Question about Tefal Avante Deluxe 4 Slice Toaster
Wont stay down
Toaster stopped working - wont engage-wont stay down-how do i repair possible solenoid problem
    Problem Solver:
  • 3 Answers
At the moment I am looking for the problem in m,y Tefal. The biggest problem seems to be sorting out how to pull it apart. I have sfound that the whole carriage must be pulled out the back of the toaster. About 10 T10 screws to be removed from the base then there are are a couple more philips screws to remove after the back is off, then the handles that you press down to allow the bread to drop mus t be released. There are plastic pieces that hold in the metal tip on the handles. They are located inside the body and are accessewd from the slot that the handle moves in. I haven't yet located the release clips for the high lift handles. Once I have found them I may be able to access the mechanisms. If this doesn't help enough then please ask for more information as I shall have found my way inside by then
billypil
Posted on Jul 13, 2010
Kitchen aid toaster won't stay down, heats when held down, but only on bagel setting. Checked crumb tray but all clean. What to do?
Contacts may be coated with Burt oil, butter, other matter. When engaged, contacts aren't engaging.
Aug 31, 2014 | Kitchen Appliances - Others
Cuisinart CPT-180
default_avatar.png Dale Anderson
1- Crumbs or part wearout may be keeping the plastic latch from engaging. If you have the toaster apart, you can compare the arm latching action of the good side with the bad side--maybe there is an obvious difference in the travel of the arm that keep it from engaging.---leaving the travel short even 1/8" can keep the latch from engaging.
2- If there is nothing obviously mechanically wrong, then it may be a control board malfunction. Make sure the 3-pin control board connector is plugged into the transformer/solenoid board. Since you are getting lights, this should be OK. You have at least one good board (the side that works) so you could plug that board into the other side to see if the arm stays down. For fun, you can plug the bad board into the other side to see if the other side now malfunctions. If the problem follows the board, then you have your answer.
If you know someone that understands electronics, they may be able to repair the board--have them look at electrolytic capacitor C1 and make sure it is good. If that part is bad, it can be replaced for about $1 by going to Fry's and purchasing a replacement capacitor. After a couple of years of use, a defective C1 may "dry out" and cause control board problems.
  • I repaired the same symtom that happened to one of the sides of my CPT-180 toaster. The magnets wouldn't engage due to a bad C1 capacitor on the circuit board that controlled that side of the toaster--the capacitor was bulged out on the bottom and turned out to be bad. I've attached some photos showing C1 bulged out compared to C1 on the good board.
    C1 is the main power supply capacitor and if it goes bad, the circuit board power supply won't function correctly. This can lead to a broad spectrum of problems like the lever not staying down due to the magnets not engaging or the toasting control/timing circuits malfunctioning. If you replace the capacitor, it is best in most cases to replace with the same value as the orginal (220uf on my toaster)---you can usually get a replacement capacitor at Fry's Electronics. Replacing with a higher capacitance may be acceptable, but you should understand the impact to the rest of the circuit before you substitute a higher capacitance value. The voltage rating and temperature rating of the replacement capacitor should be the same or greater or the capacitor will fail quickly. Note the max temperature rating of capacitor C1 is +105C---toasters get hot (duh!) and the temperature around the circuit board of this model gets quite warm, so the temperature rating of the capacitor is critical. Finally, make sure the substitute capacitor fits when installed (requires soldering) and does not interfere with surrounding circuitry or other toaster mechanics when the circuit board is put back in place.
    Pictures:
    C1_location (next to screw)
    Comparing_good_C1_with_bad_C1--note bulge on bottom of right C1
    Right_orginal_C1_and_left_replacement_C1
    Bad_C1 showing capacitance, voltage and max temperature ratings
    5487aa4b-7e7d-4e6f-9542-cf9ff618008c.jpg2d853c87-48b6-4735-99f4-fdd5dbc60ffe.jpge1a82299-a243-46e1-b11b-4c20e0d9b304.jpg5543b7e5-8108-4b1d-bed3-90eee4600722.jpg
    Jun 24, 2014
May 26, 2014 | Cuisinart CPT-180 Metal Classic 4-Slice...
Our toaster stopped working a little while ago, but it is outside the (presumably) one year warranty period. It's a 4 slice, soft touch black toaster, cost about £75, I think it is this model. It only...
remove from the electricity supply
remove crumb tray,
remove bottom 4 os 6 screws.
at the bottom of the toaster there is what liooks like a flat fish hook that engages with the handle when you push the handle down to start toasting. clean around this and try to get it to engage when you push the handle down, it wont stay down unless the electricity is connected but dont plug it in as you will probably kill your self!!
put it back together abd try it
if it does not work 4 slice toaster from Tesco £9.99
Nov 09, 2009 | Dualit 45375 4-Slice Toaster
KitchenAide Toaster
Kitchenaid does not recommend repair on the toasters, as it is not cost effective for the consumer or company to engage in repair.
I would recommend calling Kitchenaid Customer Service. If the unit is within the 1 Year Warranty, they may replace it at no cost. If the unit is outside of warranty, they may provide discounts on the purchase of a new toaster.
Their toll-free telephone number is 1-800-541-6390.
Apr 10, 2009 | KitchenAid KTT261 Ultra Power Plus 2-Slice...
The digital control panel is on the fritz,
We ran into the same problem today with our toaster. There was never a problem before I cleaned it--not only by sliding out the crumb drawer, but by turning it upside down to dislodge every last crumb. After that, It would not stay down when pushed down--and none of the buttons were functional.
My husband took the cover off and found that a magnet is what keeps the lever down when the toaster's on, and allows it to go back up when the toasting is done. It's an electro magnet that works only when the toaster is on. It seems that when I turned the unit upside down and rightside up again, crumbs landed on the magnet's contact plates (which are about 1/4" x 1/2") and would not allow the magnet to engage. Because the magnet wouldn't engage, the lever would not stay down, and the toaster shut off. Brush off the magnets, replace the cover and toast away!
Nov 28, 2008 | Oster 6330 4-Slice Toaster
Lever will not stay down on Krups 155 ToastControl Compact
No promises, but I had a similar problem with a Breville Clasic. Toasters these days use a solenoid (electromagnet) to hold down the toast carriage. This solenoid is usually soldered to the circuit board, and is reasonably big, i.e. 1/3 a cigarette pack.. on mine, because of repeated impact when the carriage is pushed down, one solder connection developed a haiirline fracture. This meant that most of the time it wouldn't stay down. I resoldered the connections and all ok.
Oct 02, 2008 | Kitchen Appliances - Others
Tefal toaster wont stay down - Avanti Elite, twin.
Hi, I assume that you had the toast carriage pushed down when you check the solenoid (hold down coil) volts ? .. a bit dangerous to try though
Either way, try resoldering the solenoid connections, they can develop hairline cracks that limit the current.
Feb 11, 2008 | Kitchen Appliances - Others
Bread won't toast
We ran into the same problem today with our toaster. There was never a problem before I cleaned it--not only by sliding out the crumb drawer, but by turning it upside down to dislodge every last crumb. After that, It would not stay down when pushed down.
Dec 27, 2007 | Kitchen Appliances - Others
Lever won't stay down Breville CT20
hi sounds like the problem is the holding down mechanizem clean the toaster well find that spring which caches the lever down you can find it on the external lever side pretty small and simple thing when you push down the external lever the spring kick a little lever which holds the slide in place for heatup only when you will hear a "click" then you'll know its in place and then the electric cicuit will be close and engage the coils to heatup good luck
Mar 30, 2006 | Breville CT20 Retro Classic 2-Slice...
Tefal Avante Deluxe 4 Slice Toaster Logo
601 people viewed this question
Top Tefal Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paul
paul
Oscar Netto
Oscar Netto
Are you a Tefal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
