Question about Dell Inspiron B130 Notebook
Cannot get a full screen on my laptop. I only get 3/4 of the screen.
    Problem Solver:
  • 7 Answers
Try adjusting the Screen Resolution to a different size. Based on your operating system you can right-click in the center of your desktop and select either (xP) Properties then the Settings tab or (Vista/7) Screen Resolution and under the Resolution area try adjusting the slider and click Apply until you get one that fills in your complete LCD.
Posted on Jul 12, 2010
Black screen on advent5431
1. Check in Screen settings to make sure the video output is going to the laptop screen, not the secondary out put.
2. make sure that you choose Extend displays.
3. There is probably a FN key at the top that will toggle between primary and secondary displays.
Apr 21, 2014 | Acer Aspire 7720-6569 Notebook
Tip
Dell Laptops (Has power no display issues) 1. Immediately run PSA. (Make sure...
1. Immediately run PSA. (Make sure laptop is connected to AC Adapter. Leave laptop off. Press and hold on the Fn key then press power button once).
2. Just wait for about 3 to 5 minutes then you might will hear beeping sounds (no display with beeping sounds) this means that laptop is working fine but no display. This might cause by either the video card or LCD.
3. After hearing beeps turn off laptop. (Press and hold on the power button for about 3 seconds)
4. Leave laptop off. Press and hold on the D key then press power button once. If full screen colors appears this means LCD is working fine and the problem is the video card. If no display from the LCD no colors were displayed try the test again just to make sure. If still the same no full screen colors then the problem is the LCD.
on Dec 03, 2009 | Computers & Internet
Browser open, background screen (top of screen) flashes every few seconds. Laptop is about 3 months old. When typing on any app or online, if it flashes during the typing then it will skip the letter typed...
It is not a memory issue. Looks like a malicious script or setting issue. Here is what you can do, open the Internet Explorer and press F11, now you should see a full screen of the browser. Check if the screen is still flashing?
Thanks!
Oct 03, 2013 | HP Pavilion Computers & Internet
Asus 1005ha down arrow suddenly began toggling full screen
Try this:
Go to your computers manufactor and download the systems frimware drives (BIOS,Motherboad, etc). look to see if they have any drivers for the keyboard. This could be the result of corrupted drivers gone heywire.
Aug 27, 2012 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Laptop screen resolution
when u connect to projector.after connecting change your laptop screen resolution and by setting lowest resolution you will see full screen.
Feb 19, 2012 | InFocus LP530V Video Projector 2000 ANSI...
Hey.my laptop window is not full screen and it has no sound on it.it is an older laptop model
To fix the full screen problem just ajusting the screen resoulution. Go to the manufactors website to download a sound driver.
Jan 17, 2010 | Computers & Internet
Screen has flipped 90 degrees
Don't worry about that. I guess you were playing a full screen game, or a full screen program :) Try the following steps:
1-Open "Control Panel"
2-Open "Apperance and themes"
3-Open "Display"
4-Get to the tab "Settings", and click "Advanced".
Now I don't know the following steps, because of your graphic card, but look everywhere for a phrase: "Rotation" or "Flip". As you find it, look for the option to reset to the normal position (0*)
Hope this solved your problem!!
Good Luck :)
Jun 13, 2009 | Fujitsu AMILO PC Laptops
Screen does not present full display
may be ur display & graphics driver not installed properly
May 27, 2009 | Panasonic Toughbook CF-51 Notebook
Full screen probs with netflix
This has nothing to do with Netflix, you would get the same result with any DVD regardless of its origin. Chances are that is the laptop trying to revert to a screen saver or power save mode during the movie.
Check your laptop's power and screen saver settings. If you are experiencing the problem every 3 minutes or so, your screen saver is most likely scheduled to go on after 3 minutes of inactivity. The same goes for your monitor-- it may try to dim or turn off after a certain amount of time.
To change these settings to a longer delay, go to your desktop and right click. Select "Properties". Choose the "screen saver" tab, and change the "wait:" field to a higher number. Or, just turn the screen saver off by selecting "(none)" under the screen saver dropbox. You may also click "Power" and change the time for "turn off monitor" to "never", or a longer amount of time.
Jan 04, 2009 | Toshiba Satellite M115-S3094 Notebook
1/3 screen is blank and loose power jack
The LCD needs to be replaced. As for the D/C Jack its the sort of laptop an engineer would have to play by ear. Or in otherwords work it out as they go along. Try removing all of the screws that you can find and be careful that you know where the screws go back afterwards. You might need to flick the hinge covers off to access the rest of the laptop. They also tend to have plastic clips all around them.
Aug 28, 2007 | Averatec 3200 Notebook
Dell Inspiron B130 Notebook Logo
134 people viewed this question
Alun Cox
