Question about Bosch 24 in. SHU53 Built-in Dishwasher
How do I run Test mode for a Bosch SHU5302UC dishwasher? How do I drain and cancel and wash cycle?
  • Bosch Expert
  • 414 Answers
Don't hold me to this but I believe to reset during a cycle you press simultaneously the two buttons with a dot under them (2nd in from the left and 2nd in from the right) 0.01 or 0.00 comes on the screen and the pump will run. To run a test cycle turn machine of, press and hold the same two buttons and turn machine on whilst holding them in, the machine code should show in the display (usually a number in it's 20's), release these two button and then immediately press them again, this should initiate the test cycle. The d/w should now run thru a test cycle. If no fault is detected the display will show 0 or 1. If anything else, please repost and I will try to let you know what the fault code represents. test sequence is usually is as follows.
Pump, fill, circulation motor, dispenser (listen for it to open), heat to 65 degrees, regeneration flush, intermittent pump, sensor recalibration (if the d/w has any), alternate fill/pump, pump, finish. Take approx 10-15mins to complete.
Hope this helps, pls feedback or reply if unknown code appears.
Posted on Jul 12, 2010
  • Bosch Master
  • 2,605 Answers
Hello, welcome to FixYa.
I`ve attached a document which should answer both of your questions, if it worked.
Let me know if you have any problem reading it or require further assistance.( you may have to copy and paste it in a "windows viewer program" or the like to enhance it, I couldn`t with the limited resourse I have at the moment ).
I could email it to you if you want to post an email...if this doesn`t work.
Thank you for visiting FixYa to day. Please take a moment to rate the assistance I provided for you here today.
Good luck.
macmarkus :)
Posted on Jul 13, 2010
  • Mark MacDonald
    Mark MacDonald Jul 13, 2010
    Nope, didn`t work.
    If you post email address I`ll send the complete test guide or tech manual whichever you prefer.
    Let me know.
    macmarkus :)
  • lantolov Dec 16, 2010
    can you forward me a copy of the test procedure?
    Thanks
    Luch
    lantolov@gennum.com
Motor keeps running. Water heats fine. Help
One of the reasons for motor not draining during normal cycle is the check valve is stuck. It is meant to return to normal during drain cycle but close during wash. I think the cancel is resetting it and letting water out.
See this discussion.
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dishwasher/26-129-977852-/Bosch-Dishwasher-won-t-drain-SHE43RF2UC64
Apr 02, 2014 | Bosch 24-in Built-In Dishwasher Color:...
My Bosch dishwasher is driving me crazy! When it finishes a wash cycle it beeps twice every 10 minutes until the door is opened. We can't run the dishwasher at night after dinner unless we're SURE we...
Hello there,
It would help to know the model number of the dishwasher, but on many Bosch dishwashers, you can switch the cycle cycle completion signal off as follows:
1. While holding the right-hand CANCEL/DRAIN button, also press and hold the ON/OFF button
2. When the LED above the CANCEL/DRAIN button illuminates and the beeping starts, release both buttons
3. Press the right CANCEL/DRAIN button repeatedly until the beeping tone is at the desired volume, i.e. silent!
4. Press the "ON/OFF" button again to set the volume.
On models with the wash cycle buttons on the top edge of the door, the CANCEL/DRAIN buttons aren't always explicitly labelled CANCEL/DRAIN. These buttons are also labelled RESET on some models.
On models with 3 and 4 wash cycle buttons, the right CANCEL/DRAIN button is the third button when reading from left to right. On models with 5 wash cycle buttons, the right CANCEL/DRAIN button is the fourth button when reading from left to right.
Please try the above then let me know if you need further assistance. Please state the model number or series (i.e. Integra) of your washer if/when replying.
Hope this helps.
Regards,
BElectric
Mar 16, 2011 | Bosch Dishwashers
Bosch dishwasher shx55m with bottom tub full of water
The dishwasher really shouldn't pass any particles near large enough to clog the drain hose. It sounds more like a mechanical issue. Check the circuit breaker to make sure it's not tripped. See if you can hit a cancel button or something to make it drain. Try to run another cycle. If the computer is stuck or acting funny, trying cutting the power for a while, holding down a stop/reset/cancel button, or running a cycle that you don't usually run. I had this kitchenaid that would randomly refuse the normal wash cycle, but would run fine when you ran rinse only or something, then regular wash and everything would be fine again too. If the line somehow is clogged, there's a good chance it's right where the hose connects to the disposal or drain pipe.
Feb 18, 2010 | Bosch Integra® 500 SHX55M05UC Built-in...
When the washer gets to 1 in the cycle, it doesn't stop washing.
try running the test cycle or running delicate economy in that cycle it gets up to 150 degrees in the very first cycle let it run 15 or 20 min see if the water is screaming hot it is not and Luke warm it is not heating it is most likely a control board heaters very rarely go out
Jul 24, 2009 | Bosch SHU5316UC Dishwasher
Error code 2H
The control panel needs to be replaced (indicated by the "2H" error code displayed at the start of the cycle).
BTW - The number 1 displayed at the end of the cycle indicates the cycle has timed out (i.e., it doesn't mean 1 minute remaining). Hence the continued running of the unit. Until you replace the control panel, you'll have to manually cancel the cycle at this point.
Oct 08, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch shu5300 dishwasher
there is a relay on the main control board that has gone bad. you have to replave the whole board to fix the problem
Nov 24, 2007 | Bosch 23 in. SHU5302UC Built-in Dishwasher
Bosch Dishwasher wont drain
have you removed the filter? if it gets clogged the dishwasher wont drain. other wise is sounds like a faulty drain pump
Nov 17, 2007 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch SHU5316
Sounds like the control module is out -- cost about $100 (I am on my third). I got a "lifetime" warranty when buying my second one. If you are handy, you can replace it yourself. You can call Bosch to confirm this (I did). It mounts inside the door.
Apr 15, 2007 | Bosch 23 in. SHU5302UC Built-in Dishwasher
Bosch 24 in. SHU53 Built-in Dishwasher Logo
1,392 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
