Question about Canon PowerShot S90 Digital Camera
After i shoot a picture the image no longer displays on the screen for a second or two. It used to do that but i don't know what i did. Please help!
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Set the Mode dial to P. Press the MENU button and use left/right to select the camera tab. Use up/down to select the image display time and make sure it's not set to Off.
Posted on Jul 12, 2010
Why is display information having a ghost like after image when the camera is turned?
Perhaps some moist came behind the glass? perhaps some air? Try to live with it, because the result is what counts and the pictures don't have this problem. I think it will cost far to much to bring it to a service or repair centre. Use the money to buy a new camera what this no longer shoot pictures.
May 18, 2014 | Fuji Finepix S3200 14. Mp 24x Wide Angle...
Desact monitor
When the following symptoms, that is, to replace a laptop LCD screen:
No image on the screen, but the power light stays on
Dark display but still readable
Between the screen flashes on and off 1/2 to several seconds
Power light stays on, but no display and sound
No image on the screen, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
Jun 07, 2013 | Computers & Internet
My screen is black and will not display images to shoot. Also when picture is taken it plays back as black image. Previously taken pictures will display.
Michele, a stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 19, 2011 | Canon PowerShot SD960 IS Digital Camera
Battery level don't show on display.
hi friend,
follow these steps
  1. Turn off your LCD display screen. I know this is hard—who likes shoving their face against the camera to compose a shot through the little viewfinder? But the LCD screen single-handed-ly drains a lot of power.
  2. Minimize the picture preview to the least amount of time possible—usually one second. This uses less LCD screen time, thus less power.
  3. Dim the brightness on your LCD screen. A dimmer display extends battery life by consuming less power to light the screen. This might make the display harder to see, but usually only in direct sunlight.
  4. Set the power saver to the least amount of time. Power saver lets your digital camera “sleep” when not in use, but doesn’t shut it down entirely. To “wake up” your digital camera, simply click the shutter button.
  5. Use your zoom as little as possible. The motor that moves the lens uses power. This also goes for repeatedly turning your digital camera on and off if it has an extend able lens.
  6. Turn off the continuous focus. Again, constantly using motors and electronics to ready your shot drastically minimizes battery life.
  7. Don’t push the shutter button half-way down until you’re ready to shoot. Pushing the shutter button (constantly resetting and refocusing) will drain battery life.
  8. Use the flash only when necessary. Your digital camera’s “auto flash” option should take care of this, but make sure your flash isn’t going off in broad daylight.
  9. Don’t delete pictures from your digital camera unless necessary. This consumes power. Wait until you download the pictures to your computer before deleting.
  10. This one’s basic, but charge your battery often. Lithium ion batteries, which most digital cameras use, don’t have “battery memory” like older alkaline. In fact, lithium ions work better and last longer if charged completely and regularly.
thank u for using fixya
regards,
sivaranjini
Aug 11, 2009 | Kodak EASYSHARE M1063 Digital Camera
Canon Powershot SD1000: LCD screen display
Hopefully you resolved this already. If not, push the "DISP." button left of the MENU button. Pushing it gives you three options: black (for discreet shooting so your LCD doesn't give garner dirty looks from fellow concert goers), liveview, and liveview with info overlayed (shooting mode, ISO, etc.). Good luck!
May 05, 2009 | Canon PowerShot SD1000 Digital Camera
Image or movies are not appearing in the screen
Depending on the camera you are using (you didn't give the make and model, so I don't know for sure), Go into the setup menu and make sure the LCD screen is turned on, or look for a similar setting. Again, without knowing what camera you have I have to be general here. Let me know if I can help you any further. Thanks for coming to FixYa and don't forget to vote my answer a fixya.
Rob
Feb 23, 2009 | Canon Cameras
Television screen is showing mirror image not the actual image.
There's a button on the original remote control that does exactly that:
(Please vote or comment if my solution helped you!)
Adjusting PICTURE FLIP Settings
You can set the orientation of the picture.
Directly setting the PICTURE FLIP
Press PIC. FLIP to display the
PICTURE FLIP screen.
2 Press PIC. FLIP to change the
setting.
Setting the PICTURE FLIP on the
MENU screen
Press MENU to display the MENU
screen.
2 Press a/b to move the cursor to
PRESET, and press ENTER.
3 Press a/b to move the cursor to
PICTURE FLIP, and press
ENTER.
4 Press c/d to select the desired
picture flip setting, and press
ENTER.
5 Press MENU to return to the main
screen.
NORMAL MIRROR ROTATE
UPSIDE DOWN
A•
The PICTURE FLIP screen automatically
disappears in 3 seconds.
• [NORMAL]: normal image
[MIRROR]: mirror image
[ROTATE]: rotated image
[UPSIDE DOWN]: upside down image
Oct 22, 2008 | Sharp LC-15AV7U 15 in. LCD Television
Finepixz20 digital camera
That is actually the exact same thing I am experiencing but mine has grey lines on the display window. I was able to take photos to a grey screen connect it to my comp...low and behold my pics showed....I am furious....need some answers as I will never hear the end of it from my daughter.
Grrrrr
weelassy
Oct 20, 2008 | Fuji FinePix Z10fd Digital Camera
Monitor does not stay on
The LCD monitor screen at the back of the camera does not display a live picture like many point-n-shoot digitals. It only displays after the pic is taken. Use the LCD on the top cover to check your settings. Please leave feedback if this helps.
Aug 02, 2008 | Nikon D80 Digital Camera with 18-135mm...
No display at all. But able to take pictures with Canon A75
Sounds like you might have accidentally turned the display off. Turn on the camera and press the DISP button once on the back of your camera.
Mar 17, 2008 | Canon PowerShot A75 Digital Camera
Canon PowerShot S90 Digital Camera Logo
35 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
