Question about Ovens
Hi the temp on our st george oven, model ueo-8 has become unreilable?
I have a St George UEO I would like to set it for automatic start, but can't seem to work it out.
Posted on Jun 29, 2013
    President:
  • 1,891 Answers
If digital the replace the oven control / if dial then the dial is at fault . mm
Posted on Jul 16, 2010
How do I set the clock on my st George oven model WEO-5?
do you have a button that says clock . press it if so and use oven up down buttons to set time , then press coc again
May 31, 2018 | Ovens
St George UEO-7 stopped working
The pop is the key. It sounds internal. The cost of a repair guy depends on ware you live. I would expect between 80-125 for the visit and the part could vary. So you could call the tech to see if it is worth fixing. Or at least find out what the part is and then buy the part and fix it your self. Many times the fee to have the tech look at the appliance is not charged if you have the appliance repaired.
The element going out should not effect the clock. The clock is 110 and the element is 220. There is something that acts like a fuse inside the unit it is designed to shut the unit down if it reaches an extreme temperature. But I also believe these rest them selves as they are not fuses but a heat sensor type thing. I would turn off the power and poke around first and then call a couple of techs and get prices on house calls.
May 25, 2014 | Ovens
I have a wall oven, a St George single oven. The
Depending on model-
Put the door at an opening of about 100mm. You should feel an indent for thecorect position.
You will probably need 2 people, 1 each side,
Slide the door upward at an angle same as hinge, It will slide off the hinge.
If the hinge is broken, and they usually break inside the wall of the oven, it will be very difficult to slide it off the broken hinge.
Hinges are available from EDIS SPARES 1800 125 039
Sep 12, 2009 | Ovens
St George DEO 7 oven temperature not going past 170
Merrillie,
we have this problem too on the top oven. I used to work at StGeorge and I'm an engineer, so if I find a fix, I'll let you know.
Simon
Sep 06, 2009 | Ovens
Oven turns off if too hot
There is a temperature switch that shuts the power down if the temperature goes too high. This is to prevent a fire if your thermostat sticks on. Sometimes the switch will become weak and open the circuit at too low of a temperature. Replacing the switch should solve your problem.
If you need more assistance, post a comment with the model and s/n of your stove.
Thanks,
Tim
Jun 28, 2009 | Ovens
Ovens Logo
348 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
