Question about Maximatic Deluxe Popcorn Trolley Popcorn Maker
Motor I think the motor is broken, can I buy a replacement?
  • 206 Answers
You might be able to it just depends on the type of popcorn maker
Posted on Jul 13, 2010
Broken motor mounts?
Would you not ask that question at an auto parts store
or go to an inline parts site?
Why not also install yourself?
I don't think a repair shop will appreciate you
walikg in with new parts as they loose the 20% or
more your trying to save.
On a Taurus you replace the motor & transaxle mounts
All of them,I think that is 3 in total.
Jan 21, 2013 | 1991 Ford Taurus
I have a 1995 dodge caravan w/a broken timing chain , Once i purchase parts ,what do you think are reasonable labor cost ??
IF IT WERE MY CAR I WOULD PURCHASE USED MOTOR FROM JUNKYARD,IF THE CHAIN BROKE ITS POSSIBLE THAT ONE OR MORE VALVES COULD HAVE BENT,THEN THE HEADS WOULD HAVE TO COME OFF....YOU NEED TO FIND OUT IF THAT IS A ZERO TOLERANCE MOTOR FIRST,BEFORE BUYING ANY PARTS.IF JUST THE CHAIN CAN BE REPLACED I WOULD LOOK TO SPEND 500 TO 700. YOU COULD BUY USED MOTOR FOR 500 AND 350 TO PUT IN.
Aug 10, 2011 | Dodge Challenger Cars & Trucks
Broken screen. i think both internal and external. it's pretty bad. replace screen? or buy new tv? or buy broken tv with in-tact screen? i paid $450 for this tv, so what is most cost effective?
Buying a new TV would save time most definitely, if it's in really bad shape the repair costs would add up pretty huge. Buying a broken TV with an intact screen might work as long as you can prove it's exporting signal though. If time means anything, and you have experience in engineering, I'd say go with buying a broken TV, otherwise based off your description, just buy a new system.
Jul 17, 2011 | Mitsubishi WD-65731 65" HDTV
Drivers side window will not go up, I think it's the motor. 202 mitsubishi galant 4 door
If u switch the WiNDOW and u hear some buzzing inside the door, means the motor is still working! Mostly the part easily get broken is the WiNDOW REGULATOR assembly! You could buy and replace the regulator only w/o the motor! Before putting a new regulator add some GREASE on the cable link and the plastic guide!
Taah!
Nov 10, 2010 | 2002 Mitsubishi Galant
Dyson DC16 has broken impeller. Need schematic and part
you cannot buy the impella but i have a complete motor for spares if u think your upto the job pls msg me,, promo7uk2@hotmail.com
you pay postage costs via paypal and 10£ for motor and its yours,
May 17, 2010 | Dyson DC16 Root 6 Bagless Handheld...
Mazda Tribute 2001 automatic antenna is broken. Can hear the motor running but I think the cable is broken. Where can I buy an antenna mast aside from the Mazda Dealer.
If you hear the motor running, you are probably right that the cable that attaches to the antenna mast is broken. You should be able to buy this part only. Check Ebay. Sometimes you can buy the mast portion with the cable attached only. It's a lot cheaper than the whole assembly with the motor.Here's a link to one.
http://cgi.ebay.com/ebaymotors/Black-Billet-14-ANTENNA-2001-thru-2009-Mazda-Tribute_W0QQcmdZViewItemQQhashZitem588671d518QQitemZ380212729112QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Feb 12, 2010 | 2001 Mazda Tribute
Broken plastic screw from motor shaft
According to Jack Lallanes Support you need to buy a new motor! No replacement part for that specific part!
I have the same problem and also do not want to buy a new motor! Scam!
Dennis
Nov 21, 2009 | Jack Lalanne Power Juicer 250 Watts
I think my motor is broken , can i simply replace
Unless you know what you're doing, you can easily mess the whole thing up. It's not hard to replace the motor, but its a task you have to pay close attention to. If you can, get the motor from Sebo and then take it to a local vacuum shop and have it installed. But first make sure they are an authorized Sebo ship
Aug 12, 2009 | Sebo Air Belt C2.1 Bagged Canister Vacuum
Motor is broken and will not enter into a cycle
If you're sure it's the motor than you must call a repairman to replace it. Although, if your machine isn't in perfect condition perhaps you should consider buying a new machine or replacing broken motor with used motor (second-hand) since it is not a cheap part and repair itself will cost you too.
Apr 20, 2008 | Washing Machines
Shear pin ??
You most likely have several teeth broken off the drive gear that drives the cutting block. Not too difficult to replace but you need some special tools. A deep well socket (I think it's about a 3/8") to remove the cutting block and replace the broken gear. The gear should be available from a Fellowes dealer, or they might sell it to you direct if there is no dealer near you.
Let me know if this helps.
Aloha,
Bill Monroe
Oct 15, 2007 | Fellowes 220C-2 Shredder
Maximatic Deluxe Popcorn Trolley Popcorn Maker Logo
120 people viewed this question
Top Maximatic Kitchen Appliances - Others Experts
George Merkley
George Merkley
raysaw
Irene Tulloch
Are you a Maximatic Kitchen Appliances - Other Expert? Answer questions, earn points and help others
