Question about Toshiba Satellite 5005-S504 Notebook
When i insert a dvd/cd, the light on the rom blinks - suggesting it is reading - but it doesn't. nothing shows on the computer. when i double click on the rom icon in MY COMPUTER, i get a blank window. Please help!
  • 734 Answers
Go to Start>My Computer> System Properties. and finally open Device Manager. In the list of Hardware items, go to your CD/DVD listing and open with one click on the little Icon to the left. Then double click on the name of the CD/DVD player. Click the Driver tab. Click the Update Driver button. If the driver won't update, click the Troubleshoot button and start answering the questions as closely to your problem as you can. You will often be led to a Microsoft Autofix application that will fix your DVD player.
Posted on Jul 13, 2010
My problem is that almost all of my CD's cant be read by my DVD rom drive in my computer, when I insert the cd it keeps on blinking until it stops and nothing happens, I tested it on the laptop and it...
it sounds like the dvd drive without ,,that's kinda what happened to our cd drive last week, I bought a cd drive at walmart,,but they also have good one at best buy
Aug 26, 2011 | Acer (KV.16X04.007) DVD Drive
Sir i am using acer 4736z i got problem with my dvd driver when i am inserting blank dvd for writing operation it shwos 0 bytes used free sapce 0 bytes not able to write data so what to do pls help me...
you have to make sure you are using the correct format for your drive i.e (+/-)
  • Read: 24X CD-ROM, 24X CD-R, 24X CD-RW, 8X DVD-ROM, 8X DVD-R, 8X DVD+R, 8X DVD-ROM DL (double-layer), 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 8X DVD-RW, 8X DVD+RW, 5X DVD-RAM, 4X BD-ROM, 4X BD-R, 2X BD-RE, 4X BD-ROM DL (double-layer), 4X BD-R DL (double-layer), 2X BD-RE DL (double-layer)
  • Write: 24X CD-R, 16X CD-RW, 8X DVD-R, 8X DVD+R, 6X DVD-RW, 6X DVD+RW, 5X DVD-RAM, 4X DVD+R DL (double-layer), 4X DVD-R DL (double-layer)
8X DVD-Super Multi double-layer drive:
  • Read: 24X CD-ROM, 24X CD-R, 24X CD-RW, 8X DVD-ROM, 8X DVD-R, 8X DVD+R, 6X DVD-ROM DL (double-layer), 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 8X DVD-RW, 8X DVD+RW, 5X DVD-RAM
  • Write: 24X CD-R, 24X CD-RW, 8X DVD-R, 8X DVD+R, 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 6X DVD-RW, 8X DVD+RW, 5X DVD-RAM
Apr 09, 2011 | Acer Computers & Internet
My cd/dvd rom do not play when i i insert cd.what can i do?
Try navigating to Start Button/ My Computer/, then Double-click the CD or DVD drive. If no CD or DVD drive shows up in My Computer, there is a problem with the drive. if no disc shows up in the Drive, it is a problem with reading the media.
Mar 27, 2011 | Computers & Internet
My lg gcr 8523b cdrom drive is not reading discs. when a dics is inserted green light blinks and cd rom makes a squeaking sound but after a moment it stops and doesn,t spins. what's the matter........
There are lots of possible reasons for this, but I will just try and give you a few troubleshootings
steps that you can try out.
The first one is that, your CD/DVD lens might have become weak, and therefore might need to be
changed, or if its just dirty, you might just need a lens cleaner.
The second reason is that, it might be that the CD you are trying to read is bad, dirty, or not
properly burnt...in this case, you might need to clean the surface of the CD properly then re-insert it.
Also, you can try to upgade your RAM(Memory Card Sticks), especially if it is less than
1Gigabyte. (I've seen a case like this before, and that is why I'm adding it.
The third reason is that, your CD/DVD Drive might be having a conflict within the OS. What I
would suggest in this case is that, Power up your system, then when the system boots, just right
click on my computer, then properties, then select the hardwares tab, then click on device
manager.
When you get to device manager page, try and locate DVD/CDrom Drives, then click on it, if your
drive is there, then just right-click on it, and select uninstall, and after this, on that same page,
click on 'Actions', and select "Scan for hardware changes". But if its not there. Just click on the
"Actions, and Then select "Scan for hardware changes".
This should automatically place your CD/DVD drive back inside your My Computer page. After
this, try the CD or DVD again.
Hope this helps you out.
Goodluck and Thanks for using fixya!
Nov 12, 2010 | LG GCR 8523B Internal 52x CD-ROM Drive
My light on dvdrw lh20 a1p will not read and durnt cd
I was having a problem getting my dvd (Lite-On LH-20A1P) to read my cds. I found a very simple solution that worked for me. I hope the following procedure works for others.
I have windows xp (I believe this solution may work for other window versions)
Go to "My Computer" on desktop (or in Start) and right click on it.
Click "Properties"
On the tabs at the top, click on "Hardware"
Click on "Device Manager"
Click the plus sign beside "DVD/CD ROM drives"
Double-click on Lite-On
On the tabs at the top, click on "Properties"
At the bottom, there is a box that is most likely checked that reads...
"Enabled digital CD audio for this CD-Rom device"
Uncheck it.
Do the same for all DVD/CD Rom devices you may have.
This simple solution worked for me. Now both my DVD and CD Roms are reading all of my cds.
I would suggest trying this simple step first before downloading any drivers or buying any 'Driver Update' programs - which may cause you even more problems than you are already having.
Beth
Sep 14, 2010 | Lite On LiteOn LH-20A1P - Disk drive -...
Cd player wont launch software
After inserting the CD, double-click My Computer, then double-click the D:/ drive or whichever drive letter corresponds to the CD-Rom drive on your computer. It should now load.
-Tha Mp3 Doctor
Dec 31, 2008 | Microsoft Windows XP Home Edition
The setup wizard on the CD will not automatically run when inserted in the CD-ROM drive, what do i do?
  1. click on start
  2. My computer
  3. right click on CD/DVD Drive
  4. Left click auto run
selecting My Computer, right-clicking the drive that contained the CD-ROM, and selecting Properties. click the AutoPlay tab and select the Select an action to perform option, then double-click the program to use to run the CD-ROM. This action launched the program on the CD-ROM. Note that simply highlighting the program you want to use and clicking OK or Apply doesn't work; you must double-click the program and force it to launch on the CD-ROM or DVD in the drive. The CD-ROM then ran automatically, using the program associated with it on the AutoPlay tab.
Apr 15, 2008 | Computers & Internet
Combo drive not reading DVD
my combo drive also not reading dvd :(
Dec 23, 2007 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
CD ROM CR-589
Hi, A couple of possibilities: With a known good DVD with files inserted into your Compaq CR-589, double click in your My Computer, double click in your CD/DVD. 1. If it opens and displays the content, then there is nothing wrong with your DVD but the auto start feature of your OS was disabled, enable auto start; 2. If in My Computer or in Device Manager, the DVD doesn't show up, then it can be hardware problem, IDE/power cable problem, bios did not recognize DVD device, replace if and as needed; 3. If the DVD is in My Computer but will not display the files or contents, possibly defective DVD, replace. Hope this worksa out for you. Pls post again how things turn up. Good luck and kind regards.
Aug 05, 2007 | Compaq 32X IDE CD-Rom Drive (opal)...
Toshiba Satellite 5005-S504 Notebook Logo
71 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
