for you.
Feb 26, 2008 | Tefal Avante Deluxe 4 Slice Toaster
Cuisinart CPT-160 Metal Classic 2-Slice Toaster Logo
188 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
