Question about Sunbeam 4243 Iron
Sunbeam 4243 iron. When turning on green window with settings flashes very fast or goes off. Red wait light goes on but will never turn green. Plate does not get hot. After leaving on for awhile red power light flashes.
5 Suggested Answers
brnspncr
  • 67 Answers
SOURCE: trouble cleaning Sunbeam iron 3983
you can buy an iron cleaner from your hardware store, wallmart sell it.
Posted on Jun 11, 2009
  • 158 Answers
SOURCE: sunbeam iron won't power up.
I bought a new replacement iron at Sears for $17.99. It is not worth fixing my old one .
Posted on Jun 18, 2009
Metal maniac
  • 6 Answers
SOURCE: 4268 iron leaving residue
This will probably just need de-scaling. Buy some descaler and there should be instructions on the packet of how to de-scale an iron. Usually by warming the iron slightly, switching off, emptying out the water and then adding the diluted de-scaler to the iron and leaving it in an almost horizontal but raised position in a bowl or something so that some of the de-scaler will drain through. Then emptying out, re-filling with water and then iron something that you don't mind getting marked while any residue get's flushed out.
Posted on Aug 04, 2009
  • 4234 Answers
SOURCE: My non stick sole plate on my Sunbeam iron is
The discoloration is from a reaction of your water and the shield. The best way to avoid this is to use distilled water rather than tap water or use a water filter. I have had this problem at home as well (i have well water) and using a filter "fixed" the problem for me. Hopefully this will resolve the problem for you as well.
Please let us know if you still have the problem and we'll look for other alternatives.
Dan
Posted on Nov 05, 2010
Sunbeam iron model gcsbcs-212 troubleshooting unit keep turning off while ironing
The iron is getting to hot internally and setting off the high limit switch. Since these cannot be repaired by design, you will have to replace the unit.
Mar 23, 2017 | Sunbeam Irons
Why light blinks then goes off when switch is still in the on position
The thermostat in the iron controls the temperature of the iron. The red light indicates when the power applied to heat the iron which is set by the temperature dial on the iron. When it reaches the correct temperature the thermostat turn off the power and that is when the red light switches off.
Jan 15, 2012 | Irons
Iron worked fine yesterday today it turns on but does not heat up Any answers? Is it shot?
Simply, something internally failed. Probably burned out a component, it happens. So yes, it is shot and it's time to invest in a new iron. Let me know if I can help you with anything else.
Benjamin
Nov 04, 2010 | Sunbeam 4243 Iron
Need to clean my sunbeam steam iron and can't find the instruction book. Help! Won't spray when I push button, can't get the clean mode to go anywhere.
Fill it with white distilled vinager and sey it in a shallow pan with enough of the same vinager to cover the shoe. Let that sit overnight then try the clean function again.
Eric
Jun 20, 2009 | Sunbeam Steam Master 4055 Iron
Sunbeam iron won't power up.
Jun 17, 2009 | Sunbeam Irons
I'm having a problem with the auto shut off of my sunbeam 421A series iron. The iron works great until the auto shut off comes on and the red light starts blinking. I understand that the iron should...
Unless you have a 5 or 6 hundred dollar iron, or unless it is brand new, and still under warranty, there is an excellent rule of thumb when an iron quits working: Buy a new one! These days, irons can be purchased cheaply enough that it is WELL worth the money. Not just for the convenience, but for the safety issues. This is an appliance that could burn your house down even if it's in PROPER working order. Hope this helps!!
Chad
Sep 21, 2008 | Sunbeam 4214 Iron
Iron whuts off
check the circuit at the switch it could ave faulty cap that is not regulating the voltage properly.replace it.good luck
Apr 11, 2007 | Sunbeam 4237 / 4238 Iron with Auto...
Sunbeam 4243 Iron Logo
50 people viewed this question
Top Sunbeam Irons Experts
Wayne Fellows
Wayne Fellows
Craig Butler
Craig Butler
Are you a Sunbeam Iron Expert? Answer questions, earn points and help others
