Question about Compaq Presario 5000 PC Desktop
DVD+RW is not recognized. Doe's it mandate DVDRW+- only?
Cannot download my photography onto DVDRW+ disc. Does it have to be a DVDRW+ and - ?
    Brigadier General:
  • 4,044 Answers
That is determined by your DVD recorder not the media you are recording. The + and - are format types. You need to use the format that is compatible with your DVD recorder.
Posted on Jul 12, 2010
Dell gx 260 there is no disc in the drive.
OK, first of all you said you put a blank DvD in the drive. Make sure your dell has a DvD writer. Look on the drawer of the drive and see does it say DvDrw or DvDROM. It has to say Rw for rewritable and not ROM for Read Only Media. Maybe you have a Combo Drive that is DvDrom and CDrw which means it will read both DvD's and Cd's but in can only Write CD's.
If in fact you do have a DvD writer make sure you're not trying to put a Blue Ray disc in the drive.
Lastly, remove the DvD from the drive. Click Start/My Computer. Notice what it brings up as to your DvD Drive. Does it Say DvDrw or just plain ole DvD. DvD means it will only read a DvD.
Mar 20, 2012 | Dell OPTIPLEX GX260/SMT P4 2GHz 512MB...
My xp computer will not recognize the dvdrw. under hardware devices it shows the driver but with a yellow tab. the device is a liteon dvdrw 160p6s. liteon says in docs that it uses pnp service and not...
There are 2 types of dvd-rw discs, dvd+rw and dvd-rw. Some drives, especially older ones (since you are using XP) only support certain types. I run XP as well and many DVD+RW discs do not work for me. If this is the case, drivers arent your issue, its simply a hardware flaw. I would try experimenting with a different format, whether its + or - (plus or minus)
Mar 19, 2011 | Microsoft Windows XP Professional
MacBook Pro often will not recognize commercial DVDs
Go to MAC's website and see if there are any driver updates for your MACBOOK Pro.
Oct 25, 2009 | Apple Genuine Pioneer "SuperDrive"...
DVD RW DVR-K16 does not recognize blank DVD-R
I have a Pioneer DVDRW DVR-K16, in a sony dv81114Notebook. Running Windows XP. It cannot play dvd's and cd's, It will recognize blank CD-R's but when I insert a DVD-R it say's no disc installed. I have firmware version 1.15.
Nov 26, 2008 | Pioneer (DVR-K16) DVD RW Dual Layer Burner
Dvd rw drive not reading discs (DVD and CD)
That sound to me like a defective dvdrw because it can't read the dvd an try to re read and re read and lock the computer until you take it out.
Solution:
Tools:
+ Small screwdriver
-- Small screwdriver
Buy a new or used dvdrw for laptop, first take out the laptop battery. Locate the two screws at bottom of your laptop, take them out, whit a paper clip open the dvdrw from a small hole in front of it, pull the defective dvdrw out, if the front plastic face plate is diferent from yours you can change them using a small - screwdriver (be carefull). If you dvdrw have a smalls canals at sides in your defective dvdrw take them out and put them in the new one two, Install the new dvdrw by slowly pushing in to the dvdrw hole until it take its place, put the two screw drivers back + the battery and you shuold be on your way. Let us know. Obed
Sep 05, 2008 | Computers & Internet
I cannot format DVD-RW
I had to download the latest firmware (rev. VS0M) for Lite-On DVDRW SOHW-832S. This fixed the problem.
Jun 21, 2008 | Roxio Easy Media Creator 7
DVD Burner will not burn
Read the front of your drive to see if you have a DVD-R or DVD-RW drive. A DVD-R will copy a DVD to your hard drive, but will not burn it. If you do have a DVD-RW drive, try a different brand of disc or a DVD-R disc, some drive are just temperamental.
Jun 13, 2008 | Toshiba Satellite A105 Notebook
Not recognizing mini dvdrw
DVD-R discs can be used with no preparation, but a DVD-RW must be initialised before it can be used for the first time.
You may also have to initialise a DVD-RW if you get the message "UNABLE TO RECOGNIZE THE RECORDING MODE OF THE DISC" .
Also, make sure you always use DVD "minus" format discs - the DC210 will not work with any DVD "plus" format discs.
When you initialise the disc you will be asked to chose between Video mode and VR mode. Most DVD players will play a Video mode disc, but a VR mode disc can be edited with the camcorder. My preference is Video mode - I can then play on a DVD player and edit on a PC.
Don't forget to rate this solution once you've tried it !
Apr 18, 2008 | Canon DC210 DVD Camcorder
PD CD-RW 24x1040 external usb2 firmware
This device is meant only for CDs. However, the drive is an internal CDRW with IDE interface. You can substitute some DVDRW drives, but some DVD drives are picky about voltage and amperage. This enclosure is on the weak side for most DVDRW drives. You'll want to find a DVDRW that can work on as low as 8VDC on the 12VDC line. And the drive can't draw any more than .75A on the 12VDC line either. If the drive requires higher amounts, yor system may only recognize the drive as being connected to your system, but it'll never have the power to read the disc, and just kick it out after spinning the disc around for a short time.
Feb 12, 2008 | Pacific Digital (U-30106) CD-RW Burner
Compaq Presario 5000 PC Desktop Logo
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
